My previous construction of a kit..
..is coming to an end, so it's time to start with a new one...
Another construction I'm starting is scratch build, I've decided for a ship from the 16th century, a galleon, which I always liked, specifically 1597 Roter Lowe..
I've had the 1:60 plan at home for many years, it's a copy of a well-known German plan..
The scale is close to fifty, still very detailed and mainly the ship hasn't got much decoration, which I do not dare make yet. I'm leaving 3D aside, I hope paper plans will do..
Right from the first comparison of copies of the two side elevations, I came across different front ligament shapes..
That's also why I decided to create a cardboard half of the hull and check the crossing of the ribs, and then do the plywood frame..
Ondras.
Done : President - https://www.modelforum.cz/viewtopic.php?f=177&t=90230
Under construction : Roter Lowe - https://www.modelforum.cz/viewtopic.php?f=177&t=114576
Member of the organizing clubhttps://wchs-c-2023.klom-admiral.cz/en
Hi Ondras -
This looks like an interesting project, a build of another 16th Century ship, and quite difficult, with your having to compare and adjust two different sets of plans.  I read through your prior build log, and you clearly have all the skills and talents that you will need for a fine rendering of the ship.
I have pulled up a chair and look forward to enjoying your progress.
Be well
Dan
Thank you for your welcome here. I have books ready to support the construction :
Wolfram zu Mondfeld - Historic Ship Models
Rolf Hoeckel - Risse von Schiffen des 16. und 17. Jahrhunderts
Herman Ketting - Prins Willem
Wolfgang Quinger - Wappen von Hamburg
Beginning "from scratch" is a bit different than a modular one, there is a lot to save and spoil..
As I said, I first created a paper half of the hull..
When laying a rail, some ribs really do not fit..
So I varnished the edges of the rib and there will be more grinding and adjusting . So treated ribs will be a template for plywood ones ..
Ondras.
Hello Ondras
Your ship looks a lot like my Golden Hind.
I'm following your building log.
The book "Risse von schiffen des 16. und 17 jahrhunderts" is very helpful to me.
Edited by Backer
Copied title from book 2 times
Hello Ondras
Hello. Golden Hind is my favorite galeon, but Roter Lowe has won, because it is bigger .. I'm looking forward to building and watching all the similar buildings, including yours .. Only the Holad boat is a bit different from English, which attracts me ..:D
Ondras.
Working with paper plans isn't exactly easy, but in the days before computers it was as well the only way..
The paper ribs really needed adjusting, making the radius accurate..
I transfered the modified shapes back onto the ribs. I transfered the heights and the shape of the deck
and then deducted future planking..
I thought about a way of gluing the body of the galeon's hull, so that it wouldn't twist.
I decided for a reversed variant, where the ribs stand in exact height on removable parts..
Finished paper ribs and keel are now ready for gluing on 6mm plywood and carving it..
Edited by Ondras71
Ondras.
I got the planks and wood for construction from the Czech model maker Petr Šimek. Light cherry, dark cherry, maple .. :D
Ondras.
On 11. 10. 2017 at 2:37 PM, marsalv said:
Hi Ondras,
nice to see you here with the new build:dancetl6:.
Thank you marsalv!!:piratebo5:
The coarse skeleton of the hull..
Ondras.
The frame placed on the base plate ..
I painted the inner edges of the ribs, which will be heavily bevelled, black so that I did not tear off the edge when grinding..
A glued frame ..
Added base plate of the bottom mirror..
After the bevels, it's time for the 5x2mm spruce strips planking..:)
Ondras.
On 23. 10. 2017 at 4:53 PM, Backer said:
looks good.
Well done Ondras.
Thank you Backer, I try to work honestly..:)
The correct shape of the plank hips is formed..
Bow and stern filled with balz..
Edited by Ondras71
Ondras.
Making good progress, Ondras. She's starting to take shape.
I have a rather more personal interest in this build than usual, as Lowe is my surname (although I'm not "red").
Steven
Edited by Louie da fly
The first plating of the submerged part is laid and ground..
The hull inside is reinforced ..
59fa30eb255bb_vyplnntrupupolyuretanovmlepidlem.(1).JPG.561e2e626d1087a6cd8a0ca20f478737.JPG
59fa30f0c87f2_vyplnntrupupolyuretanovmlepidlem.(3).JPG.742c035f9e4b4815fb10b1e7730254c7.JPG
The construction is solid, waiting for the second plating ..:rolleyes:
Ondras.
On 1. 11. 2017 at 10:59 PM, flying_dutchman2 said:
Beautiful work. Another bluff bow ship, just like my Utrecht yacht. I see that you did your planking the way I did it. Planking a bluff bow can be a challenge.
Marcus
Thank you dutchman2 :rolleyes::D:piratebo5:
Laying a cannonboard made of plywood 1 mm thick..
Edited by Ondras71
Ondras.
Lined and trimmed lower cannon deck ..
The sheets of plans are a bit disapproving, I'm solving the heights of the bottom shot..
Made guns holes of cherry wood ..
Ondras.
So I'm finally enjoying working with cherry wood ..
The gun ports are brushed to the side's shape..
I tried bending the cherry, the first 5x4 mm strip in two directions, it goes easily just soaked ..
I started to tile the mirror with bright cherry wood, here is the future contrast with dark cherry..
created keel, stern post, stem..
Ondras.
Further work on keel, stem, stern post ..
I created a HOME MADE bottom grooving cutter, I do not want to buy it..
I tried it and it works ..
Christmas present, another piece in the workshop ..
Ondras.
Placed stem ..
HOME MADE narrowing milling cutter..
Created radius for the rudder hole frame ..
A part of the mirror with a hole for the rudder lever ...
5a5614e714af9_ppravaotvoruprokormidelnpku(3).JPG.53b6ece2bedb97f4cc03be8cf82f3c83.JPG
5a5614eb085fa_ppravaotvoruprokormidelnpku(4).JPG.18f0a0a1faf4c9daa0c21f11929da73e.JPG
Edited by Ondras71
Ondras.
This looks to be a truly fascinating and instructive build.  You are making a very neat job of it, so far, and I will be following along with great interest.  I loved your router table technique for cutting the rabbet into the stem!
Thank you honestly zappto, Backer, HubacsHistorian..!!
I placed the keel, stem, stern post ..
According to the instructions I found on the Internet, I have created a tool for accurate ribbing..
And it works ..
And it works .. When ordering wooden strips I forgot to order 5x3 mm strips for wales, so I was forced to make them on a saw ..
Edited by Ondras71
Ondras.
Placed top wales made of 5x3 mm strips.. Bending it into an arc created an unsuitable shape at the stem ..
The end of the strip adjusted..
The result is satisfying ..
planking started..
5a662bf0c4c88_prvnlitapodwales (2) .JPG.5e5755ad888476b87e07b8dfa5f7eb7d.JPG
5a662bf858536_prvnlitapodwales (4) .JPG.42391ef01a3d41d23020f2b380ba94f0.JPG
Edited by Ondras71
Ondras.
