Everything posted by druxey
What an interesting concept! I've not seen this tried before. In your mock-up I find the mesh of the material distracting, as opposed to your white thread outline. Have you looked in fabric stores for very fine nylon lawn material? It is translucent and had a very fine weave. I have some (for other purposes) in a pale neutral grey color.
This is interesting stuff, Louie! Would the bulwarks on the xylocastra be closed? I'm thinking of windage. Professor Pryor's interpretation of their location and your mock-up seem logical.
Inverted knees are called standards. They were usually used only on large English ships back then. Lovely neat work and explanations of your techniques, Clare.
Echo by davec - FINISHED - cross-section
druxey replied to davec's topic in - Build logs for subjects built 1751 - 1800
That's a nice well and shot locker you've made, Dave.- 127 replies
A Lorch Micro-Mill that never was ...
druxey replied to wefalck's topic in Modeling tools and Workshop Equipment
Beautifully machined, Wefalck! -
Model Machines Disc Sander for sale
druxey replied to Byrnes Model Machines's topic in Modeling tools and Workshop Equipment
I agree with Jim: Greg is very hard on his machine tools!! Thanks for the donation, though, Greg. The new owner will have a machine with a provenance, checkered history and having belonged to a former Famous Owner. -
That is very realistic indeed. I'm just waiting for someone to emerge from the wheelhouse. Well done, Mehmet!
Glue should be fine: pin them and it adds complexity to removing the supports later. Great progress, Maurys!
- 525 replies
- anchor hoy
- hoy
Airbrush
druxey replied to Mike Dowling's topic in Painting, finishing and weathering products and techniques
I agree with Kurt and company: surgical cleanliness is the key! A different style of airbrush that is less fussy than the traditional design with a long needle is the Aztec. It has short screw-on cartridge style heads that are easy to remove and clean. No more bent needle tips! -
I have issues with accuracy of the AOTS. This is an example. That chain would not stay in that position as taken around the 'wrong' sides of the timberheads! Assuming the ends were hooked and secured to ringbolts inboard, the chain should still be passed around the other sides of the timberheads. I would rely more on Harland and use a line or cablet hitched around the same timberheads.
I agree with almost of what you've written, Chuck. However, I smiled as we all have different tastes in brush choice! I think everyone should experiment to see what round, flat and filbert brushes can or cannot do. One additional point: not only use your pinky for control, but control your breathing as well when 'cutting in' to an edge.
- 269 replies
- Queen Anne Barge
- Syren Ship Model Company
One way of protecting the stern timbering is to attach one (or more) battens across them as a temporary measure. Also don't make any sudden reaching over moves and wear short sleeves!
- 525 replies
- anchor hoy
- hoy
And you have another follower here, Clare! Looks like a great start to your build. Small point: the chequerboard was a painted canvas floorcloth, not actual parquet. Looking forward to seeing your progress.
Steamboats and other rivercraft - general discussion
druxey replied to Cathead's topic in Nautical/Naval History
Mark: We are discussing fixed buckets or blades here, rather than the feathering type. And yes, the trapping of air in the sponson is what I was speculating on.- 281 replies
- Steamboats
- riverboats
(and 3 more)
Anyone care to comment on the air pressure idea?- 281 replies
- Steamboats
- riverboats
(and 3 more)
I use 1000 and 4000. If an edge should get a nick, I might use something coarser to get the worst ground off. If you sharpen properly with a micro-bevel on the edge, all you need to do is a few strokes on the 4000 grit to get the tool back to A1 shape.
- 525 replies
- anchor hoy
- hoy
Thinking things through: Some bits about the bitts
druxey replied to dafi's topic in Masting, rigging and sails
Uh...sure, Jud! Usually the height of the crosspiece above the deck (plank) was in the order of 19" to 20"(mizen) 21" (main) to the underside. The height of the bitt pins above deck: 2' 11" (mizen), 3' 7" (main). Hope this is a helpful guide.
