Queen Anne Barge by Rustyj - Syren Ship Model - 1:24
Hi All, I had the good fortune to obtain one of the Queen Ann Royal Barge's from Syren Ship Model Company.
I've decided to start doing some of the building while working on the Syren re-rigging. It will make a pleasant break
from redoing the yards and the running rigging.
The kit comes with two sheets of plans and numerous sheets of laser cut parts. As expected all were in perfect
condition upon their arrival.
First I started on making the frames. You can see a faint laser line across the futtock frame.
This is a reference line for placement of the frame floor. Using this reference line insures uniform
placement of all the floors.
The futtock and the floor.
A straight edge is placed along the line.
I clamped the straight edge on the frame, applied glue to the frame floor and then butt it against the straight edge and waited for it to dry.
A small weight was placed on the floor while it was drying.I can do two frames at a time. Hopefully care was used to not use too much
glue so I can later remove the center away from the futtock.
There are a total of 23 frames. 19 that have a separate futtock and floor that need to be assembled. While they are drying I'll work on the keel.
The fun has begun!
Rusty
"So Long For Now" B)
Current Builds: HMS Winchelsea 1/48  Duchess of Kingston
Completed Build Logs: USF Confederacy , US Brig Syren , Triton Cross Section , Bomb Vessel Cross SectionCutter CheerfulQueen Anne Barge, Medway Longboat
Link to comment
Share on other sites
Hi Rusty.
Will follow along with this one Rusty if you don't mind.
Got my front row seat and the pop corn.
Regards Antony.
Edited by AntonyUK
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Link to comment
I'm looking forward to watching this one come together. I missed out on the last batch and hope to get mine when they come available.
The heart is happiest when the head and the hands work together.
Al
Current Builds:
HMS Halifax 1/48 POF Lumberyard Kit
Model Shipways Glad Tidings
Acoustic Guitar Build FINISHED
Link to comment
Welcome aboard everyone and thanks for all the likes!
Antony,  There is an abundance of popcorn available so sit back and relax!
Hi Bob, The design of this kit just about assures success.
Hi Alde, It was a stroke of luck that I stumbled on it before they were sold out again! Good luck!
Thanks Steve.
Rusty
Link to comment
Definitely a follow along from me too.
Michael
Shipwrights of Central Ohio
Current Build: ...
Completed Builds: Queen Anne Barge - SyrenPinnace - MSHalifax 1768 - LSSMurrelet - PygmySwift 1805 - AL
Future Builds: Surly (because i'm definitely not so Cheerful), Echo cross-section.....
Link to comment
Welcome aboard Michael and Canute.
Whats great is all seats are front row! :D
Rusty
Link to comment
Thanks Ben. Glad to be building along with you again!
Hey Joe. Any thing for a successful build!
Rusty
Link to comment
Moving along I have assembled all of the frames. It went very smoothly.
I've also been able to complete the keel assembly. Chuck did a great job on the scarf joints. You did not need to sand the char off and the fit was perfect.
Thanks for stopping by!
Rusty
Link to comment
Thanks Chuck, you do make it easier though!
Also thanks for the likes!
Rusty
Link to comment
I will follow along too. Always a learning experience with your work Rusty.
Ian
Link to comment
Hi Ian and thank you for the kind words.
I've got everything ready to attach the keel to the frames. First the frames are placed into each half
of the base board. Some minor sanding was needed for each slot in the base board to get a good fit.
The frames can't be too tight or too loose in the base because it could cause problems releasing the frames later on.
Here are the frames set ready for gluing to the keel. After I took the picture I noticed an error.
The two 0 frames should not face in the same direction. One faces fore and one faces aft.
Thankfully I noticed it before I glued it up! Phew.
Here half of the frames are glued to the keel and drying.
Once dry I'll glue the other half to the keel and then fair the frames.
Rusty
Link to comment
Both halves have been glued to the keel, dried and fairing is mostly completed.
I've started prepping the spiled planks. They are 1/32" (.08mm) thick so they are delicate.
Laser  char is gently removed with a sanding stick. You will also see a faint laser etched
line in the plank. A bevel from the laser line to the edge was created with the sanding stick too.
Here you see a plank formed to fit by heat bending until it lays on the frames without being forced.
This is a whole lot of fun!
Rusty
Link to comment
Thats the way to do it!!!!  wonderful plank shaping.  It makes it so much easier to glue into position.  Well done :)
Link to comment
Thanks Chuck! Great design and having a ball.
Also thanks everyone for all the likes! Much appreciated.
Rusty
Link to comment
Hi All,
Here is the first row of planking on the starboard side.
And here is all the planking completed.
And the now released from the building board!
Rusty
Link to comment
Superb job Rusty. She becomes beautifully. A nice source of inspiration for me.
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • Santa Maria boat - Korabel (Ukraine) - 1:24
Link to comment
Thank you Jean-Paul and Ben.  Also thank you all for the likes.
Rusty
Link to comment
Thanks and welcome aboard Tim!
Thank Bob!
The centers have now been removed from the frames. Like Ben I found using a fine razor saw worked well for me.
Next is adding the cap rail and fairing the inboard frames.
Rusty
Link to comment
Now that the barge has been released from the building board it can be used to hold the model in the upright position.
Chuck supplied the wood pieces and now it is held firmly is place.
Next I sanded the tops of the frames flush with the planking in preparation of adding the cap rail.
The cap rails finished width is 5/64". you can see that a piece is plenty wide enough was provided.
You can see I marked how wide it would be when sanded to its proper width.
The rails were added and then sanded flush to the outboard planking.
I then marked a reference line to guide me while sanding the inboard  frames and rail.
I also used a 5/64"  gauge to ensure a correct width.
Rusty
Link to comment
Thanks Ben. I hope you are enjoying this as much as I am.
Also thanks for all the likes!
Rusty
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
