Everything posted by druxey
The overall effect of your model is lovely: I'm expecting someone to walk over and climb aboard! Congratualtions on an outstanding result, Geert.
Sorry, you are quite correct, Chris. That's who I was thinking of! I remembered incorrectly. Bad memory! Bad!
In this new self-isolating world, we ship model-makers are the lucky ones. We at least have somethign productive to do. Although a nice pint of draught.... Fabulous detail work as ever, Keith.
Welcome! If memory serves me correctly, there's another ship modeler in Yellowknife.
Can you cast a few master figures in the rough and then complete them individually? Impressive work on the tholes using hand-held equipment only.
Garboard plank
druxey replied to Sheerline's topic in Planking Techniques's Click Here for Topics dedicated to planking!!!!
One, you are correct in not letting the garboard creep up the stem. Two, you seem to have a good fit to the rabbet in picture two. I recommend that the curve on the edge that abuts the second strake be make more gradual before spiling and fitting the second strake. Starting the curve as far back as the right edge of the photo should be about right. -
Help evaluating old model of screw steamer USS BROOKLYN
druxey replied to Cono's topic in New member Introductions
Good assessment, Eric. -
Nice to see the end in sight, Rob. It's been quite a journey!
- 1,208 replies
- great republic
- clipper
For half or quarter round parts, have you considered gluing up pieces, turning them, then dissolving the glue in a suitable solvent? Then there is no kerf to consider or waste.
Basic but Good kit recommendations for granddaughter and I
druxey replied to glbarlow's topic in Wood ship model kits
Check out Model Expo (Model Shipways) Lowell dory kit. -
Would 'painting' the nailheads be easier with a brown fine-tip Pigma marker pen? The wood effect looks really great, Clare!
- 175 replies
- hanse kogge
- shipyard
There is quite a bit of discussion of the colors used on French ships in The Color Blue in Historic Shipbuilding by Joachim Müllerschön Originally in German, titled Die Farbe Blau im historischen Schiffbau: von der Antike bis zur Neuzeit. Full disclosure: I was the translation editor.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Galilee's Rabbet
druxey replied to CDR_Ret's topic in Building, Framing, Planking and plating a ships hull and deck
It seems very atypical the way it was drafted. I'd concur with Mr. Cleek. And wrestling a 6" thick plank bow and stern would be a mighty task: it would have to be tapered in thickness. -
Casting detail with lead-free pewter is improved by dusting the mold with talcum powder first. Also have sufficient weight of metal in the gunhead so that the mold is well-filled. (The full size cannon were cast this way.) Don't forget the air escape vents!
That row of stern lights came out really nicely!
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Interesting use of tape for drawing smooth curves on a curved surface! Had you considered thread and dilute white glue instead of tape to line out on the model? As for gun deck planking, you are master shipwright. As long as you plank in the spirit of the Falconer engraving, no-one will be able to fault you.
Contraband smuggled in by HM boats? Whose side were they on?
Curse those typographical shags!!!!
