sorry to hear about the ship Nils.........I too hope nothing goes out of whack.   your making such great progress with her........looking very nice.  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you Denis,
it really looks like the glue-swelling out went back over the week. Quite good that I did`nt remove it, otherwise there would be pits in the "skin" now....
I`m working at the decks in the waist areas now, after finding a supplier for wonderful precise cut mini pine planks 2 x 0,8 mm. The "caulking" is done with a soft dark pencil along the planks edges
Nils
a set of 300 fine cut pine-planks 2 x 0,8 mm
planked forward waist area
the lower aft waist deck stripes
will do the shrouds for the aft mast later on with buckle screw fastening / tensioning , therefore sufficient bases for anchoring points beneath the deck stripes
the promenade deck will cover these outcuts in the sides later on
Current builds
-Lightship Elbe 1
Completed
Hi Nils
Nice work! You're really moving at a fast pace with the decking, that's for sure. I'm also glad to hear that the swelling of the glue joints shrank back once dried. Failure to do so would've been quite a setback for you, so I'm happy that it worked out well for you.
Looking forward to the next update!
Thanks
Patrick
Edited by Omega1234
Glad to hear your glue swelling issue sorted itself out Nils. Mighty fine progress there.
glad to see the hull fared well.........probably needed a bath anyway,  with all the dust you've been kick'in up  ;)   love the deck planking......looks really sweet!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Many thanks to Patrick,- Grant, - Popeye,- Bob, -
and all the "likes"....
Patrick,
I`m also glad that this is overcome now..
Grant.
yes. that was a lesson related to high humidity air getting into the room
Denis,
thanks for your nice comment
Bob,
I`m also quite happy with the deck planking. The smaller the plank dimensions get, the more fragile the plank edges are whilst cutting to length and after laying and sanding. It gives a little messy deck surface with the slight remains of white glue, sanding dust, and pencil-caulking charcoal
Nils
Current builds
-Lightship Elbe 1
Completed
Good news Nils and your decking looks super nice.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
I just love to see your updates - lovely work
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thank you very much John, Piet and Kevin...
for your kind appreciations
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 16
did a trial mock up today for for rounding the 19 mm high cabin wall corners. The doors are  15 mm resp. 14 mm  high depending on position of mounting
Nils
doors with window frame, and doorknob are of brass
cut a profile bar for the corner- fitting of the cabin wall plates
easy to round and blend out
a good base for the plating....
gives a nice smooth corner connection
door and porthole fitted
Current builds
-Lightship Elbe 1
Completed
Nils, is there a reason for oversizing the wood, or is it just to get the shape
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Hi Kevin,
correct, its only a mock up for getting a good round "Corner", the silver plating indicates the hight of the walls (19 mm between the decks)
Nils
Current builds
-Lightship Elbe 1
Completed
lol - if you are doing that for everything, at the end of the day you will have two complete ships
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Very nicely done, Nils. However, I find the rivet heads 'read' a bit too prominently. Perhaps it's the fact that they are reflective at the moment?
Auh .. .. ... what kind of magic you use ?
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
many thanks - Kevin,- Druxey, - Nenad, - John,- David,....
and the "likes"...
For all your kind comments
Kevin,
a good comment, but not general practise, ....if there are certain details I find its worth doing a trial before doing repeatable objects, I do it, and possibly see where it can be improved, this has saved me much time work at the end. On the other hand I would be happy if I could see trials and thoughts (in pics) from fellow builders as well, i find this makes the "spice" of a builder`s forum comunity like this
Druxey,
the resembled rivet size depends on the tooth-module I use on my poncing wheel. Here I used double thick aluminium foil, because I had some scrap strips left over. I thought I would have to put more pressure on the ponce wheel. Will probably flatten the the rivet head a wee bit, but thats why it`s a trial,...improvement pending
Nenad,
glad you like it, its only making use of what I had already experienced in some way before and to my own satisfaction
John,
Thanks for that nice pic relating to rivet joinings at the bridge cab. Have you been officer on the "MV. Meringa", a nice ship
David,
for deck planking I use 2 x 0,8 mm precise cut pine strips. The basic material is probably machine cut pine veneer. Unfortunately I ca`nt cut that precise in those dimensions myself. The strips are glued to the raw deck made of 0,8mm plywood. This way the total deck thickness is around 1,5 to 1,6 mm
Nils
Current builds
-Lightship Elbe 1
Completed
Nils,
You may also want to experiment with the hardness of the surface below the foil when embossing the rivets.  Harder material will decrease the rivet size and height.
The model looks great.
Ed
Thanks Ed,
yes, I`ll be looking into a different shore hardness for the rubber pad I use underneath
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils -- I've finally had the chance to catch up on your progress:  Whew!  there's quite a bit here, plus the close shave with the humidity!
This is a great log showcasing the skills of a Master Builder, and for the narrative spills and thrills!
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Hi Martin,
Thank you very much for looking in again and for your nice comment. ...
In the moment I`m just figuring out what semi materials there will be required in brass for the coming sequences, so its a bit of thinking ahead, determining possible alterations how to do certain details before spending the money. There will also be much soldering involved. The scale 1:144 is quite a task, but also fun to find solutions...
Nils
Current builds
-Lightship Elbe 1
Completed
I agree with Nenad.  What you do is impossible it must be magic.
Bob
Current build:  SS_ Mariefred
ha....thought i'd take a peek at what you're up to, and wow, talk about detail....those props are amazing...i know i'd never have the patience for something like that.....ship looks like it will be very detailed and i can't imagine how many years it's gonna take....do you have someone to take over after you :)..............congrats...              vic
Many thanks to  Bob (cap`n), Vic and Dirk...,
for the fine words...
Bob,
I do hope that the "Magic" dos`nt let me down when the tricky things start, there will be so many details I do´nt even know know in the moment how I will do them later... (golden stern decor, railings, vent Hoods, funnels. etc....)
Vic,
Thanks for dropping in....
as I mentioned in the introduction to this log, this build is going to be my most ambitious one, but I trust I`m quite good in the Timing. I have to make a break when the hull is plated, in order to finalize my HMS Pegasus....
Dirk,
Danke Dir.....
hope you shall have pleasure in dropping in now and then, regards out of the greater Hamburg  neighbourhood area,...
I love your build "Maria", you`re making a real gem out of that kit...
Nils
Current builds
-Lightship Elbe 1
Completed
Little update...
have been producing some of the doors in different hights and with different size windowframes, also some forecastle doors, and about half of the double-story promenade deck windows
Nils
the window frames have been sprayed with dull clear varnish in order to keep the brass shiny.
the 4 doors for under the forecastle deck (with each two locking levers) will also be painted
Current builds
-Lightship Elbe 1
Completed
