I could not resist the urge as the Ole Girl was calling me and wanted some attention,  so back on the bench this evening, I went strait to the port holes and got some black acrylic in a jar - it was quite thick as I wanted it to fill the holes, I used a fine pointed paint brush then dabbed the paint into the port holes, I then wiped away any spillage.
After all the ports where filled I diluted some hull colours and applied a light glancing brush - a few times just to cover the over spill and darkening from the black.
It seems to have gone ok on the one side(the other side I will do tomorrow).
Here are a few pics of the work folks.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
That worked quite nicely OC - looking good (even with the glasses on :))
cheers
Pat
Well done on the portholes.  They look like they're supposed to be that way.
cheers
Pat
Thank you Pat.
OC.
Current builds
Completed works.
Thank you mark,  and a Big thank you for all your likes of my build, It certainly keeps the inspiration going. :dancetl6:
OC.
Current builds
Completed works.
Right then folks now that I have overcome my little port hole wobble and just have the starboard side to do,  my thoughts have turned to when I continue on the two rear deck wall sections that accomodate the name plaque.
The name plaques  are PE and on my fret (that arrived damaged not making work with it to easy) anyway they are indivual letters and secured by two pips on each letter, instead of trying to place each letter and spacing them on the plastic wall,  I came up with the idea of creating a sheet that will be sat behind the latters while stil on the fret, then glued in place.
When its fully stuck to the letters I will be able to cut the pips and remove the whole name with the backing plate attached underneath, then after a bit of sanding the edges I will paint the whole thing the correct camo colour, then after either rub off the paint on the latters leaving a brass name or paint the letters white.
I will then be able to lign up and stick the nam eplate to the wall with better accuracy.
Well thats the plan ;):)
Here is a couple of tiny drawings of what i meen - the letters as they are attached to the fret, and the plate I will fix behind them.
OC.
Current builds
Completed works.
OC,
I don't get this ... what are pips? I only know it as those things in grapes, fret, another one which can be anything not related to building a ship or ship's items according to dictionaries
Carl
OC,
The PE parts are attached to the fret via tiny strands of PE material - I call them pips  abit like the plastic kits and how they are joined to the plastic frets,  we all cut the parts Plastic or PE as close to the part as possible.
Hope that makes semse?
OC.
Current builds
Completed works.
Started working on the rear walls  not sure if that is the correct name for them?  anyway I worked on the extension piece I added - this needed sanding down a bit to reduce its hight a bit more, then I fashioned some PE into a plate that goes on the wall and bridges a gap towards the turret.
Here is a pic of it folks.
OC.
Current builds
Completed works.
How does sprue work for those little linkages from the fret to the part?
Not sure I understand this but what I was saying that in both mediums all the parts are attached to the frets by small stalks or as I called them pips, it just how they are made.
OC.
Current builds
Completed works.
A bit more work folks - I attached the name plaque to two thin PE plates, I glued them down with PVA after giving the PE a slight sanding to help key it, I then placed a weight on it ald left for a few hours, when set I painted over both the letters and plate and gave that a coat of flat brushed on top coat.
I will carefully cut these out tomorrow and either sand back the letters to a brass look or run over them with a white paint.
I also added a few layers of 507C as a base coat on the wall secion(Bulkhead)?.
The picture shows the letters attached to the backing plates still attached to the fret, and the bulkhead below it showing the relationship and scale between them.
OC.
Current builds
Completed works.
I carried on today with the rear starboard side bulkhead by generating a line for the camo break, I them painted the darker shade in a few coats and put it aside to dry,  I then turned my attention to the name letters on the PE Fret, I attempted to remove these including the backing plate I had attached yesterday, but no luck they peeled away,   so I had to remove them in a few groups of letters and place them on the backing plate,  I was going goggled eyed due to the size of the letters,  when set with the PVA I used  I then attached the whole thing to the bulkhead.
Next was to to give the plate and letters a light coat of brass colour, then when dry an over coat of bulkhead grey colour, then when that had dried I gently/lightly sanded over the letters with some fine wet n dry just to highlight the letters.
Not as neat as I would like but best I could do.
Here is a couple of pics folks showing the bulkhead in place on the rear deck.
OC.
Current builds
Completed works.
Thanks for the suggestion re - the letter scraping, my concern is knocking the letters off, as they are only secured down before painting with PVA onto a sanded PE plate, so making them PE ontop of PE, I should have used super glue but the one I have at the moment is one of those thick brush in bottle fella's and I wouldn't have had enough working time for moving them around on the tiny PE plate.
OC.
Current builds
Completed works.
I tidied up the lettering a bit (best they going to be)  then I glued the bulkhead to the deck, needs a bit of tidying up near the turrets,  I also decided to add a bit more wood decking that should extend towards  the edges over the old rear 6inch casemate, this is missing and not shown on many builds or even the pontos decking does not show this.
So I basically cut the shape from left over decking and dry fitted a few times then after a few bits of cutting - I then pressed it down,  it does need a bit of weathering to match the decking this I will do with a bit of a dark wash.
OC.
Current builds
Completed works.
nicely done OC  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Just got myself a cam phone from the old old days - a  sony ericsson K800I, gonna use it as easy to use option, as the cam I lent needs to be returned soon, and I will have no cam available appart from my wifes pas cam, but its not fair incase I break it.
Any way here are a few test pics from the K800i  - what do you think?
OC.
Current builds
Completed works.
OC,  those pics look pretty good.  One wouldn't know it was an "old" camera phone unless you told them.  Oh wait.. you told us...  ;)
Hi folks - Evening,    I got a bit more done on the ole girl this eve,  I continued with the rear deck area creating some more decking over the extension above the old rear casemate, this again was done using some wood decking cut offs and required dry fitting and shaping,   then when correct I fitted it down and added a bit of shading with a black wash - on and off with a rag.
Here are a few pics folks again taken with my cam phone(over 10yr old model) ;)
OC.
Current builds
Completed works.
Nice
Thanks
Current builds
Completed works.
Hi folks evening to all  - I started work on the other side(starboard)  rear deck balkhead, again I cut it from the fret and added a small strip of plastic ontop,  when set using revel glue I sanded the top down to reduce the hight to match what I had done on the Port side,  I also drilled through the port holes and then sanded back the join on the top plastic section I added.
Here are a few pics also including one of the boats with the kit that will be detailed.
Wonce again - many thanks for reading and liking my work. :)
OC.
Current builds
Completed works.
More fiddly bits ...  looking good
Yea  I know those are for my 1200 scale kit :D   Only joking but imagine :o
OC.
Current builds
Completed works.
