1 hour ago, Javlin said:
Most Excellent Recovery OC you prevailed were I probably would shelved or quit for that :imNotWorthy: Kevin
Thank you  kindly.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
11 minutes ago, Ebomba said:
OC, your build is looking spectacular and I think you brought to the project the same can do spirit that our fathers and grand fathers brought to the fight! Stay safe.
Best ,
Ed
Thank you Ed.
OC.
Current builds
Completed works.
Thank you All  for the  likes and interest in my build.
Today  I decided to have a go at the  Flat clear coat  curtosy of Tamiya TS80  Rattle can,   I was always going to be  "on the dge of my seat"  doing this  as I was worried about it bubbling up the decals  due to it being a hot laquer,   I decided to try it on the wings first  as the decs have been settled the longest,  first I warmed the can gently  with  tap water in a bowl (this helps the paint to mix)    then out doors  on the patio  (a bit windy to be fair  but  cant change the weather)   I tried to do a misting coat  - not easy with rattle cans,  I gave it about Ten minutes then over sparyed a few more times.
Seems to have worked ok  - I could see the paintwork smoothing out to a nice flat coat  and no interference  to the decals,  I then repeated  it on the other wing,   I then did the same to the fuselage.
Trouble is  trying to not get the fumes from that damn Laquer paint/top coat is impossible in our house.
Why o why cant they do Acrylic  in  Rattle canc?
OC.
Current builds
Completed works.
18 hours ago, Old Collingwood said:
Thank you kindly Edward,    the only thing  that is scaring the living daylights out of me is  spraying the Tamiya TS80  Clear top coat  rattle can, I have no choice  it has to be dulled  and the rattle can is the only  smooth way I can do it,  so yep  it is worrying me.
OC.
Looks amazing OC!  Nice job!
Yesterday I used Mr Color Matt from a spray can on one of my current builds.  Couple of light passes and it dulled the plane nicely. I’m sure Tamiya will do the same and be just as easy 👍
Was that a Rattle can mike?    my paintwork/flat coat  has to be either  brush painted or rattle can,   but the most important requirment is for it to be Zero Fumes.
OC.
Current builds
Completed works.
Bit of a funny tail  (didn't know if I should post it earlier)  - when I was top coating my fuselage  I was holding the mossie  by one of the rear stabs  and wearing a throw away glove  - all normal at that point, anyway  I then went and grabed the other stab (that had just been  sprayed😮)   and got a loverly Black finger print on the camo.
I was outside yelling  ####$$$$$$$&&&&&&   couldn't believe it   (dont put down technical ability  when stupidity spoils it)
So now I have to decide how I can rectify it without causing too much damage to the camo  - possibly a very very light  wet and dry  to try to remove the fingerprint.
"Fun and games  - fun and games"
OC.
Current builds
Completed works.
Just took these pics of the bits in my box drying/de gasing,   it shows the damage to the Left  rear stab  (I used a little wet and dry it has gone through the paint a bit  so I will have to mask and re spray  the Grey  section).
OC.
Edited by Old Collingwood
Current builds
Completed works.
Minor hitch in the giddyup brother, well within your skills as I have seen right on this log.... Don't sweat the small stuff and that is small stuff..... Just make sure it is completely degassed before you try and fix it...
Beautiful work a mossy to be proud of.... (I'm sure your father would love it)
Thank you kindly EG,   yep its just a "Bag it job"  to mask all the fuselage minus the area to be re sprayed, then after a few days  another blast over with the top coat.
OC.
Current builds
Completed works.
Cant believe it  over 12.000 views  just on a model plane.
Thank you all  so much.
OC.:dancetl6:
Current builds
Completed works.
Well earned my friend a journey to be enjoyed and a tribute to be respected.....
Edited by Egilman
Quote:
5 minutes ago, Javlin said:
For a rattle can paint job she came Quite Nice OC!!! ;) Kevin
Thank you Kevin.
OC.
Current builds
Completed works.
Thank you for those kind words EG  - means A lot.
OC.
Current builds
Completed works.
Nice recovery OC. No one will ever be able to tell what it looked like last week!
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Thanks Lou,     yep  its  getting there  bit by bit   wont be long till I can join the wings  - just a few  little things to do next.
OC.
Current builds
Completed works.
getting closer to the finish line........look'in really good!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you Denis  - yep  wont be too long I dont think.
OC.
Current builds
Completed works.
20 minutes ago, kpnuts said:
That's looking amazing (I toyed with the idea of getting the airfix 1/24 scale but since I've never built a decent plane decided not to) this on the other hand looks great.
Thank you so kind,    yep its a nice kit  - has its issues that need fiddling  like the fuselage halves  joining, and the engine units  fitting them over the wing is a pain,  they need filing/sanding  and then a bit of filler.
But over all  it is a nice kit.
OC.
Current builds
Completed works.
Hi all,    I spent a bit of time on mossie to day,  the rear stab was nice and dry  so I gave it a few watery coats of Acrylic  grey  by brush - all good, I then took off the masking  and noticed the main decal on the one side had  crackled,   the trouble is  there is a  coat of  laquer  flat coat  that was sprayed over the top,   would micro sol  work on  it  to smooth it out  even though there is a coat of laquer over the top of it.
Looks quite bad  and spoils what has turned out to be a  good finish.
OC.
Current builds
Completed works.
OC.
I feel your frustration. I don't think microsol is going to work if you have lacquer on it as it needs to penetrate the decal to soften it. I am not an experienced aviation modeller and I don't know what may have caused that issue, but I do hope you find a solution as it's looking great. Best of luck with it.
Thank you for having a look  - much appreciated.
OC.
Current builds
Completed works.
4 minutes ago, CDW said:
You are having a string of bad luck on this one OC. I don't know any easy way to fix that in place.
Tell me about it  - its like  its a jinxed plane,   the funny thing is  all the other decals are just fine  - nice and flat  and blended down with the flat laquer.
Its not an easy operation by any standards  even holding the  thing while spraying  is fiddly  then the blast from the rattle can, trying to control that is impossible, I have to do it freehand  as I have no way of spraying into a booth  or rotate the model on a turntable.
Who ever said modeling was easy  (well the painting side anyway)
OC.
Current builds
Completed works.
Brother, did this happen to just this one side?
Quote:
Yep,   the other side is fine,   I  have just this moment  gone down stairs (as its night here now)  and put a coat of micro sol  over the affected  decal/s  I will check them in a couple of hours to see if  (by miracle)  the micro sol has  worked - not holding my breath though.
The problem is  that top coat of Tamiya Laquer  is key  as it will either stop me working on the decal, or  if I decided to try to remove the decal using tape to pull it off  - I think the laquer will stop it  or at worst pull a larger area of paint and laquer with it.
OC.
Current builds
Completed works.
