4 hours ago, BLACK VIKING said:
Very nicely done on the shrouds OC . I love rigging apart from ratlines
Martyn
Thank you martyn,    yep I have the whole ratlines thing to go throgh as well.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
I spent a couple of hours on the pearl this eve  - It struck me that the shrouds will obscure and work that needs doing inboard,  this included the spar lifting tackle, so after researching how this is done on the pearl  - I firstly seperated two lengths of thread found out where they are tied off/lashed on the deck  - this is along the front bulkhead railing containg some belaying pins, so I did a couple of twists around the pins and added a dab of ca to secure.   I then ran the rope upwards and through the one side of the block  - then I rapped the loose end round and secured with some tape till I later when I fit the yard - I repeated for the other side.
Just a few pics showing what I mean  -
Current builds
Completed works.
20 minutes ago, cog said:
I would say: "Hang in there mate" you've got still some yards to go ... looking good
Thanks carl,   I was chatting with the wife about displaying some figures on her  - yep they do jack sparrow and crew figures in 1/72 scale             https://www.super-hobby.co.uk/products/Zombie-Pirates-48-figs.html  :dancetl6:
OC.
Edited by Old Collingwood
Current builds
Completed works.
"...some yards to go?" No pun intended there, eh? 🤔
Regards,
Don
"Unless you're out of air, it's NOT an emergency!"
Current Build: "Lady Nelson" by Amati/Victory Models
Current Build: "Polaris" by Occre
Current Build: "Battle Station" A Navy Board Model (Scratch Build)
Indeed.
OC.
Current builds
Completed works.
Work for tomorrow  -  smooth those two lift ropes (as they are a bit fuzzy)  using some watered down pva,    then I will start work on the main mast - same as I did on the foremast,  this is to allow me to make and fit the mainstay (as this will be more awkward with the  foremast shrouds completed).
OC.
Current builds
Completed works.
It's a shame that they say they supply 48 figures  but in reality it is 12 figures repeated four times, then they make you pay again for the other twelve figures repeated another four times!
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Indeed lou,   dont know what the quality would be like or if there are any others out there?
OC.
Current builds
Completed works.
3 minutes ago, CDW said:
You got something against quadruplets, Mister? 🙂
Just need to build three Pearls I think.....
OC.
Current builds
Completed works.
How did you know ... straight forward as always ...
Carl
I preffer  feet,   but I aint putting feet on those masts:dancetl6:
OC.
Current builds
Completed works.
Yeh, I'm politicaly incorrect! or is that socially impolite? Whatever it is I are.
https://www.super-hobby.co.uk/products/Zombie-Pirates-part-II.html
Same maker part two. Quality is what you make of them. It looks like you get four chances to get it right.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Good day all,  more work on spaghetti city (ropes)   first I assembled the mainmast mid section, and after painting and weathering I attached the lift rope blocks, then I glued the mast into place and made sure it was square with the foremast,   then it was time to work on my rope making rig  to serve the end section of the rope  - so this was the status as that stage  -
Current builds
Completed works.
Then I  cut the mainstay rope from the rig and placed it around the mast - I then tied and glued the loop and let it set,   I then turned my attention to the bowsprit and looped and lashed some rope around it,   I then worked on two double blocks still attached to the sprue (I thought it would help working on it still on the sprue)  I used some fine thread and fed it through both ends of the blocks then tied a knot in the middle - I then moved the knot along and hid it inside the block holes - this was repeated for the other sides of the block, a dab of ca secured the threads, this assembly was then cut away from the sprue and painted,  I then  attachetd the double block  to the mainstay/bowspit end  and tied/glued the end  - this was left with mainmast mainstay end dry fitted to the block  - hope that makes sense.
OC.
Current builds
Completed works.
Some sort of magician you are ... or did you use a flute on the rope? (Last picture)
Edited by cog
Carl
you can also wind a bit of rope around where the rope attaches to the pulley {the eye}.....to make it look more period to the model.  the pulley assembly looks good.......no crossed ropes allowed ;)    great job!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
 Not a magician  just  feeling my way learning as I go along mate.
OC.
Current builds
Completed works.
5 hours ago, Wallace said:
Your step by step account just shows how involved rigging can be. Nicely done O.C.
Thank you wallace.
OC.
Current builds
Completed works.
5 hours ago, CDW said:
Very nice rigging work OC. The plastic molded parts of this kit are very impressive. This is a Zvezda kit, correct? That company has come a long way since they were new. I remember some less than stellar products but now they are right up there with the very best of the plastic molded kit makers.
Its the Excellent Revell  kit  craig   - its very nicely molded.
OC.
Current builds
Completed works.
Thanks denis  - thats a good idea.
OC.
Current builds
Completed works.
Hi all,   some good progress today  - I made and fitted the mainmast lift rope,  this was tied and glued to the side handrail with a loop hangng down, same as before I then ran the other ends of the rope up and through the blocks, and looped and taped to be connected later.
I then turned my attention to the two stays - first I added some thin rope around the block ends, then I tensioned the stay - added a few drops of glue then lashed the ends with thin rope - after I ran a bit more glue and trimmed the ends,    so fore and mainmast stays now fitted and tensioned.
OC.
Current builds
Completed works.
Nice looking work OC. Moving right along.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
21 minutes ago, cog said:
Love the contrasting colour mate. Not so darkish as the rest of the ship. I knew you had it in you ... a streak of joy ;)
Thanks mate.
OC.
Current builds
Completed works.
Thanks lou.
OC.
Current builds
Completed works.
