gee....and I thought the test guy wires looked cool..........the real ones are fantastic!   awesome job Nils.........she's really looking sweet now!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
G'day Nils
I'm in a real dilemma, I am holding my breath to see this finished ship, but I don't want it to be finished. :default_wallbash: I'm enjoying myself so much with every part and every log entry, I can't hardly believe how small she is.
I'm flabbergasted with everything from the funnel's tires to the simulated rivets. A truly inspiration piece of craftsmanship.
Havagooday
Greg
"Nothing is impossible, it's only what limitations that you put on yourself make it seems impossible! "
Current log : The Royal Yacht Royal Caroline 1749 1:32 by Greg Ashwood:...
Thank you very much Denis, Jeff and Greg,
for your nice words, much appreciated....
Thanks to all the other recent "likes" for clicking in...
Denis,
I had two diam. sizes of wire and chose the thinner (0,3 mm)  one, which would be 43 mm cable diam. on the actual ship ....
Jeff,
I still have`nt made up my mind yet for what project would be next on the drawing table....
Greg,
there is still quite a lot to be done......
all the rigging with blocks etc. for cargo derricks and beams, also the winches on the aft ship and aft mast,  all the ships boats, the davits and their rigging, and last not least, the command bridge with all its associated relings, bridge-wing cabs, and others, etc.  ...
Nils
Current builds
-Lightship Elbe 1
Completed
Not only have you put up all the guy wires, but you even added the two wire clamps at the end of each one.  Here you are building at 1:144 while I am finding 1:100 difficult. Lovely detailing, Nils.
Bob
Current build:  SS_ Mariefred
Nils....I encourage you to stay focused....and only when this fabulous ship is complete and on my mantle..should you even think of what model is next on the drawing board.
I made that mistake and I have 3 unfinished clippers...because the *Next* vessel couldn't wait to get from my mind to the drawing board to the bench.
Rob(I reap what I sow)
Current build:
Finished build:
Current build(On hold):
Thank you so much for your appreciative coments Bob and Rob....,
Bob,
two wire clamps...., thats due to the learning experience I went through, I remember with the "Heinrich Kayser" steamship I only had one clamp per guy wire and it pulled / slipped out slowly, also I wanted to do something good and used stainless steel wires to avoid oxidizing, there was also trouble with the soldering of stainles steel wire, but all that was much regretted later on. With Gorch Fock and Pamir I started using exclusively tin galvanized steel wires and two clamps on the wire with more success
Rob,
correct, that is also my aim to complete a model and complete means to close the bonnet of the glass casing over the ship. Sometimes (per coinsidence) when viewing the net I come across information on ships, photos, details, etc. of which I consider it worth saving for a day I would need it. This is then put in a special file archive of my PC....
Nils
Current builds
-Lightship Elbe 1
Completed
Update :
ladders to the midships platform, railings to the lower bridge, and supports for the upper bridge (railings still require some straight bending, wooden handrails and paint)
the structures in the light tower areas require some filler material before final painting....
Nils
several stairways attached
boats winch in foreground, the whole boatsdeck is crowded with "detail structures", I`m quite pleased that all could find its place in accordance with the actual ship
supports for upper bridge, railings for lower bridge, light tower areas require some filler and repainting. Left some fingertips in the pic for scaling
all fragile parts, I do`nt think its so wise to choose that small scale again
those upper railing wires hardly withstand touching, structure here filler is needed
Current builds
-Lightship Elbe 1
Completed
Hi Nils
Once again, I'm totally blown away with what you've been able to achieve.  The work is so finely detailed, yet perfectly in-scale.  Just amazing!
What's even more surprising is the photo with your giant fingers in the way. Just that photo alone, emphasises how small the individual parts are.
Amazing!
Cheers
Patrick
Nils,
You keep on outdoing yourself. Al those smart details. I see some brass railings. Will you keep them brass, and if so, how are you going to keep them shiny and bright? I presume you are not walking around weekly with your polish and cloth ;)
Carl
Lots of nooks and crannies to get lost in.....
Fine job Nils..lots of depth.
