Everything posted by druxey
A slitting saw blade on a table saw. Heat-softening the brass first and some wax while cutting will help. Mounting the brass on a sacrificial wood backing will also ease the job.
- 1,126 replies
Welcome aboard indeed! 31 years so far on your model? Good things take time.
No, you are not having a senior moment! It would be difficult to do, as only the 'dead flat' in the end-on elevation drawing is given. Yes, you have the sheer (in elevation) and half-breadth (in plan) as well, but that tells you nothing about the changing sectional shapes. They may be inferred from the planking runs - if accurately drawn - but that is a s much as one can squeeze out of that plan. Perhaps a similar lifeboat drawing that has the station sections might help.
Impresssive woudld be an understatement, Rob. Wow!
- 3,560 replies
- clipper
- hull model
Excellent! Could not see them in the other photo. Glad you included these.
- 542 replies
- Sphinx
- Vanguard Models
(and 3 more)
Coming along nicely, Ron. Will the spritsail have water drainage holes added?
- 542 replies
- Sphinx
- Vanguard Models
(and 3 more)
That's the general idea, Toni. There would also be sacrificial blocks of wood on the rail to protect it. However, there is one drawback: it would be tricky to get the anchor past the fore channel, deadeyes and laniards. I think that the chain would be secured to an eyebolt inside the bulwark with a hook on the 'free' end that engages a second eyebolt inside. Call in the Time Machine to be really sure!
Nice castings and finish, Toni! There may well have been a shankpainter chain used to secure the anchor, rather than the anchor lovingly hugging the swivel mount. It would be about in line with the aft end of the billboard/lining. This would raise the anchor shank parallel to the rail and the stock should then clear the water.
Welcome, Jack, from another Ontarian.
While your clamping process will work, I still prefer a plaster outer jacket for stability of the mold - especially during a 'pour'!
There are two versions of this book. The earlier edition gives both French and Dutch practice as well as English, but the later one covers only English rigging.
- 2,696 replies
- heller
- soleil royal
(and 9 more)
Do read (or re-read) the planking primers on this site! They explain and show you how to do this really well.
- 20 replies
- Planking
- Lining out
