She's a beauty Joe. The fore and aft decks are very clean and the binnacle is a lovely touch. The wheel looks fine to me. Nice work all round. Also well done with the boat.
  • 8 months later...
Another long overdue update. I have done a good bit of work over the last few months, but again have been bad with the documentation.
Anyway...Standing rigging is complete. Again, obviously I did a ton of work with no updates. That was no mere few days of effort.
I've also gotten the boom and gaff rigged. Line is from a variety of sources and all of the blocks are from Syren. Finally the launch was installed and secured in place.
Joe Volz
Current build:
Model Shipways "Benjamin W. Latham"
Completed  builds on MSW:
Caldercraft HMS "Cruizer   Caldercraft HMBV "Granado"   Model Shipways "Prince De Neufchatel"
Love the tiller with blocks and rope work. Nicely done detail.
Beautiful work. A historical note: All Cruisers (all sloops of war, for that matter) carried a 12-pounder carronade for use in the launch during cutting out expeditions. Since the Reindeer shattered the barrel of one of the Wasp's 32-pounder carronades, the latter's captain took the 'short bus gun' aboard and mounted it in the destroyed gun's place. Since Wasp's chase guns were twelve pounders, there was plenty of shot available for it.
The Reindeer originally mounted 32-pounder carronades, but had to throw most of them overboard in a severe storm. The only replacement guns available for her at the time were 24-pounders.
Thanks guys, much appreciated. I need to get some better photos up. The lights over my work area are rather harsh.
Frolic: Thanks for the historical info, good stuff.
Joe Volz
Current build:
I took some much better photos  away from the harsh lights of my work table that show detail more clearly.
Thanks for all the nice comments above everyone.
As usual failing to plan and ignoring the issue is causing me a bit of headache. I have to get Sophie mounted on her display base and at this level of completion it is going to be a challenge. That's my next project before moving onto the yards. Wish me luck...
Joe Volz
Current build:
Sophie is safely mounted on her base now (should have been done a long, long time ago in the process...)
The base is Canarywood, which I routed a simple round-over  edge onto, leaving a small lip. The pedestals are Model Shipways brass. I had to shorten the slot depth with a razor saw as they were too deep for the keel. Scratches and dings were polished out and then I rubbed them down with Scothbrite to give them a brushed finish. I was going to seal them with lacquer, but decided I'll let them tarnish naturally, which will look good next to the copper.
Edited by jwvolz
Joe Volz
Current build:
Thanks Mike. Woodcraft has some nice lumber for things like bases. I've never used Canarywood before, but thought it looked pretty interesting.
Joe Volz
Current build:
The lower yards are now in place and some of the rigging is complete. I'm rigging them according to the brig Irene book. It's well researched and most of it is backed up by Steel and Levers. Note the crossjack yard only has a parrel and sling, no jeers per the book and well explained there.
Joe Volz
Current build:
Thanks everyone for the comments and "likes".
I've finished all the rigging on the bow area/spritsail yard. Again, rigged to the Irene book. I'll move on next to finishing installing remaining yards and then on to braces.
I took a picture down the length of the deck, thought it was a nice "crew-level"perspective...
Joe Volz
Current build:
I love the "crew perspective" shot!  And I can see why you chose that canary wood for the base -- handsome!
Overall, a build to be proud of.
Cheers
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Spent a ton of time in the shipyard and made a lot of progress over the weekend. All yards are now in place and have their lifts rigged. I've also rigged the topsail and topgallant braces, as well as the topsail sheets. Made a bunch of rope coils as well, where my variety of line colors becomes a bit obvious, but I'm sure there was plenty of variety in age among lines on the real thing. I'm holding off on the main braces until the rest of the upper rigging is finished so I have room to work. As it is I'm constantly bumping yards and lines while belaying...
Joe Volz
Current build:
