Thank you very much, Richard!
Thank you all for the comments and the likes!
The bitts are installed and progress has been made:
I made part of another rigging fitting that I do not know the name to.  It looks like a large cleat.  I will post pictures the next time I work on Victory (soon).
Building:
The large rigging fittings are the staghorns.
I will work more on those later.
I am currently working on the poop deck fittings because the poop deck is completely empty and that is annoying me.
Here is the start of the skylight:
It should look more or less like this when done:
Edited by GrandpaPhil
Building:
Looking forward to this stage Phil,   you going to have a go at the flag lockers also?
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Thank you very much!
The railing on the poop deck is made.
The mizzen mast coat is done and installed.
The remaining stanchions for the ladders are awaiting paint.  They broke during carving and had to be glued back together.
 The pattern for the mizzen mast bitts are glued to the wood.
The horns for the staghorns and the patterns for the giant cleats on the poop deck are glued down.
I discovered from pictures taken by a member of this forum, and posted on YT’s build, that the flag lockers are removable cabinets that are not permanently installed.  I will make them after I make the knees on the transom (which are on my to do list).
Building:
Thank you Mark and Richard!
Thank you everyone for all the likes!
The railings for the ladders from the poop deck to the quarterdeck are installed and mostly done.
6884A4E0-5DB2-4DD9-A147-49BB33D4A17D.thumb.jpeg.d8501d641e5d5603300090fa344296b3.jpegBC437043-7490-4D4F-BE18-D4265BC2DAE9.thumb.jpeg.8d6d864fee9556b740be9d292cc2938f.jpeg
I ordered desert camouflage netting off EBay for the netting on the hammock cranes and the railings because it looks like the right color and mesh size for my scale netting.  The Tulle that I had previously purchased was out of scale and black, which is the wrong color.
In other news, I carved both poop deck staghorns.
Building:
Thank you, Emmet!
Two staghorns are made and installed.
The mizzen bitts are in the process of being made.  They are currently drying, because they keep splitting out.
2E0CC05C-4125-4146-993C-1F7B09A5B2DE.thumb.jpeg.eaf9a8202d3fa7d3740a93f2a7c43571.jpeg81441380-2BD3-44D5-84A2-FC03B02C1DB1.thumb.jpeg.21fcc2639d36928e86b77668102d911b.jpeg
The Victory has proven to be very frustrating at times because of the scale.
Yet my skills are improving as I go, so it is paying off.  I have put much more detail into a much more complicated model at a much smaller scale, compared to the Prince de Neufchatel.
This will help immensely on my next project.
Building:
Nice work Grandpa Phil. I especially like your use of card to make the skylights. I wish I had thought of that on my Terror model. I used veneer, which split and cracked maddeningly.
I'd like to see more pictures of your work on the binnacle as you go along. I can't find any mention of a binnacle in any of the research I've done on Terror, but I'm sure there must have been one. In the fictional TV show, which was in fact very extensively researched, there is a binnacle sitting on the aft skylight, which would be a sensible place to put it as the wheel is right behind it. I've been trying to work out how to make one. I'm going to copy what you do, if you'll be so kind as to document the process!
Edited by Keith S
Just catching up Phil, so much detail, you must be very dedicated to your task.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
