That was VERY funny indeed.
CHEERS
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Hey G
Ive seen some build fully framed this way - just curious as to your thoughts as to its advantages vs mounting fully assembled frames.  Does large scale have something to do with it ?
On 2017-2-13 at 2:24 PM, Gaetan Bordeleau said:
The next build.
Before to begin the construction  with wood, I want to have all the necessary information I need for the complete build.
-I do not want to have to do extensive research
-I do not want to draw plans
-I do not want to begin in 5 years
My prefered activity is to build and I want to concentrate on this particular aspect.
V4.0       for the forth time
74           I will build a 74 guns
1/24      I will use the biggest scale I can manage. For this one 1/24 is 8 feet long. This is
                about the maximum I can easily manipulate. I would have love to build even at
                a bigger scale like 1/12 but I do not have all the plans I need.
Jean Boudriot offers me everything I need. All the required information  is available in 5 books, not 4 but yes 5. I am a lazy person for this time, I will not draw the frames; JC Lemineur di dit and I will use it.
So, I have all what I need to begin :
-all the paper I need (the fifth book is in the mail)
-all the tools I bought tools for the last 30 years
-all the wood I need, at least for the frames.
I did build  1 version of the 74 with exotic woods. If I add the price of all the exotic woods used, you would not believe how much expensive it can be in these quantities.
Traditionnally, in Europe, they use pear wood  for the frames and boxwood for the carvings.
In my country, here in Quebec, there are no places to buy these woods and anyway it is too expensive for what I want to do.
Here in Quebec, 1 one of the most stable wood we have is cherry wood. In addition the properties ore similar to pear wood except for the grain; cherry has pear has not. For sandind both are identical. As a bonus, at leat for my taste, I love the smell of this wood when cutting or sanding.
Ou au Quebec te trouves-tu je suis de l'Outaouais j'aimerais bien et je me sentirais previlegié de pouvoir voir ca de mes propres yeux !
I added a new item in the personal protection department. I began with a pair of earmuff, a respirator with cartridges, a head gear to install  on a construction hat,  a 3M full facepiece.
I will begin soon  extensive  hull sanding and I wanted  a lungs protection easier to wear than  the respirator with cartridges.
The next step will be in the protection equipment PAPR (Powered Air Purifying Respirator).   The best equipment I found on Internet is the 3M Versaflo but it is expensive and you need to wear a belt for battery, motor and fan.
 Another solution at ¼ the price of that unit is the Trend AirShield Pro.  Wood turner use this gears. This head protection gear can replace all the previous gears I had. It is a hard hat with a face shield made of plastic and cloth. Under the hat are incorporated a fan motor, battery  and filters. Performance is surprisingly good. The head is enclosed in a mask with positive pressure so wood dust does not enter. Even if there is an air cleaning system, alone it does not filter the air fast enough.
I guess there is an exponential amount of dust produced as the scale of the model increases! Have fun, Gaetan....
I have used the Trend unit in the past, it is very good but can feel heavy on the neck after using it for a while, and the screen scratches easily.
Also uses cheap materials to construct for the price you pay for it. Filters are expensive and need to be replaced regularly particularly in heavy use
Battery is not Li-on so takes a long time to charge, Oh and the fan motor is very noisy
It also does not stop the whole workshop gathering a layer of dust.
One of the better protection devices for personal use agreed, but as they say the best type of dust control is not to create it in the first place.
Two pennies worth over
Finished builds are
1/35 Endeavour's Longboat by Artesania Latina
1/36 scratch built Philadelphia Gunboat from the Smithsonian Plans
Current build is
Scratch build Boudroit's Monograph for La Jacinthe at 1/36
Superman said with great power come great responsibilities.
The modeler says with a large model comes  a lot of dust,  it is part of the game.
Druxey,  you are right, plus the 3 feet  belt sander  can change the color of  floor in few minutes.
It is a robust tool (no distortion in the sanding angle) built to sand metal , knife maker use it to give edges very rapidly.
It is clear that Noel would not buy another one.
In comparison, it is more difficult to breath with with a full face or cartridge mask.
This I did not knew before I tried the positive pressure which is always bringing air.
The cartridge mask is directly on the face. not the other one.
Hi All,
Everytime I look at this wonderful build log, I can't help but think that the ship is large enough for a Viking funeral.;)
Best,
John
Member:
Connecticut Marine Model Society
Model Ship World
"So we beat on, boats against the current, bourne back ceaselessly into the past" F. Scott Fitzgerald - The Great Gatsby
"If at first you don’t succeed.......skydiving is probably not for you”
Before assembling the frames, fore and aft ends are began.
Actually working at the aft.
It is a long work which goes like this: try, sand, fit...
It is a long ladder to climb, the more level, the more precise parts will be adjusted.
The only question to ask is when is it adjusted enough.
Continuation at the aft section will continue to receive some parts.
Only after ''middle frames'' will be assembled
