Posts posted by druxey
That second photograph (https://blog.firedra...015/01/7531.jpg) should answer your own question, Siggi. Thanks for the link: that particular image hadn't turned up for me when I searched.
Time for a small update. The cabin floor was made in the same way as that for the forward section of the footwaling. In this case the wood was left 'bright' and the joints slightly enhanced using pencil lead. The finish was dilute sanding sealer. The footwaling aft of the cabin will be installed at a higher level, with a small scuttle for access. Some pattern-making will first be required, though.
- mtaylor, AnobiumPunctatum, dvm27 and 27 others
30
I'm sure that there would have been battens of some sort to support the footwaling plank ends in the actual boat, Carl and Joel. As these would be hidden (as are the floor/futtock joints), I omitted them.
Thanks, everyone, for your continued interest and likes.
The footwaling is now complete, after making a false start. I initially tried cutting and bevelling each board to length in situ. The result, as you can see, was not pretty. Having thought things through, I then made a card template which was used to actually attach the boards to. When complete, I channelled out the card so that the boards would sit at the correct height on the keelson, then glued the assembly in. This gave a much improved result.
- steamschooner, Mahuna, AON and 29 others
32
Thanks, Gerhard. I've already seen all those images. The Greenwich Hospital barge is not as elaborate - thank goodness!
- Gerhardvienna, Canute and mtaylor
3
So, back to work. I cut strips of footwaling to scale size, then cut a trial piece. This is exactly 4' 0" long, whether by design or coincidence I'm not sure. The actual footwaling will be painted a subdued maroon color, rather than the bright red of ships' bulwarks. There is evidence of this in paintings as well as on the state barge of Charles II, although this boat is obviously earlier and has been heavily restored.
Both back as well as bevel should be mirror-like. Check out the sharpening system ('Stone pond') and jig that Lee Valley has. This makes sharpening much easier than you might think.
- Canute, paulsutcliffe, mtaylor and 2 others
5
Yes, that's more-or-less my 'take' on it as well, Paul. However, the floorboards rest on the keelson and their outer ends against the frames. I had already mentioned ZAZ7154 in post #177, a useful reference.
Joel: my carving proficiency will never equal that of Mr. Gibbons!
Carl: I hope you found the reference with help from Endlesshunt.
- cog, paulsutcliffe, Canute and 1 other
4
Paul: I have found a useful photograph of the inside of Prince Frederick's barge (copyright, so cannot show it here) that confirms athwartship boards. These appear to be about 8" to 10" wide and painted red. There are also moveable vertical footboards for the rowers - a detail I've never seen or noticed before in small boat models. I was wondering if there were turned supporting pillars under the thwarts and indeed there are. All these will keep me busy for a while!
Yes: the back of the chisel should be honed to a polished finish. The reflection of the wood gives you a guide as to when your chisel is vertical. Don't try to chop off thick slices this way: if you do, the edge will tend to move as you cut through the wood leaving an angled cut. Thin slices, please!
- mtaylor, michael mott, Stuntflyer and 3 others
6
Thanks for the comments, gentlemen. Now I'm back, it's time to begin fitting out. The first item will be the footwaling (the floorboards). These were laid athwartships rather than longitudinally, according to the specifications for a different ceremonial barge of this period (ZAZ7154).
Gerhard: the planking is 1/64" thick, or a scale ¾".
Well, you are learning a lot in a short time, Louie! It's good to think out your strategies several steps ahead....
- CaptainSteve, Canute and mtaylor
3
Greenwich Hospital barge of 1832 by druxey - FINISHED - 1:48 scale
in - Build logs for subjects built 1801 - 1850
Thanks, Siggi, for your helpful contribution.
