Spectacular work on the carronades.
Hi Johann, very good step by step presentation of awesome work! Fascinating!
Alex
Current build: HMS Sphynx, 20 gun ship launched in 1775 at Portsmouth, Hampshire.
On the drawing board: HMS Anson, 64 gun third rate ship of the line, launched in 1781 at Plymouth
Hi Alex,
I am very pleased about your nice comment.
Here is an update of the report:
Completion of the fittings for the carronades.
So now the fittings are manufactured for the carronades. For assembling the brass parts still need to be blacked.
In the following picture you can see almost all the parts to build a Carronade.
All parts are now neatly sorted in a plastic box, ready for final assembly. Thus, over 50 items come together for a Carronade. For 20 carronades which means about 1000 parts.
Hi Johann,
From now on I believe that what you keep doing is not impossible or unbelievable because I saw you had done it, this had not been a dream...  m1830.gif
hello archjofo
 I really like your work.
a question.
What materials you use to weld? I do not think is tin.
dust appears.
a greeting
cabrapente
Many Thanks Karl.
Hello Dear Friends,
gun locks were also used to fire the carronades.
The rifle lock was fastened with a thumb screw.
Later percussion locks came into use.
The next picture shows one of the 1849.
The production of the carronades of La Creole continues steadily.
Here is a short update:
Edited by archjofo
This will probably also shoot it? Perfect.
- Pavel -
Sorry, my english is bad, I must use a translator.
Praise makes you happy, but criticism makes you better.
Hello,
the straightening rod from the carronade was secured with a chain.
For this I used a ready-made micro chain of copper wire 0.20 mm.
The ring bolts are made ​​from brass wire 0.25 mm.
Here are some pictures that show these chains.
