46 minutes ago, pontiachedmark said:
Gidday OC.
She sure is looking good.
Wishing you and your family all the best.
Mark.
Thank you mark.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Evening/morning all,    thought I better sign in I havn't left the country  - just been a wee bit distracted elswhere,    I will be back on the pearl faster than you can say   -  Supercalifragilisticexpialodocious.:dancetl6:
OC.
Current builds
Completed works.
she's look'in sweet OC..........the rigging is coming along well  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you denis.
OC.
Current builds
Completed works.
Evening all  back on with the pearl  today,   I finished off fitting the top foremast shrouds., then I lashed them around the top to secure them  - they still need thier ratlines.
I then decided to make the foremast lower spar  - this is going to be wood made from dowel (the same with all the spars)   first I used the pre-molded spar/sail  as a template and cut the dowel to the correct length, then I marked each side of the dead center  where the taper will start - I then used a combination of my curved scraping tool and sanding stick to shape each end  - slighty time consuming and tedious, but I think I achieved the result - then I drilled the linking hole in the dead center and then fitted the two lift blocks at each end.
It will be painted/weathered then glued in place and lashed around the foremast.
Just the one pic showing he spar/blocks.
OC.
Current builds
Completed works.
16 minutes ago, Fright said:
Glad to see you're back at it!
Thanks Robert.
OC.
Current builds
Completed works.
2 minutes ago, cog said:
Why not replace the blocks as well ... while you are at it.
The plastic ones are quite good mate  and they have the rings on the ends making for better attachment - when painted I dont think you can tell the difference.
OC.
Current builds
Completed works.
16 minutes ago, cog said:
Pitty, thought to get you some additional work ;)
Thanks mate  - and theres me trying to finish it.
OC.
Current builds
Completed works.
4 hours ago, Wallace said:
Well worth the meticulousness (is that even a word?) OC, nice and symmetrical sir.
Thank you wallace.
OC.
Current builds
Completed works.
Just dry fitting the spar(yard)   to see how it looks.
OC.
Edited by Old Collingwood
Current builds
Completed works.
54 minutes ago, Canute said:
Spar looks good, OC.
Thanks Ken.
OC.
Current builds
Completed works.
Is it right to assume - all ships of sail would lower thier yards  on the mid and upper masts, when not set for sail and when in port.
OC.
Current builds
Completed works.
1 hour ago, cog said:
Looks fine to me, like when you had it off the mast ... miss a bitta colour though
Yep its gotta be painted/weathered yet.
OC.
Current builds
Completed works.
Ah, I caught up with your build OC, nice work!
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Cheers,
Thank you Piet.
OC.
Current builds
Completed works.
Good day all,  Firstly as always thank you so mush for all the imput and the likes,     more with the foremast yard,  I painted/weathered it  then ran the lift ropes through the blocks on the yard,  I then glued the yard to the mast and lashed it inplace,   then I pulled the lift rope taught at both ends and through the top blocks,   but during tentioning one of the blocks broke away  - so I had to make a way of conecting back to the mast top, I did this with some thread tied and glued - this repaired it but did leave both side slightly differently tentioned with the blocks at different placement from the mast head.
Anyway after painting the ropes to blend in with mast head - it kind of slightly hid my errors.
OC.
Current builds
Completed works.
44 minutes ago, Wallace said:
Looks fine to me OC, only you know where all those little misdemeanors are hudden sir 😉
Thnak you wallace.
OC.
Current builds
Completed works.
doing a great job OC...........and you were so worried about rigging  ;)    yard looks really good too
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Not a great day today  infact it was one of this flipping frustrating days at the bench  where I took about six steps back :default_wallbash:
First I started to do the upper foremast ratlines  -  talk about fiddly - my method using the tools I have was to cut a managable length of thin black thread  then tie a simple singke knot at one end then and apply a dab of ca direct from the plastic bottle (that did start with a fine end but the glue soon eats it away  - Locktite glue that is)  also battling with the nozzle keep blocking,   I use an angled pair of tweezers to catch the thread between shrouds and pull it through then simple loop over and a dab of ca, then the same at the end - then cut off at the shroud.
So far so good apart from the dabs of ca on each junction (they look messy)   so I finnished the ratlines on that section.
But  - I broke the lift blocks due to constantly knocking the yard,   so I decided to cut both away and start again, I tried to simply glue both lift blocks to the side/top/underneath of the tops - but I had no room to handle them due to the upper shrouds getting in the way, when I did manage to secure them (not securley)  I tried to run more ca around where they were joined  but I managed to block the holes with ca where the ropes are supposed to run through  - so I ripped them off   turned the light off and walked away from the bench slighly frustrated/annoyed and wondering why I bother to try to do things so frustrating and fiddly.
OC.
Current builds
Completed works.
because you can, and you like the challenge. So get your $%^&*!@# hiney back at that table and fix it!!! You are doing so well, and sometimes you just need to take a step back, recuperate and pick up where you left off
Carl
Just what the admiral said,    I will make some more lift blocks tomorrow and lash then around the topmast ontop of the mast cap  then re route them to the yard blocks.
OC.
Current builds
Completed works.
11 minutes ago, SHIPSCAT said:
Hey OC
Come on my friend don't let a little thing like that hold you back.
We know you can correct it easily.
Jo.
Thank you.
OC.
Current builds
Completed works.