Rob
Current build:
Finished build:
wow Nils........the progress you've made is astounding........so much detail added !    you've really gone above and beyond ;)    I did notice a couple of eye bolts that were partially open.......did you not close them,  or is that from stress?   sorry if I sound picky.......but I'd rather say something,  rather than hear that something you may not have noticed right away,  spoils it for you ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Many thanks Grant, Patrick, Carl, Rob and Denis,
for your nice comments and words....
Grant,
agree, it helps quite well to compare with the own fingers...
Patrick,
pleased you like it, as you are the specialist for midget ships...
Carl,
the railings copper or brass will be painted in place, I`ll do some masking off along the decks before, before the wooden handrail goes on
Denis,
some of the blackened copper eye-bolts still require close-bending, but I must be carefull, as they sometimes break off, (this hapened a few times before already) and it is very tricky to place in new ones from under the deck (the end with the counter flat head).
At least they do`nt "open" due to stresses in the wires. Next time I`ll use brass or steel ones
Nils
Current builds
-Lightship Elbe 1
Completed
Nils, I wish I could find old pictures of my boat being built as you did of yours.  And then you post them and say they are your build.  I won't tell. ;)
She's a great build with unbelievable detail.
Bob
Just an incredible amount of detail on her, Nils.  Very inspiring.
Many thanks Bob and Mark,
for your kind compliments....
Also thanks to all who clicked the "like this" button...
Bob,
the idea is not bad Bob, look out when I start posting black and white photos of the build you should get suspicious.....:D
Mark,
I have studied the old photos I could find and am thankful for the details I was able to make out. Who knows, perhaps one day there might be a kit of this model, or at least a good plan
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you so much for your nice words John (Jim Lad), Greg and John (Neptune)
Nils
Current builds
-Lightship Elbe 1
Completed
small update:
the upper brass profiles on the railing are carrying base for the mahagoni handrails (glue on with CA)
Nils
the U-type brass mini- profiles give stable strength to the fragile upper railing wire
like here on the aft ship railing
Current builds
-Lightship Elbe 1
Completed
3 minutes ago, overdale said:
A true thing of beauty Nils. Well done it's a real credit to you.
Welcome aboard Dan,
and many thanks for your nice words, I`m pleased you like it...
Nils
Current builds
-Lightship Elbe 1
Completed
Well, when compared to the beginning time frame you are nearly finished...IMV:P
I just haven't had any time to work on the GR......so two years from now I might be looking at a 6 month finish time frame.....B)
Rob
Current build:
Finished build:
Rob and Jeff,
many thanks to you both for your words...., an no need rush through, enjoy the build
Rob,
I´ll be looking out for your further progress on the GR, when you find time to continue....
Jeff,
Dankeschön, a nice comment, much appreciated...
Nils
Current builds
-Lightship Elbe 1
Completed
Everything looks great and excellent work on the funnels,overall a "Titanic" job..thumbs up Nils!
Completed.... Charles W. Morgan,Sea Horse,USS Constitution,Virginia 1819,San Fransisco II, AL HMS Bounty 1:48
L'Herminione 1:96
Spanish Frigate,22 cannons 18th C. 1:35 scale.Scratch-built (Hull only)
Cutter Cheefull 1806 1:48 (with modifications)
Current Project: Orca (This is a 35" replica of the Orca boat from the movie Jaws)
Nils - really nice work.  I never noticed the bolts holding on the blades of the propellers.  Exquisite.
Dan
Australian English 101
G'Day  all
In Australia we make a few words in a sentence into one longer word. We, I must admit, are a bit lazy in our speaking, but for us it's normal.
The reason why I'm writing this down, so other countries and their population might under stand our lingo. Some examples are:.
Lingo = language
Ozzie = Australian
Havta  = have to
Havtagree = have to agree etc
G'Day  = good day
Havagooday  = have a good day
Havagreatrip  = have a great trip etc
If you say it out loud long enough, I hope that you may understand our poor speech.
In Australia we use bloody a lot. Bloody is one of our best adjective to describe something so good or some times bad. Eg bloody fantastic is very good. Bloody terrible is very bad.
We also break down large words into a smaller/shorter word eg. Air conditioner  to Aircon.
There are many more facets to our unique language, above are only a small sample.
havagooday to all
Greg
