Everything posted by druxey
Chris: it's very similar to Endeavour. However, I'm sure every shipyard had slightly different methods of planking. I'm also sure that no more stealers or drop planks were arranged than were absolutely necessary, saving much work.
- 15 replies
- Steelers
- drop planks
You see this technique on 18th century museum models such as seen in Annapolis or (formerly) Greenwich, Mark.
- 15 replies
- Steelers
- drop planks
Here is a photo of that bluff bow completely planked. Two hooked strakes under the main wale was all that was needed!
- 15 replies
- Steelers
- drop planks
The example you cite, Captain Jerry, is a rather excessive one. It is the result of allowing the garboard strake run too high up the stem, forcing the other strakes to be too crowded into the stem. This could easily have been avoided by an experienced shipwright. Take a look at the example in 'A primer on planking' by David Antscherl pinned on this site. The bow is just as bluff as the one in your photo, but compare the run of planking in both examples.
- 15 replies
- Steelers
- drop planks
THE 74-GUN SHIP by Jeronimo
druxey replied to Jeronimo's topic in - Build logs for subjects built 1751 - 1800
Very, very nice so far, Karl!- 194 replies
I agree: Taking time to plan and draw the planking layout and shift of butts is never a waste of time! It will save grief later on.
- 1,051 replies
- cheerful
- Syren Ship Model Company
If that is where those timberheads are located, the way you have done it is very convincing. Well done!
- 102 replies
An additional hint: once I have a strake of planking laid, I run a sanding stick along the edge of it to ensure it is even and lines up with my mark-out before proceeding with the next strake.
You forgot, Dan? Forgot???? And after all your work to make the lantern.... That's funny. Glad it all worked out for you, though.
Had you considered making master patterns and casting all those units?
- 2,625 replies
- kaiser wilhelm der grosse
- passenger steamer
Echo by Maury S - FINISHED - Cross-Section
druxey replied to Maury S's topic in - Build logs for subjects built 1751 - 1800
And take a lot less time, Dan!- 324 replies
3D printer at Home Depot
druxey replied to twintrow's topic in CAD and 3D Modelling/Drafting Plans with Software
Think Commodore 64.... -
Coming along nicely, Mark. Try to resist doing too much sanding until planking is complete. What do you mean by '3" off'? Do you mean creep or cumulative error compared to your lining off of the planking runs? You can easily correct this by either making remaining strakes fractionally wider or narrower to compensate. Just don't let this become a big issue when it comes down to the last strake!
All the best with the move, Ben. We will await your return with bated breath....
- 889 replies
You forgot, Gaetan? Please remember next time!
- 728 replies
- le fleuron
- 64 gun
Just catching up with your log, John. She's looking lovely.
- 745 replies
- francis pritt
- mission ship
Tiny fake nails/nail heads
druxey replied to Landlocked123's topic in Metal Work, Soldering and Metal Fittings
Technique is great, Popeye, but I'd be wary of using ferrous metal in a model. It can rust under certain conditions. Brass or copper are better choices. -
Christian: The old-timers used both methods to get the timberheads in the positions that they needed them. As master shipwright, you need to make those decisions based on what makes the most practical sense.
- 102 replies
Check out Scale Hardware as Mark suggests. -
Very nicely done, Nils. However, I find the rivet heads 'read' a bit too prominently. Perhaps it's the fact that they are reflective at the moment?
- 2,625 replies
- passenger steamer
