mtaylor
Moderators
Everything posted by mtaylor
  1. I empathize with you, Lou. When Janet was teaching, I was her IT guy and sorting out stupid stuff with college IT department was part of it. Very stressful and not always satisfying to say the least. I daresay you have your priorities right... we'll just have to be patient until real life gets sorted out.
  2. We'll need a bit of data to answer your question... such as who made the kit?
  3. Welcome to MSW. I see you're off and running with questions in the Research area.
  4. If it's cherry, why not just varnish it? Cherry does darken with age. I've done that on two models and looks great to my eye. But then, I might be prejudiced.
  5. It looks like a jig for making rope coils. Unless I'm wrong, You catch the end between "B" and "C". Secure with "A" then wrap the coils around "C". The separate parts shown look to be a variable for different size rope and coils. Pretty ingenious to my eyes and probably wouldn't be all that hard to make.
  6. Ok... that's not an uncommon problem as rigging is one of the dark arts. Here's the way I'd do it, others my have different ideas as there's a lot of ways to skin a cat. 1) Mount the lower deadeyes. 2) Take a piece of brass or wire that will fit through the holes in the dead eyes. Bend in a "u" shape such that when the jig is inserted into the lower deadeye and the upper deadeye, they are spaced properly. 3) Run the shroud. Note that where the shroud wraps around thee mast, it should be seized do there's a loop. Being the line down, through the next deadeye (using the jig to space it). And then seize that deadeye. 4) Repeat step for for the first two deadeyes on the other side of the ship. 5) Just add to each side, one at a time, back and forth so as not to put stress on the mast and bend it. I hope this helps. You might take a look at some of the build logs to see how they do it.
  7. I hope your parents get through the self-imposed quarantine without any problems. Scary times these are.
  8. There's also a quick find index for kits:
  9. Wonderful work on this build. The black background sets it off perfectly.
  10. You don't have to declare when you return home?
  11. Well, I can't see it either so Keith I have a feeling that's going to be two us feeling stupid.
  12. As far as rigging her, can you get her out of the workshop if there's masts in place? Beautiful work.
  13. Sails will also hide a lot of the detail of the interior. Maybe reefed or partially reefed so the interior is visable?
  14. It was a privateer... maybe some English soul with a desire for profit?
  15. Welcome to MSW. I hope Amati can help you.
  16. Welcome to MSW. When you're ready, feel free to start a build log. Instructions are pinned in both the Kits and Scratch build areas.
  17. You're right... don't sweat the first layer as it will be sanded smooth. For the final planking, see the planking tutorials here: https://modelshipworld.com/forum/14-building-framing-planking-and-plating-a-ships-hull-and-deck/ They're all slightly different so look them over and figure out which one will work for you. There's also one in the database here: http://modelshipworldforum.com/ship-model-framing-and-planking-articles.php for a simplified method. Have a look at the builds I mentioned up above and you'll get a good idea as both did an excellent job of planking. I got to thinking about the gun problem and the covered gun deck. One solution if you don't want to take off the deck you have built is to install the guns through the gun ports from the outside. It'll be fiddly and you'll probably have to install the carriages first then put the guns on afterward. I hope this helps.
  18. Well, after getting sidetracked by the helicopter build and fiddling with air cleaners... I've been sanding and shaping the port side of the hull. I will need some touch up on both sides before planking, maybe a bit of filler here and there and final sanding. However, I still need to shape and smooth both sides of the bow. I saved this part for last thinking everything before leads to here. Hopefully, I'll get it sanded by next week. I'm going slow and cautiously. I'm also using templates to check that both sides are the same. Tedious, but must be done. Here's the proof of life photos of the port side.
  19. I agree with Bob... get some bits of brass or even copper wire and practice. There is a learning curve but it's not a steep one.
  20. They still do that. They and Chinese. Both countries have had "issues" with copying American jets as the engine metal technology is behind the curve.
  21. Hi Marco, Welcome to MSW. Best way to get help and have people watching is to start a build log. I checked our index and there aren't any builds for this so you're a first which will be helpful to anyone else deciding to build it.
