Today I gave myself a big list of things to do including dentist, grocery shopping, 5 acres of grass to cut then finish with completing and installing the rudder. If successful I promised myself a bbq steak and a trip to the liqueur cabinet( trying to follow EJ's footsteps;)) Well steak is still the fridge yet but there have been a couple of trips to the infamous cabinet, all jobs completed!!!!!
 I realise there is a little overkill with pictures on this post, I feel there is never too many pictures when it comes to the rigging aspect of a build so please bear with me.
 This what the task was for today. Top picture showing the rudder and the next picture showing the rigging for the tiller.
Pieces for the rudder, straps made from 3 mm copper strip
Still needs painting, this is showing the bottom bracket and bar mounted on hull the top bracket and bar is then mounted on the rudder. Receiving bracket is then mounted on hull at top and on rudder at the bottom. A much easier process, I love it!!IMG_2232.thumb.jpg.e0ced38bbad68a73d9c6a4f6056a061e.jpg
 The tiller being rigged with 4 mm double blocks. Seizing is done using Gutermann thread readily available, wide assortment of colours and measures approximately .18 mm
Blocks and rope for rudder, 4mm blocks .5 mm rope and eyebolts all kit supplied, used approx 50 mm of rope for each. It is the same set up for the tiller with the exception of the eyebolt, a hook is used instead.
IMG_2234.thumb.jpg.f21105b2b3eb6606ef11c7647303323a.jpgIMG_2238.thumb.jpg.3b4b48422ffedb147c71a3f33bf0395a.jpg
Showing rigging of the tiller, the use of hooks helps so much. Here I am showing running the rope through the blocks before attaching the hook to eyebolt in bulwark.
I will adjust that block after I'm done here. The plans do not show any sort of belaying point so I am assuming  coils of rope will be needed below the tiller later on. I have read the rope was wrapped around the tiller first to allow the helmsman to make adjustments??????
This is what the ship's cat might see.
You all Take Care,
Thanks for stopping in.
Cheers Don! :cheers: That rudder work alone is deserving of a drink or two in my book! Another excellent addition to you build. :D
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
If i were the ship's cat, I might go sit up on that tiller for a better view.  Rudder work totally deserves a drink!!
Mike Shanks
hello there Don! :)   browsed through your log ,  and I must say...I'm impressed.   it's a very unique looking ship your building here.   kind of a mix between a POB and a POF.   I've done a few Billing kits that the bulkheads were open like that....but I never thought to do anything like a lower deck.......I might try that?!?!?!? ;)   the deck is another interesting feature......instead of the usual platform to plank on,  the platform is actually planked.   I've done that with a POF,  and left it at that  {Billing Regina}.  splendid work on all the fiddly bits as well......they add a lot of texture and detail.  it's too bad though that I've caught your log near the end,  but I'll at least get to see if you decide on sails or not :)   hat's off to Marisella for such a wonderful kit
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks Rafine, Blighty, EJ, Mike and Dave for your comments. This is overwhelming. Thanks also for all the likes
Thanks Popeye for the compliment and joining in the log, always lots of room and never too late. These MarisStella kits have lots of cool features like the planked decks. One of the problems with the sails is that I don't put my models in cases ( the price of a case could easily buy another kit :)) so I am concerned with the cleaning of the sails. I am still hashing this out. I suppose I could hire a sail cleaner once a year :D.
 It was brought to my attention by a good friend of mine, Zoran, that I did the rigging on the rudder a little wrong. I went back to the plans and sure enough what I have done is not the same as what is shown
IMG_2244.thumb.jpg.8102346280ebbac36d6d73ac77cfaed1.jpgIMG_2238.thumb.jpg.f8ea747457adfb0c42e3f7afe7fccead.jpg
 As you can see the plans show only a rope on the port side tied to the rudder and on mine I have blocking on both sides. Now I know my way is wrong and not historically correct, however, I'm thinking in real life this rudder is almost 17 feet long, 4 feet at it's widest point and 6 inches thick. Given these dimensions this rudder would have weighed a ton (figure of speech) and raising it in shallow waters would have been some feat of strength. I'm thinking why not give this crew all the advantage possible and let them have a four block system:D Or should it be done the right way? Given the temperature today and this problem I am considering a trip to the refreshment fridge. Please help, or better yet come over for a cool one:cheers:
I like the symmetric look of your tackles.
17 hours ago, Dilbert55 said:
Does anyone know if there were stoves purpose designed/built for use on sailing ships or did they use those used on land?
