Everything posted by mtaylor
That is an amazing diorama. So, if I'm understanding this, the flywheel was damaged and repaired at some point before she hit the snag? Given the grooving on the bearing and shaft, i'm gathering that no one ever did any maintenance on it. Just color me surprised.
No pressure here, Denis. . . . . . . . . . . . . . . . . . . . . Is it back on the table yet? Is it? Is it??
Well, over here in the Scratch area, there's lots of frame raising to see. I do see the French influence though in the American ships. It appears often in the lines more than the operational details, though. Size may end up being a factor but I'm looking for the "attachment" and the challenge. So we will see... I've got Hermione plans on their way, so that's possible. Druxey and Frolich had good ideas. Indeed. The lines and drawings were made just after capture by the Brits before they did any modifications. For example, the plans show the fireplaces and the oven. The Brits would have probably pulled out the oven and fireplaces and put in one of their stoves... I'm just not sure where they would have put it as things were pretty tight under the forecastle.
I'm thinking the same as Pat... that is a lot of sub-miniature detail work. It should just add to the "Wow!" factor.
I should point out that there's several differences between the French rudder and the British/American besides the previously mentioned shape at least at the point of time of the Licorne and Belle Poule. The French didn't use a spectacle plate as such. It was two eyebolts either by themselves or as part of the uppermost rudder iron. Since the uppermost rudder iron on Licorne will be too close or even covered by the rudder coat, I put them down lower "C". On the British/American ships, the rudder was retained by lines to the spectacle plate. On the French, there is a strop hole "A" that has a line from a ringbolt through the hole, and then to another ringbolt. Also, there's two lifting rings "B" to aid in resetting a rudder that went adrift.
Brig Eagle by robnbill - 1:48
mtaylor replied to robnbill's topic in - Build logs for subjects built 1801 - 1850
Beautiful work, Bill. I'm loving the details. -
Talk about a finicky bit of mortising... and tiny at that. Beautiful and inspiring work, Druxey.
- 641 replies
- greenwich hospital
- barge
Thanks for the likes and comments and following along. You guys are going to make this decision for the next ship hard, aren't you? And I thought it would just be a simple decision.. Roebuck or something French like L'Orient. I figure why not go for tough ones.... John, the Roebuck also juxtaposes with quite a few American ships according to the history, as I recall. A bit of an update... the rudder is ready for hanging. The macro shows the problems but in real life it looks pretty good to my eye. I actually had another one made but it hit the floor without my knowing it. The pup (hah!!!! at 3 years old, not a pup but she thinks she is) picked it up, and gave it back with unfortunately some deep teeth marks. I had to laugh as I call her "my helping bud". Anyway, I've got blue taped into position while I sort out the irons attached to the hull. As always, critiques, comments, or general mayhem is welcome.
Kurt, Not that I've seen on Google. I've heard of it but never used it. You can get it on E-Bay: http://www.ebay.com/sch/i.html?_nkw=butapren&clk_rvr_id=996470600024&adpos=1o1&treatment_id=7&crlp=94296869454_857&MT_ID=70&device=c&rlsatarget=kwd-19017607590&keyword=butapren&geo_id=10232&poi=&crdt=0&ul_noapp=true Apparently a lot of shoe repair shops also use it.
Sweet looking boat, Pete. Congratulations on another great model.
- 258 replies
- buzzards bay
- herreshoff
I sure don't like seeing that last picture, but it's necessary and you'll be safer and happier, by all means do it. I do hope the ground shaking stops for you guys.
Yangliyuan, I know of no Chinese instructions for this kit. As for help, there's quite a few build logs here in MSW which would probably be a lot of help. Also opening your own log would give you a lot of feedback.
Those truly are "fiddly bits' then. But this build is still blowing my mind, Druxey.
- 641 replies
- barge
I'm just curious... have you given any thought to making one master and then casting the oars? What you have carved looks great.
Patrick... here's a starting place: http://www.iann.net/giants/spindrift/blueprints/index.htm A further bit of Googling and apparently there are plans available for purchase. Ok.. I'll go quietly. Great looking fleet, sir.
- 1,083 replies
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
Just be good to yourself, Nenad. Everything else will fall into place.- 4,152 replies
- cutty sark
- tehnodidakta
Crew
mtaylor replied to CalSmurf's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
There's a topic here: http://modelshipworld.com/index.php/topic/1006-in-need-of-shipyard-workers-or-boats-crewmembers/ It's a bit old but it's worth checking out as there's a lot of ideas. and these but they seem to for specific scales... http://modelshipworld.com/index.php/topic/924-scale-crew-figures/ http://modelshipworld.com/index.php/topic/7177-i-cant-find-any-scale-nautical-figures-for-a-190-are-all-ships-lifeless-edited-by-admin/ http://modelshipworld.com/index.php/topic/4633-148th-scale-figures/ -
Piet, I bought a "tub" of dowels that are varying sizes in diameter and about 12" long from Dollar General a few years ago. None have warped although I haven't shaped any either. Right now, using them as place holders for things. I also have one the 3 foot long ones from Michaels that 3/4" diameter. Had it about 5 years and hasn't warped yet. Just make sure you get straight grained one(s) as many of the ones I see lately are warped and bent.
I love that display case, Tom. It does your lady justice.
- 212 replies
- constellation
- artesania latina
Gerhard, I think those half-rounds are the vents. I thought that also until I went back and compared the photo to the plan. I'm not seeing anything on the plan within a reasonable distance to those winches. No hatches, no booms.
- 2,625 replies
- kaiser wilhelm der grosse
- passenger steamer
A beautiful prop there, Keith. Nice work, indeed. Nothing wrong with watching paint/varnish dry. I do it early then read MSW and sometimes take a nap... although naps lately have been impossible due to dog seeing me doze off decides suddenly that it's play time.
