She looks great Rusty, and the detail work looks incredible.
I thought she was big when I drew her up at 1:32 scale...at 1:24 scale she's truely huge :)
Keep up the great work!
Jeff
Edited by jeff1395
Well I’m back safe and sound and hope to relax a little doing some modeling this weekend.
Thanks Paddy.
Ben, Not as much as I missed MSW!
Hi Grant and thanks.
Thank you Craig,
Hi Chuck. Thanks and it’s good to hear from you.
Jeff, yes she is huge but I’m getting used to it now.
There has been so much going on here at MSW over the last 8 days! I need to take a week
off just to read all the posts. I’ll do my best the work shop is calling right now.
Thanks again you all and it’s great to be back!!!!!!!! :)
Rusty
"So Long For Now" B)
Current Builds: Speedwell
I’ve completed the second layer of decking for the mortar pit. I assembled it off the model again
gluing black construction paper between the planks to simulate the caulking. The planks are a
different width and did end up over lapping the lower decking most of the time. One seam lined
up on each side so there shouldn’t be a concern with strength is it was that way in full scale.
After I did the initial assembly I then marked the circle for the mortar and cut close to the
line with the scroll saw.
I then used the dremel with a sanding drum to finish it.
I then glued the second decking to the first. I also have drilled it for the treenails
After looking at the plans I noticed that between the top beams for the shot room, the
deck beam, and the two layers of decking it would have been 3’ 4” thick on the actual ship!
That’s a lot of support for what I assume to be a very heavy gun.
Rusty
Hi Andy. That's a duh moment for me. I didn't give recoil a thought. Thanks.
Rusty
I’ve installed the gun deck clamps now and have started on the beams.
Here you see the plans of what the gun deck will hopefully look like once completed.
Here you see the beams set temporarily in place and marked out for the placement
of various carlings, beams and half beams.
Here is a beam the goes between two deck beam, # 3 & 5 as well as the half beam.
And here it is set in place.
I will just work my way from one end to the other filling in the carlings, ledges and knees as I go. :)
Rusty
Between your  triton cross section and this bomb vessel section you may get tired of cutting all the mortises for the deck beams...as alway very nice jointery and a great build to follow.
ps. if you are not tired of cutting them i have a cross section you can work on  :D
Triton Cross Section 1:32
SEE YA LATER
im-outta-here-bye-bye-smiley-emoticon.gi
Thanks Ben but I can tell you cutting them into cherry is much easier than boxwood.
I don't envy you all of the ones you're going to have to do. ;)
Hi Pete I wouldn't want to deprive you of all that fun.
Thanks Grant.
Rusty
Hello Rusty.
Like the other guys have said great detail to the joinery and fine work.
I like the cross section as its some thing you can build a lot of detail into.
And you are doing just that :)
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Thank you Antony. Your continued support is very appreciated.
As I work my way around installing the ledges and carlings there are also
assorted knees, hanging knees and double knees.
All of the deck framing  pieces are being cut from Cherry.
Here you see one set of double knees rough cut out.
Here is a hanging knee rough cut and then set in place to test the fit prior to the finish sanding.
Everything seems to be going well, so far, now hopefully I just didn't jinx myself! :huh:
Rusty
Very nice work Rusty........looking at the how structurally sound these vessels had to be to withstand the punishment from the mortars you can understand why they were so popular with the Arctic explorers.......i am pretty sure both the Erebus and the Terror were ex mortar vessels,both of which withstood years of being icebound until they finally succumbed to pressure of the ice.
  Great build and very nicely done.
   Cheers
    Jack
Edited by jthemanjack
lovely work, it is this project that inspired me to try a scratch build, oh how times change, when you realize that your skills are not what they should be,but it is still on my agenda to start one day, i will carry on watching your work and wishing it was me
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
That seems to be a pretty good fit straight up there Rusty. Nice work!
Rusty,
that's a very nice progress. Your section will be very impressive, especially in that big scale
Regards Christian
Thank you all for all the likes, visits and comments. They are very much appreciated. B)
Thanks Ben, I’ve been asked a couple of times if working at the larger scale is a good thing or bad.
Well when it comes to ledges, carlings and knees it seems to be easier. Although there is a lot more
wood that needs to be removed I find my errors are smaller and less frequent at this larger scale.
Time will tell if this still holds true.
Hi Jim, Thank you and it’s good to hear from you.
Thanks Jack, from what I’ve seen so far on they are very solid and I don’t know about the Erebus
and Terror but it makes sense to me.
Hi Kevin, thanks and I’m sure you can handle this cross section once you are ready. All you need is
a LOT of patience and a willingness to throw away parts that didn’t work and do them over.
Plus it’s a good excuse for more tools! ;)
Thanks Grant. That one fit right off the scroll saw. Not all of them were that close. A little
adjustment here and there and in they go.
Thank you very much Christian. Your work has always inspired me.
Hi Augie. Thank you. Yours and everyone else’s support and interest makes my day! :)
Well I’m off work until next Monday. Thanksgiving day is shot but the rest of the time
has a whole lot of shop time scheduled in. By Sunday night the Admiral may have
forgotten who that troll is in the basement. :D
Happy Thanksgiving to all here stateside and best wishes to the rest of you. Be safe!  :cheers:
Rusty
Thank you Michiel.
I've been making good progress on the deck framing. It sure helps having cut the parts ahead of time!
It still will need a good sanding to fair it all up but so far so good! :)
Rusty
Thank you all for stopping in and the likes.
Thanks Bob, you never know what kind of oops or such that could pop
up and ruin the day. :D
I have competed the framing of the gun deck. Pretty straight forward and
at this size it turned out to be a lot easier to do.
Next in the mortar pit the walls need to be built. There are angles involved
and I didn’t trust myself to build it off the model and keep the correct
dimensions. Also there are four cross braces between the beams that
need to be put in.
So to help me keep it square and position the cross bracing correctly I clamped
the side walls in place and then started fitting the angles. This way once
completed I can mark the cross bracing, remove the walls, install the bracing
and then return the wall to it's correct location.
Here is just the top piece of the wall confirming the angle and length are correct.
Time will tell if this will work or not. ;)
Edited by Rustyj
Rusty
Neat idea Rusty - I'll be interested to see how it turns out. Though with your track record, I'm sure it will turn out superbly! :)
Thank you all for stopping by.
Hi Grant, I had a good night in the shop and it’s looking good so far.
Hopefully tomorrow I’ll have more pictures. B)
Jan, Welcome aboard.
How did I miss this log?
 I understand what you are saying. With so many builds it’s hard to catch them all.
I constantly find new ones too! :)
Hi Ben,
 Looks like it will work from here
That’s similar to a saying we had while building my brother in laws house. We’d put something up and he’d ask
“how’s it look? And invariably someone would shout out “Looks good from here” or “Can’t see it from my house”.
Drove him nuts the entire time. If it wasn’t for the free labor he’d have booted us on day one! :P
Rusty
Hello Rusty.
As always excellent work.
Nice idea with the corners. Looks fine to me.
Looking forward to your next build update :)
Regards Antony.
Completed Mayflower
