Posts posted by vaddoc
Many thanks to all for your comments and likes.
Now, there has been some more progress, and then things went pear shaped.
First I finished the rabbet at the keel. It came out fine I think and actually seems to be quite forgiving in regards to the angle the garboard will have. I was very careful to preserve the straightness of the rabet line. At the stern, a lot of wood had to be removed, this job was done relatively easily with sharp chisels.
Next it was time to fit the frames on the keel and see the shape of the boat for the first time. Something did not look right but of course the frames would not stay in place.
The most accurate way to positions the frames is upside down as the vertical projections from the sheer extend to the same horizontal level quite accurately. However, the frames are not rigid at all and some are a bit warped. Best thing to do is to accurately secure them to the top view pattern of the boat. I used little pieces of beech from strips that were too warped to be used in the model. I used initially Pritt stick to glue into position and then 1 mm screws.
Then I tried to put everything together but things really didn't want to work together. Every piece seemed to belong to a different boat...
After a lot of sanding-fitting-sanding-fitting, the whole thing came together.
Now it was time to check the bevels and the fairness of the planking. Midships and towards the stern, the bevels look ok. Towards the bow, the bevels on some frames look a bit too acute but should not be too big a problem. However, frames 2 and 3 seem too narrow and really wrong.
Now, if these frames are indeed correct and it is just the shape of the hull, the planks going over frame 1 would actually never meet the rabet at the stem.
Something is very wrong. I went back to CAD. Now, there was a small ripple on the hull surface near the bow which I thought was not important so did not bother to correct
Just to check, I quickly fixed it and then compared the difference in frame shape at position 2.
Oh dear...
I suspect frames 2 and 3 are about 2 mm to narrow.
So now I need to go back to CAD and redo frames 2 and 3, possibly also frame 1 and 4, but leaving the rest unchanged.
Hopefully this is going to work, otherwise I ll need to make all the frames again. If this is needed though, I ll make them out of beech. Actually I have half a mind to just go for it, we ll see.
It is freezing cold in Cambridgeshire, there is Covid all around and most of my work commitments have been cancelled. I should be able to do some work and get some control over the situation.
Regards
Vaddoc
- bruce d, FriedClams, BobG and 3 others
6
Very nice Hakan! Seems to carry a lot of sails too. Yes, I would think maintenance should keep you busy year round!
Back to your model, you still have 9 planks to squeeze in your bow and stern. This second plank looks a bit wide but maybe it is the angle of the photo. Very interested to see how it will turn out, as I have two boats almost ready to be planked-one carvel, the other clinker.
Vaddoc
This is a good start Hakan. The 2 planks look good, I think you are planning for 9 planks a side. Interesting to see how they ll run.
By the way, our aging eyes have trouble distinguishing ' from " in a 14 inch laptop, "blue water" though we did get! Come on, show us the boat!
Regards
EG
I was hoping you 'd pick this up again Hakan! Have fun building your model, I ll be watching from the back rows.
Vaddoc
What a wonderful model! Regrettably I ve only been able to visit GL. Excellent job with the planking and rabets. Actually, top job with everything. Clearly you 're having a lot of fun!
Could you explain how you stained the wood? It came out very good.
Merry Christmas and a happy new Year!
Vaddoc
A bit of progress so time for another update.
I have not been able to work much and have not taken as many or as good photos as I could. I bought a few more chisels, two Narex 6 and 3 mm and a 3mm Ashley Isles V chisel. I really enjoy using the Narex chisels, they seem to get sharper and hold their edge better than the Aldi chisels I ve used. The Ashley isles seems very good as well, actually it arrived honed and ready to use!
I also made a new honing guide and a jig to maintain the honing angle. Very easy to make with scrap material but it is essential to use a drill press to make sure everything is parallel and horizontal. The guide functions very well but I did not take a picture-will do and post it.
Back on the boat I finished the bevels in all frames. Using an 8 mm Aldi chisel this job was actually quick, easy and accurate. I spend some time to hone it razor sharp but I found that even on the soft plywood, I had to use the strop very often. I ordered one from Narex.
I regretted using plywood for the frames very much. It is very soft and it seems to have internal stresses because it bends and changes its dimensions after cut to shape. The reason I used plywood was cost and also because it will be completely hidden. Never again.
Now, at this stage I need to think carefully before doing anything to make sure I don't mess things up, the various tasks need to be completed in a specific order. So, first I need to cut the rabet at the keel, deadwood and stem.
I made the first cut at frame 11, it came out very well.
However, then I realised that the keel is not horizontal but sloped and that the frames are vertical but at an angle to the keel. So I made a kind of base to keep the keel at its correct angle. I used scrap hardboard I found in the garage, it came out fine and does the job.
