Everything posted by mtaylor
Hi Alexander, Tadeusz43 has posted a lot of pictures from various museums and ships.. You might as him. Here's just a few of his topics. http://modelshipworld.com/index.php/topic/9473-art-of-the-bow-figures/ http://modelshipworld.com/index.php/topic/9944-art-of-period-shipbuilding/ http://modelshipworld.com/index.php/topic/10967-vasa-museum-in-stockholm/ http://modelshipworld.com/index.php/topic/11402-maritime-museum-rotterdam/ Good luck with your search.
Gregor is right. You gentlemen should open your own build logs.
- 120 replies
- la jacinthe
- schooner
I used sanding sticks. Just a piece of wood the right size with a bit of sandpaper attached. Oh.. and only apply pressure such that the cut is when the plank is against the bulwark. In other words, if it's inside needed trimmed, pressure is only applied on the stroke out of the ship. Vice versa for the planking on the outside of the hull.
Wasa was also heavily decorated.
Mike, I hate to be a party pooper.. but there's still a lot of misconception about the Constellation. Have a look at this: http://www.maritime.org/conf/conf-linden.htm and there's a PDF referenced... http://www.navsea.navy.mil/Portals/103/Documents/NSWC_Carderock/fouled_anchors-1.pdf The AL model (and Tom did a great job) is basically how the ship looked for many years as the "frigate" before the restoration.
- 212 replies
- constellation
- artesania latina
Seeking information on determining load waterline
mtaylor replied to trippwj's topic in Nautical/Naval History
You're probably right, Joel. I'll have to go re-read. I know the maths were large part of the training for designers but not much more at this moment. Been a few years since I read that book. -
I like that "water" idea for a display, Siggi. It will be breathtaking to see it all put together.
Wayne, I've read that the French were very heavy into the mathematics in ship design. The designer was able to determine the various waterlines but with how much accuracy I'm not sure. I'll have to go back and re-read Boudroit's History of The French Frigate 1650 - 1850 which is where I saw this to grasp the fulll scope. -
Google it David. I've seen it on Amazon and E-bay. I'm sure there's other places also.
- 3,618 replies
- young america
- clipper
Daniel, I'll lay odds that's a dental bur. Google for them. There's tons that show up on e-bay at various price ranges. Also, if you're really on good terms with your dentist, maybe he'll let you have the "old ones". They're not worn out usually.
- 962 replies
- sovereign of the seas
- ship of the line
Ok... here's the ones I know of for ebony: Negative Issues... it's very hard and dulls blades quickly. Oily.. glue doesn't like to stick to it although some folks recommend wiping it with acetone before gluing. The sanding/sawdust is toxic and very hard to clean up. It definitely doesn't like to be bent. It can be done but is a test of wills. Heat and steam seem to work best. Positive issues; It's absolutely gorgeous when you finally get it shaped and in place. It holds an edge very well.
Lovely work, Sjors. She has her teeth and now gets her sails.
- 1,616 replies
- caldercraft
- agamemnon
The one nice thing about models ships is the ability to do-over. I hesitated a lot before deciding to jump in. The catch is, the more I'm working on my scratch build, the faster I'm learning. I'm on a first name basis with Scrap Box and more relaxed than when I did kits. I think it's knowing that I can make new parts and not be beholden to a kit maker for anything. I'll be quiet and just follow along with you.... You're making a good choice to do another model. But do beware. You've made that first step towards the darkside* by admitting that's where you want to be. When it finally grabs you, there's no fighting it. *Darkside = scratchbuilding.
Thanks for the comments and the "likes". Good eye, Druxey. It's not the counter.. it's that framing piece I put in. It's about 1 mm too wide and sticks out too far. Rats.... Easy to fix though. Edit of the edit: close inspection shows a tolerance build up. I'll fix it during the planking as the light on the port side is about 1 mm too wide. Not sure what happened but it's easily fixed. Actually, gentlemen, I've become even harder on myself and bolder in redos as my scrap box will testify. But it's all good. I'm also accepting the "dings"...
