Everything posted by mtaylor
Thanks for the comments and the "likes". Keeps me motivated. I don't know about courage, David. It just needed to be done and I figured the sooner the better in case something went south. I have visions of the Dremel stand coming loose and wiping out the keel and framing. The first one was "heart in mouth". The second hole, I managed to breathe. Metal is a whole different critter, isn't it? I've done my share of hand machining and I find I like dealing with wood a whole better. Pure coffee at the time of the picture Kester. Irish coffee after everything had been taken down and put away.
Try checking your local office supply store. They usually sell all kinds of desk lamps and drafting table lamps. Many are clamp type, others have a base. They also have different adjustments and bulb types. I have 4 lamps in my workshop. One is a utility type under the cabinet (kitchen type) over my lathe. The other three are adjustable, one magnifier, one with a clamp base at my mill and table saw and the last sits on it's base over by build table. I can move it where I need it.
Well... I meant water with the full compliment of sails and R/C gear. Mast steps appear to be plywood.
- 553 replies
- sloop of war
- constellation
(and 3 more)
I think the spacing and the height both look good, Lextin.
- 366 replies
new clear product!! WoW
mtaylor replied to leroy's topic in Painting, finishing and weathering products and techniques
Good for you on the bulding them the way you like them Even better that you name them all after the Admiral. -
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
- 4,152 replies
- cutty sark
- tehnodidakta
Thanks, Michael. And you're right... there's always a way. We just have to find it. Sam, I wish I could help you on the solvents but short of your driving north, they can't even be shipped to California. Hmm... new career path... smuggling tolulene into California.
Minor step but for me a scary one. Rather than put off drilling holes for the mounting bolts and pedestals, I chose to grab the beast by the horns and go for it now. That way if something went really amiss, it would be fixable. So, I set the ship under the riser on the workbench, grabbed my Dremel drill press and proceed to cobble a way. I rotated it around, clamped and screwed it to the riser. It took a good 10 minutes of fiddling to get everything centered up and squared away. After inserted a very small bit, I held my breath and drilled. And it worked like a charm. I turned the ship around and repeated for the forward hole. Took a picture for posterity's sake. The pedestals fit nicely and the screw didn't do any damage.
That's about all I can muster at this point. Exquisite musket.
- 1,215 replies
- sloop
- kingfisher
HMS Druid by Krug - FINISHED - 1:48 - Hahn
mtaylor replied to kruginmi's topic in - Build logs for subjects built 1751 - 1800
Just beautiful, Mark. The figurehead is magnificent finish. I'm looking forward to the Lady Anne and the cross-section. -
Getting closer to getting her in water, Jerry. Nice progress.
- 553 replies
- sloop of war
- constellation
(and 3 more)
Hopefully they'll show up in a build log.
Looks positively wonderful, Mobbsie. No need to apologize.
- 1,279 replies
- agamemnon
- caldercraft
Hi Mat, Welcome to MSW. There's one other build log out there: http://modelshipworld.com/index.php?/topic/6261-uss-constellation-by-jlheureux-al-185/ Mine won't count since it's a heavy bash and there's a scratchbuild but it's not at all like the kit. Start a build log when you're ready in the kit area. It will be the fastest way to get help and encouragement.
Thanks for the "likes" and comments, everyone. I forgot to mention the 4 mm hex-head wrench too. My lady figures the prosthetist can build it, and I can tweak the fit and functionality. He tends to agree with her. So... I got hired. Thank you for the feedback. I may not find and fix all the errors, but I will try. I'm waiting for the Belle-Poule monograph now for insight into the details of things.
Change the story to keep the Marine ouf of trouble.. he was shooting at the rat who came up out of the hold. (I'm wondering how many remember the rat.)
- 1,215 replies
- sloop
- kingfisher
Doris has put her builds here on MSW. An exquisite modeler. Her ships are beyond works of art.
Hi Alex. It's good that you're ok. But to refer to MSW policy: No politics. No religion. No inflammatory topics.
- 227 replies
- cumberland
- 74 gun
I decided I needed a break from half-frames. So for a few days I've been doing some prosthetic work on my Admiral's fake leg. So far, I haven't screwed it up even though I'm hitting it with a heat gun, dremel and cut off wheel, and tolulene. As time permits, I cleaned up the salvaged keelson along with the salvaged fore and main mast steps. The keelson is now glued into position after tweaking the fit and the mast steps are fitted but not glued. There's markings inside for re-fitting them into position and also marked up the exterior for drilling and fitting the pedestals. As soon as I can figure out a way to drill them square in all dimensions (not a square hole but exactly perpendicular) I'll do it. This beast is too big for the drill press or the mill... <sigh> Also, minimal fairing at this point on the inside of the hull. Anyway... picture. And as always, errors, omissions, and stupid mistakes, while not always intentional are subject to be commented upon by those who read this.
Great looking grass, even if all of our admirals would insist it needs mowing. Looks even better with the Ogallala sitting in it.
- 170 replies
- ogallala
- praire schooner
