Everything posted by druxey
Looking terrific! Again, it's hard to believe the detail at the scale you are building this model to.
Planking glues
druxey replied to ChiefCarr's topic in Building, Framing, Planking and plating a ships hull and deck
Rubber cement is not, alas a permanent adhesive. It may last several years, but.... There are a range of options, but I use white (polyvinyl acetate) glue for most wood applications in model-making. Others may have other preferences, but I'd also avoid cyanoacrylate (crazy) glues. -
Practice makes perfect! Your model is looking very neat and good.
- 90 replies
- Model Shipways
- muscongus bay lobster smack
Welcome aboard, Jim!
That's true. In 18th century naval documents one comes across 'Sailing qualities'. These were printed forms that were filled out by the captain. One question asked for the best sailing trim of the ship, and the response gave the draught of water both fore and aft.
The depth marks were each 6" high and 6" apart, so you could eyeball the waterline to within an inch or so. The base of each number was the depth in feet. I believe that they were either carved in and painted (late 1700's and early 1800's) or cut from lead (pre copper plating days!), then of copper thereafter.
That is superb, Valeriy! How did you manage to cut the glass lens to shape? Or did you grind it?
A sanding of the first coat of primer will show up any minor defects, as you've found out, but the final primer coat should not need sanding. Your hull is looking very good now.
- 146 replies
- Harriet Lane
- Model Shipways
Would this be an example of Cunningham's reefing topsail? See: https://www.rmg.co.uk/collections/objects/rmgc-object-68645
Echo by tlevine - FINISHED - Cross-Section
druxey replied to tlevine's topic in - Build logs for subjects built 1751 - 1800
Very nicely done, Toni! Does this wrap up the project?- 52 replies
You are climbing the learning curve now! Did you heat soften the brass before trying to drill it?
- 90 replies
- Model Shipways