I then cut the rabet at frames 10 and 9. I used chisels taking it slowly and checking constantly. So far I am very happy with the outcome, the rabet is coming out much better than in the Yawl.
Next:
Complete the rabet
Attach the deadwood and stem
Deal with the frames to strengthen, straighten, arrange in the jig and somehow attach to the keel
Merry Christmas and a great new year to all!
Vaddoc
- FriedClams, mtaylor, GrandpaPhil and 5 others
8
Very nice work Brian! I ll bet on black (for the bottom colour).
Your log is very interesting, looking forward for the rest of this journey.
Have a wonderful Christmas and a happy new year!
Vaddoc
- mtaylor, Canute, Keith Black and 1 other
4
Gary, echoing the other comments, a wonderful model. Fantastic work and a very inspiring log all together.
Vaddoc
- mtaylor, Keith Black and FriedClams
3
Yes, I use a strop and green compound too. Brings the metal to a mirror shine and a few passes, when the chisel shows reluctance to cut wood with ease, restores the edge. To save time I strop freehand.
I am no woodworker but I am slowly appreciate how accurate tool a well sharpened chisel can be. There is a learning curve in using a chisel and much more so in honing a chisel.
The first chisels I got were from Aldi, the ones that chap Sellers says are brilliant. They do the job I must say. However, I got a 4 mm Narex which I ve always thought was better.
Two days ago I received a couple more of the Narex chisels, a 3 mm and a 6 mm. I spend a bit of time honing them and used them today. My impression is they are easier to hone, they get sharper and they hold the edge longer than the Aldis, overall a better tool but the difference is not massive. I may just be imaging things though. In any case, I just ordered an 8 mm one.
I believe that all modern branded chisels have good enough steel. However, to maintain a razor sharp edge, a chisel needs constant honing and from time to time reshaping. This part is I think even more important than the quality of steel. Honing stones in various grits, a honing guide and a jig to allow the chisel to be positioned always at the same angle on the honing guide is needed.
Get the Narex, you will not regret I think and very good value for money.
I also have an expensive Ashley Isles V chisel but have not used it yet
Hope this is helpful
Vaddoc
On 12/8/2020 at 12:10 AM, KeithAug said:
I have wondered about that tool for a while, but never taken the plunge. I’ll be interested to see how it works out.
Keith, it did not work at all. The size of the tool is fine and it is powerful enough. I think the problem is the small length of the stroke.
To remove material, 100 grit or less is needed. The size of the sandpaper particles at this grit is large. The head of the pen sander vibrates around 3 mm (or so), not enough to effectively sand and remove material. I experimented a bit but it is simply the wrong tool for the job. At least I did not have to pay for it as I used some Amazon gift vouchers I was given.
I now carefully chisel the bevels (and occasionally my fingers). Power tools are too aggressive and files end up rounding the bevels. Not easy!
Regards
EG
- bruce d, FriedClams and mtaylor
2
1
A quick update
The keel has come a long way but of course there is more work needed. It is not glued together yet, I need to think how best to do it.
Shaping the inner bevels of the frames is proving to be a difficult and very time consuming job. It would be nice to have some kind of power tool, small enough to fit in and be controllable but also powerful enough to sand away the 6 mm plywood. I bought the Proxon pencil sander, it hope it will make the task easier but really I do not have high hopes. I will report when it arrives.
- FriedClams, KeithAug, bruce d and 4 others
7
Also check Arkowood. They seem to select the timber they send out quite well.
I love beech. It is hard and tough, holds an edge, glues well, sands well, bends fantastically well. Good for frames, planks, keel. Does not split like walnut. I am going to plank two boats at 1:10 scale with it. I like it looks and colour although the pattern is quite prominent.
A couple of things though. The wood pattern depends how it is cut, can be elegant little dots (usually) or wide spots (not very nice). Also, wood seems to vary from tree to tree (I know, big surprise here...) I received some beech recently that seems much harder than wood I bought in the past.
If you like the looks go for it.
At your own pace Phil 😁
The wood (in your case paper) is patient, so are we.
- SIDEWAYS SAM, mtaylor, GrandpaPhil and 1 other
4
Bob many thanks, indeed this progress is pretty fast for my standards
Keith and Allan, Fanta Zero Sugar is one of those little pleasures that make life meaningful!
Now, I stole a few moments to spend in the shipyard. I tidied up a bit and then did a tiny bit of work.
The frames are underway, so I wanted to start work on the keel, stem and deadwood/stern. These will be partly visible and furthermore the rabet will need to be curved, so they cannot be made from plywood. Even if I end up painting the boat (quite possible), they still need to be made from wood. I chose to use pear, mostly because I forgot I also had beech which is much cheaper.
