Everything posted by druxey
Mark P: I'm interested as to why you think that the stop was not a separate piece when Steel spec's it as such. (He does not call for a rebate to be cut into the frame.) My reasoning for the frames being 1" greater sided on the sides of the ports is for extra strength when driving and fixing the ringbolts for the breeching and gun tackle.
Interesting. I believe that access to the magazine was by a passage with two separate doors that opened outward. This was a precaution against accidental sparks or detonation from outside blowing in. The doors would blow shut in such an event. Direct access from above via a companion ladder would be very dangerous!
Longridge's Midget Universal Woodworking Machine
druxey replied to SJSoane's topic in Modeling tools and Workshop Equipment
Thank you, Mark. Since I first read Longridge back in 1955, I'd always wondered what the 'Midget Universal' was like! Your post and link made me smile this morning. Thank you! -
Impressive at all scales! I imagine the car runs beautifully as well.
- 1,035 replies
- royal katherine
- ship of the line
Siggi: in the tables, Folio XXV and XXVI, it states: Port lids. - Every gun deck port to be fitted with a substantial lid made of English oak - Stops of the ports not less than (measurement in table 3 1/2" or 3". Well seasoned linings fitted into the stops (measurement in table thickness 1 1/4" to 1") Fitted into the stops implies that the linings overlap, not abut, the stops. I've certainly shown this - rightly or wrongly - in my own models.
HMS VICTORY 1765 by albert - 1/48
druxey replied to albert's topic in - Build logs for subjects built 1751 - 1800
'Cant frames' in English. Those look very nicely made. Only a few more needed! -
A very interesting form of construction, nicely executed as usual, Dick.
- 263 replies
- nave tonda
- round ship
HMCSS Victoria 1855 by BANYAN - 1:72
druxey replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
And a happy festive season to you also, Pat!- 1,005 replies
- gun dispatch vessel
- victoria
Well, obviously the limit is because of the tools available, not the skill of the model-maker! Perhaps Santa will be kind....
Gunshot proof, no; but weather/waterproof, yes! Certainly Steel (British, 1805) describes the rabbeted style of port lid clearly. Either way, you are building a very lovely model.
The thing is, in different countries and at different time periods the way things were done were not always the same. Also, secondary sources (modern books and models) can be misleading. Check contemporary models on sites such as: http://collections.rmg.co.uk/
The inner layer of lid planking (the lining) is vertical and the outer layer follows the line of the outer hull planks in thickness. The inner layer is stepped back or rebated by the thickness of the port stops. The stops are the lining pieces attached to the lower port sill and frames on the sides of the port opening. They are set back by the thickness of the outer planking. Your photo shows these rebates clearly. There is no taper as shown in your sketch.
