On 12/25/2020 at 12:53 AM, ChadB said:
Beautiful work as usual! I love your idea for making carriages! Could you go into a little more detail about how you made the initial block in the first photo?
Thanks!
Chad
Thanks Chad
The idea about initial block was taken from "tkay11" Triton cross section build. Thanks  to him for that.
I just do it a little changes. I make it a little longer and with 3 carriages  in one time.
The principle is quite simply.
I pre cut  all parts by sizes and  right mitre.
After glue them together. Only I use glue on ends of parts/Red line/
When all milling,sawing and preparing works was done
I simply cut off glued parts/Green line/.
In my opinion it worked quite well. Only I'm not sure if I'd do the same if I had to make for example 20 Carriges :)
In any case hope information given to me  helps to You.
Regards        Ainars.
Nice mod, Ainars! Glad you found the idea useful and worked on it a bit.
Tony
The rigging looks great.
10 hours ago, Ainars Apalais said:
But next model i definitely will be made without any rigging:)
 Well, I hope that is a New Year's wish that is not to be held to. Happy New Year! Happy modelling! Stay safe from COVID!
(We have a friend aged 60 who was begged by her daughter to come over for Christmas as she'd cooked so much food. The daughter on the day said her food tasted weird, so didn't eat much. The daughter then had a raging temperature and it turns out she had COVID. Our friend rang this morning to say she herself had just been tested positive. I am pretty sure that there will be stories from all over the UK that will be similar).
Tony
Beautiful work Ainars!
It's enough to tempt me to do another cross section 😉
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Beautiful work, Ainars.
Hi all
 Finally that moment has come.
When I can say the work are completed.
 I just recently added last missing piece - main mast.
Thanks  one more time to ChadB for all details for that.
And with that, the model is done.
1130716011_DSC_7182copy.thumb.jpeg.7c0efd23c28f6ea7437973c35a9d99e7.jpeg9496478_DSC_7174copy.thumb.jpeg.77309cdb7a1d86086cec96324a7b624c.jpeg
I have already started work on stand and display case.
So one more small/last build update will coming soon.
Thanks to anyone for help and good words.
Edited by Ainars Apalais
Beautifully done, Ainars.   I hope you have a place picked out to display her.
Hey Ainars,
Can you share a bit more about your cannons and where/how you sourced or made them?   They look great, and that surface character looks very real.   Stunning work, and great finish on everything.  What did you use?
