Everything posted by druxey
Tony: I was recommended this site by a friend recently, and now I'm hooked and visiting each day's new post. There's some other fascinating stuff on there - over ten years' worth!
There is a wonderful website about central London where new entries are posted daily. Here is today's entry (25th March): https://spitalfieldslife.com/2020/03/25/samuel-pepys-at-st-olaves-x/
As we undergo shut-downs, reading will become more important to us. If you are interested in the Restoration naval period or that of the Dutch Seven Provinces, this book is worthy of your attention. This is a very readable, exhaustive narrative and analysis of the longest engagement between two navies recorded. Mr. Fox has an extensive grasp of the political, social, economic and strategic issues that led up to and culminated in this North Sea struggle for maritime dominance between The Seven Provinces and Britain. The prelude to, development and aftermath of this marathon battle is well illustrated with fleet movement maps. The narrative is accompanied by contemporary drawings and paintings. There are also extensive end-notes and appendices on fleet lists, deployment and armament. An engrossing read and thoroughly recommended, available on-line through Seaforth Publishing, paperback, 2018.
And those Staedler technical pens of various line widths (hollow tubes with wire) that always clogged when you least needed them to! And don't get me started on Letraset and Linotype machines....
I suggest that you cut tiny pieces of solder, attach them to the joint with flux, then heat up the joint indirectly with the soldering tip a few mm away from the joint until the solder flows. Much less clean-up! Or use epoxy instead.
If you use acrylic gesso, it carves and sands nicely when dry. Great progress!
- 2,696 replies
- heller
- soleil royal
(and 9 more)
Brilliant work! I've just been reading Frank Fox' book The Four Days' Battle 1666, and your model photos brings this to life.
- 1,035 replies
- royal katherine
- ship of the line
The overall effect of your model is lovely: I'm expecting someone to walk over and climb aboard! Congratualtions on an outstanding result, Geert.
Sorry, you are quite correct, Chris. That's who I was thinking of! I remembered incorrectly. Bad memory! Bad!
In this new self-isolating world, we ship model-makers are the lucky ones. We at least have somethign productive to do. Although a nice pint of draught.... Fabulous detail work as ever, Keith.
Welcome! If memory serves me correctly, there's another ship modeler in Yellowknife.
Can you cast a few master figures in the rough and then complete them individually? Impressive work on the tholes using hand-held equipment only.
Garboard plank
druxey replied to Sheerline's topic in Planking Techniques's Click Here for Topics dedicated to planking!!!!
One, you are correct in not letting the garboard creep up the stem. Two, you seem to have a good fit to the rabbet in picture two. I recommend that the curve on the edge that abuts the second strake be make more gradual before spiling and fitting the second strake. Starting the curve as far back as the right edge of the photo should be about right. -
Help evaluating old model of screw steamer USS BROOKLYN
druxey replied to Cono's topic in New member Introductions
Good assessment, Eric. -
Nice to see the end in sight, Rob. It's been quite a journey!
- 1,208 replies
- great republic
- clipper
For half or quarter round parts, have you considered gluing up pieces, turning them, then dissolving the glue in a suitable solvent? Then there is no kerf to consider or waste.
Basic but Good kit recommendations for granddaughter and I
druxey replied to glbarlow's topic in Wood ship model kits
Check out Model Expo (Model Shipways) Lowell dory kit. -
Would 'painting' the nailheads be easier with a brown fine-tip Pigma marker pen? The wood effect looks really great, Clare!
- 175 replies
- hanse kogge
- shipyard
There is quite a bit of discussion of the colors used on French ships in The Color Blue in Historic Shipbuilding by Joachim Müllerschön Originally in German, titled Die Farbe Blau im historischen Schiffbau: von der Antike bis zur Neuzeit. Full disclosure: I was the translation editor.
- 2,696 replies
- heller
- soleil royal
(and 9 more)
