You're using enforced modelling time well Phil. Victory is really coming along in leaps and bounds 😁👍
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Thank you very much for all the comments and the likes!
The ladders are painted and installed:
30 posts for the rails have been made (including 4 extras):
The trim around the top of the opening to the Upper Gundeck has been cut, but not painted yet:
Stay healthy and stay safe!
Edited by GrandpaPhil
Building:
11 hours ago, GrandpaPhil said:
Thank you very much for the comments and all the likes!
The belfry is carved and assembled.  The bell is sitting next to it.
It still needs painted.
Kinda neat.
Carving these little beauties is a great way to pass time.
My admiral and I were talking about things to occupy one during these strange times.  I mentioned how so may people doing ships have their own little way of keeping their minds and bodies going.  She prefers sewing and puzzles.  I am currently struggling with rigging La Nina-my first ship.
2 hours ago, GrandpaPhil said:
Thank you all for the comments and the likes!
Happy Easter everyone!
Finished the belfry and installed it:
Currently working on the rest of the railings.
looking great phil,   all the best to you and yours mate.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Thank you very much for the comments and the likes!
The lower parts of the railings for the forward side of the hole going down to the Upper Gundeck are roughed out.
I used posterboard that I layered up four layers and reinforced them with superglue.
I got the idea to use the superglue reinforcing from Firdajan, here:
I drilled two holes in each of them to simulate sheaves.
I will put the rail on top of them and then carve tops for the stanchions from 1/8” basswood.
Here they are test fitted:
They are not perfect, but they will work well.  This whole project has been a game of “Make it up as you go along”.   It has been a lot of fun.
Building:
It has been working out very well for you from here. I frequently see card uses in logs, but I never think to use it while I am working. I really hope to be more "creative" when building in the future.
Card is a great material.  It is very versatile.  I never really did well with card (I generally do not do well with card kits) until I built the Prince de Neufchatel following Ab Hoving’s tutorial.
I made the railings from card:
I am making the tops of the stanchions from 1/8” basswood strip stock left over from the Prince de Neufchatel.
Building:
First rate work (no pun intended)  phil,   you should be so pleased with how she is coming on.
OC.
Current builds
Completed works.
Thank you very much OC, Richard, Rob and Keith!  Thank you very much everyone for stopping by and all the likes!
The stanchions for the forward rail are finished:
Following Keith’s recommendation, the tops of them are pinned into the lower parts of the stanchions (which I should have done anyways because the railings are poster board, which has a nasty habit of delaminating).
Building:
