Everything posted by Nirvana
Okay, call me crazy if you like as this will be number three of models that I will be working on. But as I haven't encountered any problems with this one, I will proceed with the build of the famous Bluenose. This while I wait for parts for the Syren and Solo. I guess this kit doesn't need any introduction or picture of contents. So I will leave that out, however I do have extra material that I will be using later while building her. This extra comes from Syren Model Company, with other word our dear Chuck Passaro. This kit was bought many years ago and the keel and bulkhead plywood is still straight. When I was putting the false keel pieces together it turned out so straight I was amazed. The plywood is very nice and very little sanding is needed to get the bulkheads into each slot. Creating the rabbet was not as hard as I thought. Just being careful at the bow where the rabbet is extreme. I pre-beveled the bulkheads so there will be less sanding once they are glued in place.
Keith, I am giving my helper a bone while in the shop, this way I have the company of him while I am fiddling with my build. That metal work is very nice.
Rich, Isn't this what is so great with MSW, making friends with similar hobbies and interests. That's how I met some of the people from here and getting involved with RC sailing as an example. Enjoy the trip, I know you will like it.
- 1,135 replies
- model shipways
- syren
Severe frustration with this kit is setting in, After using several calipers (mechanical and digital) and several rulers all shows the same result for me. The plywood provided is to thick, instead of the 3/16" (4.7625mm) they measure 13/64" (5.16mm), this is huge at this scale. It was no wonder that the jig I had made didn't fit the 3/16", this after I used a aluminum square for the center opening. With that the nothing is right. I went outside had plan two and three along, put one on top of the other on the glass table, with the sun I could clearly see differences between the plans and measures. The BF doesn't match at all, one is longer than the other but not taller, and the bulk head openings are not lining up. The Scale 3/16" - 1' bar seems to be correct, but as it is so short it's hard to tell. Have no idea what kind of "Monday" model I got. Am about to give up with Syren.
So, I had the template cut and joined. Reading Bill in Lewistons build log he had run into a problem with them as the didn't line up. I thought when viewing his picture that he hadn't lined it up properly, so I checked my template versus my warped false BF, and sure enough I had the same problem. Then I checked the template versus sheet 2, and lo and behold they were different. Placing the BF on sheet 2 we have a perfect match. Then I measured with both a ruler and caliper. This between frame 4 and ∞ On the template the distance is 36.25mmm, while on sheet 2 distance is 37.8mm exactly the same as the physical BF. My solution, scan the part of representing the template from sheet two and use that. See inserted pictures. Checking the deck plan, same problem. I will post pdf files here for everyones use.
Bill, I thought you mentioned you didn't have time to start building the Syren until second week of June...... Ha at least I found your log and as you can see I have started mine. I am glad you didn't have the same issue with warping and twist in the BF. So, now we are waiting for our President of PSSM to get going with his Syren as well.
Well, I didn't expected I would come to this point. But here is my build log of the Syren. I feel a presentation of the kit is not necessary. Reklein and I are both members of PSSM, so this could be considered as a club build. Our President has already started the build but has had the bit at a stand still for a long time. I had started the kit, but the keel for BF was to warped and twisted to be used, even after two weeks of straightening. I even tried with the inserted bulkheads and filler blocks to get it straight"er" but to no avail. I contacted Mr. Mosko at ModelExpo via email and got a quick respons the following morning. I have shaped the bulkheads, put the templates together and will do other work while waiting for the new BF to arrive. The build jig is made and ready to go to. The current BF and bulkheads are just put together without glue and I am using them to bend the planking. Thought they could come to good use for that purpose. Lastly, I would like to extend a big thank you to all other members who has build Syren, as your logs will provide a lot of extra information needed for the build and how to avoid pit holes along the way. Now picture time
Fokker Dr.I by Torbogdan - FINISHED - Model Airways
Nirvana replied to Torbogdan's topic in Non-ship/categorised builds
Tor, That engine looks like it is as good as ready for firing up, the "purr" from those engines are amazing. -
Cheering for a successful and beautiful completed Cheerful! Hat off to you, Chuck.
- 1,051 replies
- cheerful
- Syren Ship Model Company
Martin, Warm welcome to MSW. Many of us has been involved with MSW for a long time and experienced coming and going of members. The big crash back in 2013 where all was lost, at least what we thought. Some was recovered thanks to members that had build logs saved on their own computers. Now it's time for you to start a build log. As we all look forward to see your build. Once again,
Dave, would you mind passing those skb files to me? I am also a user of SketchUp so that would be perfect for me. Thanks for a fantastic build log of Bluenose.
- 245 replies
- bluenose
- model shipways
I truly like the shackles, may I steal the idea from you? For that price it's a great add-on.
- 245 replies
- bluenose
- model shipways
