1/16" x 1/32" maple strips were soaked in hot water for several minutes to create the curved base moulding around the supports. 1/8" x 1/32" maple strips were used for the vertical moulding. Some minor adjustments are needed before installation.
Steve
Edited by Tigersteve
Thought I'd take a small break from painting to dry-fit all parts again. While there are several more coats that need to be applied, I believe it's getting closer to an acceptable finish.
In this dry-fit I am looking at the thwarts and questioning if they butt up against the frames enough. I feel I may need to redo these so they butt up against the frames more. Any thoughts fellow Pinnace builders? Will this be a problem during inboard planking?
Steve
You were reading my mind. I couldn't figure how you were going to paint everything. Never realized that things weren't glued yet. :huh:
nice work Steve,
your pinnace looks great..
Nils
Current builds
-Lightship Elbe 1
Completed
The thwarts were recut and scrap wood was used to keep the proper spacing according to the plans. The grooves were made with a hand razor saw and miter box. After all thwarts were cut and placed, I used a scrap piece of the same width to mark the center lines for the longboard. The notches were filed last. Here's a photo after two coats of Wipe-on-Poly.
I plan to glue all this together prior to installation.
Steve
Luckily I did another dry-fit before any gluing. Turns out there was an error in marking the longboard location on the thwarts. Either that or I misfiled the notches. I should be able to redo two of the four thwarts and be more on point.
This particular modification with the longboard is tricky. A slight error becomes very obvious. This revision will take a while. I will post after all is installed.
Steve
Instead of notching the thwarts to accept sections of the longboard, I decided to notch one long strip where the thwarts would be inserted. This resulted in a straight board. Something I was not able to achieve in earlier attempts. The board was clamped from underneath and marked before filing the notches.
The thwarts were also notched to create a flush joining of the pieces. Lots of dry clamping before the final installation. I'm happy with the results and decided not to include the grooves for the sake of a crisp finish. I will have to remake the forward platform without the grooves.
Steve
Ditto that Steve - did I understand correctly, you filed those notches?
The inboard planking will be completed in sections due to the multiple curves required from bow to stern. I planked the cockpit section with pre-painted 1/16” and 1/8” strips. These will be filled and repainted when the rest of the planking is complete to hide any seams.
I am using basswood for this part of the planking.
Steve
That is a good question. I thought that the basswood was much more flexible and easier to bend and it will be painted anyway. (I had forgotten just how much after working with the maple.) I will use mostly 1/8” x 1/32” for the remaining inboard planking.
Steve
Steve - I'm reading a nautical oriented book taking place around the Revolutionary War. The guys are doing a lot of rowing around. Every time I read a section like that I picture this boat.
The inboard planking at the bow was completed by cutting pieces to shape. The curves needed were too extreme to edgebend. My paint job went to hell during the sanding of the cap rail. It is necessary to get the rail as thin as possible to avoid looking bulky. The overlap of the rail outboard is 1/32”.
My original plan was to leave the cap rail natural, but it looks unfinished without paint now that I see it installed. It will take some time to paint so here are some photos in the meantime.
Steve
beautiful work Steve,
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks guys. I added a revised photo in my previous post. Had to remove the cap rail behind the seat back. The shapes were loosing symmetry after more sanding and filing. Those sections of the cap rail were recreated and will be installed after I touch up the paint in that area.
Steve
The interior and cap rail painting is complete. Roughly twenty coats later with light sanding between some coats. One coat of Wipe-on-Poly applied.
Looking forward to seeing how it looks with the mouldings added. Before that tedious job, I will craft the seats for the helmsmen.
Steve
