Thank you @cog, @DORIS, and @BenF89 for your 'likes'. I appreciate it.
______________________________________________________________
Filed the snipped ends off the bed railings.
Painted the bed linen and their aluminium frames. Also added more paint to the wardroom wall.
The Captain's chair is sunk into the floor, so I decided to cut it off and raise it (1 mm).
You can see the slight illusion I made with the furniture. Painted the carpet along all the furniture sides, then painted the wooden tops and legs. It gives the solid tables and stools some empty space.
Peter.
Current Build: HMS Beagle
Thank you @DORIS and @lmagna for your 'likes'.
I was getting a bit tired and lazy with the wardroom and ended up using some decals. Soon reminded myself why I prefer to not use them. However, they do come in handy with the really small details.
The kit showed an instrument panel decal for the captain's table. I thought that was odd, so I ended up putting it into use as a piece of electronics equipment for the sound (Hydrophone) room. Also included a table top and stool for that room. The decals for the Captain's room (bulkhead) looks out of place, and I wish I never used them.
I am building the model in sections, just like they did with the real sub. I fit loosely together the parts of a section which has an effect on how it fits with neighbouring sections or bulkheads. Holding it all together level and straight, I then tack the parts together with tiny bits of super glue. When secured, I simply pull the whole section off the previous section's bulkhead. Each section only has one bulkhead (forward). I am hoping to avoid a long one piece interior which the hull has trouble fitting over. In this way, each section can be giggled into place, with the hull, before tacking them all together.
Painted the viewable stb wall onto the hull.
Peter.
Thank you @hexnut, @Mirabell61, @BenF89@BANYAN, @Altduck, and @Canute for your 'likes'.
Not happy with the way the battery banks, below the wardrooms, are shown...well, they are not shown.
This Revell kit has done similar with hiding the stb wall by placing torpedoes on the top rack. Here, the battery banks a nicely shown, but to no avail if one restrict themselves to only following the instructions (they should be called guidelines).
For showing the batteries, the only way around this is to either dispense with the wardroom floor, or create a cutaway cross-section of the top battery bank.
Decided to explore the cross-section idea.
Ordered plastic filler when I started this model. I need it now to smooth out the cross-section, but I am still waiting for its arrival.
May still need to cut away some of the wardroom floor to shed more light on the cross-section. All the cutaway edges will be painted red.
Peter.
Interesting ... hope those batteries do not have the same fault as those Samsung smartphone ones ... I see I'm not the only one waiting for "building materials"
Carl
Still waiting for the plastic putty, but something else arrived. N-scale plastic figurines. They are 1/150, just 0.02" (0.5 mm) smaller than 1/144. They sure are small. Had to trim off a fair bit of excess molding, and some had really baggy clothes and shirts. It takes me a few minutes per figurine to get them to look more human, and ready for repainting. Will add them along with the build from now on.
Peter.
Thank you @mtaylor, @Canute, @cog, and @BenF89 for your 'likes'.
The little figurines are so small (for me) that even with magnifying glasses I do not see the glaring mishaps that the digital camera can pick up. It is from seeing the photos that I go back and somehow patch up what is missed.
Bottom centre photo shows a figurine, lean against the two bunker ends, glued in situ. In this way, the figurine stabilizes the overhanging bunkers and aligns the bunker nipples into the bulkhead when I later assemble the sections.
Peter.
Thank you @RGL, for your comment; and thank you @Canute, @BenF89, @mtaylor, @cog, @hexnut, and @lmagna for your 'likes.
I wish to create a mini-diorama in the battery compartment. A dramatic scene could be based on a dangerous situation is of a compromised battery: where leaking sulphuric acid reacts with salt water to release chlorine gas. This gas has a distinct yellow-green colour to it. The diorama is about a crewman investigating battery damage.
Glued and soldered two LEDs together which share a common cathode lead (earth). Had to file some of the plastic away first. Then soldered leads to the them. Installed the LEDs to the top battery bank. They are hidden, and hoping the two colour lighs will meld together. If not, I may have to use a medium that will aid in the blending. Anyway, much of the projected outcome won't be known until everything is in place. Fine-tuning will be inevitable for such a cramped dark space as the battery compartment.
While playing around with the battery banks I realised that there is a wall missing. It is part of the battery bay. Added more styrene.
To help increase light onto the subject, the back wall (hull) and ceiling got a coat of white gloss paint. Will add another coat tomorrow.
Altered one of the figurines to look as it he is creeping along the low central gangway, while holding a torch. Optic fibre is used for the torch. Eventually the LED and fibre will be blacked out, only having the light coming out of the torch end. Drilling into the LED to have the fibre inserted, and wrapping in foil really intensified the light through the fibre. It should look okay in situ.
Peter.
nice work on the sub so far.........your very handy with the brush  ;)   you have some really neat detail going on here........you've made quite a bit of progress since I last looked in.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you @popeye the sailor for your supportive comment. Much appreciated.
Thank you @popeye the sailor, @mtaylor, @BenF89@cog, and @Canute for the 'likes'.
Today I focused on the bulkhead between the wardroom and the Control room. decided to have the Captain entering into the Control room through the bulkhead doorway. Had to manipulate two figurines to get the right body position. Used some decals but still, if not more so, prefer using the brush. My hand is getting steadier while working on this model.
Peter.
I love the sense of movement conveyed just by having the officer posed halfway through the hatch. Gives life to the model!
Edited by BenF89
~ Ben
___________________________________________________________________________________________________
Current Builds:
'Doll-Boat' - 1:12 scale 40' Cruising Sailboat
S.S. Edmund Fitzgerald - 1:350 plastic kit w/ Photo Etch Parts (On Hold)
Thank you @BenF89 for your comment. It has inspired me to try and create more movement with the other figurines.
Thank you @Canute, @cog, @John Allen, @BenF89, and @CDW for your 'likes'.
Well, I finished the cross-section. I learnt that it is better to use a 3D cross-section on a 3D model than using a 2D illustration. Next time I will do it differently.
It was not easy to paint. If I held the brush in a precarious position to draw the line I would start to shake. Another lesson learnt is that I am more steady painting lines horizontally than vertically (turning the job to suit). Next time I'll do better.
Looks like chlorine gas is lethal.
Peter.