Depends on the type of ship. Actually the history of onboard stoves is pretty interesting - the progression from brick/stone to metal. Crew size has a lot to do with it too. A little cabin stove might work for 5-6 people. A different matter for a crew of 500.
yea,  but looking at the diagram,  half is the bow and the other half is the stern........there may be a duplicate line on the starboard side.  this has been the case on many models I've done in the past.....wood or plastic.   would any be submersed in water?....another thing to consider.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Popeye, in my post 506, the plan is showing the starboard side with blocks, this is why I thought both sides had them and didn't bother to look any further:default_wallbash:. Blocks are above the water line
Mike, I like the looks too even though it is not right
Once again, beautiful work Don. To answer your question, we have a small place at Sandy Beach, north of Lloyd, where we spend quite a bit of time. Back home now so the work on the Brazerra can get going and benefit every step of the way by your trailblazing!
ian
Thanks Ian, I hope your holiday was a good one and I'll be watching for some updates
A drink or two?  I tried this while planking my last deck.  But then for some reason, the quality of my planking decreased progressively....:P
I agree Jean-Pierre, same thing has happened to me.I now have my shipyard set up so that when the liquor cabinet door opens the shipyard door automatically closes and locks. :o:D
Don,
I apologize for filling your in-box with so many "likes" - couldn't help myself. Glad that I found your build.
As has been said, your super well done details are superlative indeed. Great project! a feast for the eyes.
I was looking for a place to park my chair and follow along -OH I just found one in the nosebleed section (I have binocs -no problem)
What your shipyard doesn't serve drinks during bus. hours?
PS: I need to set up an auto bar/shipyard lock-out system such as yours ha ha -
Cheers,
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Hello Michael, welcome to the build there is always lots of room and never the need to apologise for filling up the inbox with likes. I very much enjoy that.
Drinking in the shipyard is allowed, however, until I find a way of controlling myself it is confined to spectators only. So you are good to go, fridge is in the back beside the recycle bin. Smoking is allowed in the two back rows and we ask that you turn off your cell phones while any power tools or sharp instruments are being used. All beverages are complimentary and self serve. Enjoy the voyage
Don,
Very funny!! - I will also check out your other builds (;-)
Under the table:
Completed:
Vasa-Corel -
A short little update, I have started the ship's boat:
Here is the balsa blank and a picture in the manual showing how it should look when done. Let's hope!
Laminating the top rails
Ripping some .5 x 5 mm planking to 2.5 mm wide. The off cuts will be used for the interior ribs. The carving of the boat in this picture is almost completed, shaping was done using a rasp and sanding.
Showing how the keel fits on the hull, a little bit of daylight showing there but the fit is fairly good.
First planking completed, one more layer to go
I have shown this before on another log but I thought I would show it again for those who might have missed it. To make oars I cut the dowels to length, these are 3 mm diameter, give them a good soaking in water then put them in a vice to flatten them. From right to left this picture is showing the dowel, the blade after coming out of vice then the final product after a little sanding.
The paint is still wet in this picture but these are the finished oars for the ship's boat
Thanks to all for stopping in, for all the likes and the great comments
Enjoy Your Day
What a great idea for the oars - they say the simple ideas are usually the best.
Cheers
Nigel
Current Build - HMS Victory, Caldercraft - scale  1:64,  started September 2021
Cutty Sark, Constructo - scale 1:115, finished August 2021
HMS Bounty, Constructo - Scale 1:50 - First wooden kit build, finished April 2019
Thanks Nigel, You'll have to give it a try it really works good
Ships boat is coming along nicely and that is a great idea for the oars. I will have to use that on my next set of ship's boats.
-E.J.
Ian: Thanks, it is a good way of making lots of oars in a short time
EJ: Thanks, I have been putting off building this ship's boat for sometime now thinking it was going to be too hard, as it turns out I am enjoying building it
 Hi Don,
I'm not clear how you tell from the plan that it is intended only to be blocked on one side?  Just trying to understand so I can do a better job of interpreting plans myself.
By the way, has anybody mentioned on how terrific your build is?  ;)
Doug
Current BuildsBluenose II - AKrabbenkutter / Prince de Neufchatel / Essex Cross-section / Syren / Barque Stefano / Winchelsea / Half Hull / Maria HF31 - Dusek / Bandirma - Turkmodel
On the Shelf: Santisima Trinidad and Cross Section / HMS Cutter Alert / Tender AVOS / Confederacy
Suspended Build: Bluenose II - Billing Boats Nr 600
Hey Doug, in the picture above the plan is showing the port side of the bow and stern. On the left side, the stern just a rope is going to the rudder, the other side is the bow. In a previous post I showed a picture of the plans that was showing the starboard side of the stern where there was a blocking system, I think it was in post 506. Hopefully this clears things up for you, if not let me know and I can re-post the two pictures side by side which may make it easier to see what I am saying. I don't mind, let me know.