Now, I have 2 sheets of pear to choose from, a lighter shade and one with the usual darker pear wood colour. I chose to use the lighter one because it was dead straight and flat, whereas the darker one was slightly warped and cupped. Shame really, lovely wood
The sheet is supposed to be 8mm but it is actually 8.5, no harm done though, I ll just sand the notches on the frames a bit more.
Now, this is the keel and the top view of all the frames
For the stern and dead view, I have the option of either building it up from pieces exactly as the plans show, or doing it en block, from the same 8 mm sheet. The first option is too complex and I am already cutting corners with this boat with the plywood frames. Makes sense to make it one piece
These are the patterns for the stem and knee, again from 8 mm sheet
This are the side views patterns for the bow and stern, will help to make sure all are in roughly the correct position
I managed to cut the keel straight but then I was summoned in the house. It will probably be a while before I can do any more work
Take care
Vaddoc
- BobG, KeithAug, GrandpaPhil and 4 others
7
I think another update is in order.
Box, many thanks but actually the frames on the photo were roughly cut , they were later finished to the exact pattern.
Keith, it was actually very easy to glue the mirror pattern on the back. I am pretty sure there are already significant tolerances in the build, a bit more to the left or to the right will make no difference I think!
I just managed to scrape a few moments here and there to work on the boat. I first finished all the frames to the exact pattern using the disc sander and mostly diamond files, which remove a lot of wood quickly. This took a while as the plywood at 6 mm is pretty thick.
Then, I printed mirror patterns for all frames and with scissors cut the outline. Then I simply glued the frames to the back of the pattern. It actually worked pretty well.
I could not resist aligning the frames, nice curves I must say... The straight parts that ruin the poetry will later be cut off, they are there just to help to set up the frames.
However, this was the easier part. I now need to cut the bevels, both for the outer and the inner planking. This is pretty challenging.
The diamond files are not useful here. The disc sander is far too aggressive and far too large. What actually made the task easier was to attach round sand paper to the Dremel. I like this trick, it sands not too aggressively but also is flexible and can fit in tight spaces.
A mountain of work left, I ve only sanded the bevels for two frames.
I also printed the patterns for the keel and stem. I think I will cut the deadwood en block instead of building it up.
I am not 100% certain how the boat will be assembled, probably the right side up as the frames will be permanent so need to somehow be well attached to the keel. We ll see.
Regards
Vaddoc
- bruce d, G.L., GrandpaPhil and 5 others
8
Do not worry. The smoother the better. You will not regret the work you put in preparing the surface for paint. The primer magnifies faults 10 times, the paint a hundred.
0000 wool is something like 400-600 grit I would think. No issues, both acrylics and enamels will love your smooth primed surface.
Now, I need to correct a couple of mistakes.
The actual frame count is 16 as No 17 would be the transom. Furthermore, there only 14 frames in the above arrangement as somehow I missed two!
In any case, the templates have been glued to the 6 mm plywood sheet. This is very thick plywood bought from Cornwall models, it is very good quality with no voids, it reminds me of marine plywood although the wood is soft birch. The little Dremel Motosaw is actually doing a pretty good job and is cutting the plywood with relative ease. The frames at 6 mm thick I think will be sturdy enough for the job.
All frames will need to be finished to the exact lines. Then, somehow a mirror paper pattern will need to accurately be glued to the other side to allow for the inner bevel to be cut.
There is a lot of cutting and finishing to be done though!
- Boxbuilds, mtaylor, bdgiantman2 and 7 others
10
Dear all, many thanks for your comments and likes. Unfortunately It took me a while to come back to my log as life has gone into hyperdrive again.
All the frames are now in place and strengthened with pieces of wood. The boat is ready to be planked! However, I will temporarily hold the build and concentrate bringing the Launch to the same point. I think it will be interesting, these two boats are completely different in shape and I am curious how the planking arrangement will compare.
A few final photos, the log will continue with the (clinker) planking, provided I will manage to get the 2 mm beech planks to bend.
- Bedford, GrandpaPhil, bruce d and 3 others
6
21' Fisherman's Launch by vaddoc - FINISHED - Scale 1:10 - Plans from Howard Chapelle's "Boatbuilding"
Ok, I think it is done
Next photo shows the new surface and how off frame 2 and to a lesser degree frame 3 was. I had to keep frame 1 as removing it I was getting a very wrong surface and I am absolutely not keen to re-loft the boat. I hope it will be fine, bit of sanding, bit of shimming...
This are the new frame templates ready to be glued to the nasty plywood.
This does not mean the hull will be fair, the frames need to be replaced and fairness to be rechecked with a batten
Regards
Vaddoc
