Looks like you've got  it back OC. Done a grand job again😁
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
The wings were not affected  (thankfully)    that wing above was the last  to be painted  and hasn't  had that  Acrylic top coat  problem  (And Wont)   but pleased how it has come out.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Oh  foregot to mention  - the exhaust manifold colour  is a made up mix  of  part red ocre, part  flat alum  and part  black  then just mixed till I got that colour.
OC.
Current builds
Completed works.
sorry to hear of your misfortune ....glad to see your on the road to recovery  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you Denis.
OC.
Current builds
Completed works.
Great save so far! I’ll have to keep your resolve to salvage it in mind for the inevitable mistakes that I do in the future! I’m glad to see the restoration; it was and is again looking very nice!
Thank you kindly,  I will admit  it nearly  took off   out the back door, but I counted to Ten instead  stomped my feet  cursed a bit  - and felt a lot better,  I did get a few words from the admiral though  along the lines off  "Why make them if they make you so upset"
OC.
Current builds
Completed works.
Just caught up with your Mossie build thread OC. So sorry to learn about your paint troubles.
I don't want to muddy the water here, but I have to say, I use lacquer based primer on almost every model I build. As a rule of thumb, if you can smell the paint after the application of it, it's still gassing out. When you can't smell it, it's gassed out. Simple as that. I never have an issue with any other paint over a lacquer primer, provided it's gassed out. My favorite primer is either Tamiya (in the bottle) or Mr Surfacer (in the bottle) reduced with Mr Hobby 400 Leveling Thinner. Tamiya spray primer is good, too. Just make sure it's gassed out (smell it).
Tamiya bottled paints are notoriously bad for brushing. They need a retarder added when brushing. When I use their bottled clear, I always thin it considerably with Mr Hobby Leveling Thinner (40% paint to 60% thinner), sprayed on with an airbrush. It just does not give good results brushed from the bottle. I know it's too late now, but just for future reference.
Thanks Craig,   much appreciated.
OC.
Current builds
Completed works.
I use the Alclad Gloss Black Lacquer  one for black basing and for it's adhesion but I am trying to understand exactly the gassing terminology it has a strong odor upon being laid down.
OK I think I have it had to read it a few times so once the paint has been laid you should not be able to smell the paint on the model?
Yes. After you have applied the paint and it's had time to dry (to the touch), it's gassed out when you can no longer detect the smell of the paint. If you smell it and it smells like paint, it's still gassing out.
I think some people have missed my point, you do not put Acrylics over FRESH lacquer.... you HAVE to wait till the lacquer is completely dry. And yes that means it has to pass the smell test.... just simple dry touching will not cut it...... Even though the surface will be touch dry and your fingers will not stick, it is still outgassing and that is what causes the problem....
Craig is telling you true.....
Me, I don't have the problem with it cause I do not use acrylics, don't own them and never will... So I don't have to worry about it and sometimes I forget to fully explain....
Thanks Craig for picking up where I dropped the ball...
Quote:
Thank You ALL  for taking the time to expalain this  - its important info  that will  help avoid  disastors like what happened to me - but also anyone else in a similar  situation.
This I why  I Love this site and all  who post  here.:cheers:
OC.
Current builds
Completed works.
Sounds like we have the same Admiral 😋
I'm glad you didn't launch it for it's short farewell flight.
Keep the Faith OC.
Current builds;
Completed:
Keep the Faith OC.
Thank you Edward.
OC.
Current builds
Completed works.
when I decant paint,  that's usually what I do.   I leave the cap loose and stir it a few times to work the propellant out.   the reasons to decant is two fold........to obtain the color you need in the event that it can only be found in rattle cans,  and to use air to atomize the paint,  rather than propellant.  I think that it too can be a factor for bad outcomes.   paint must be fully cured,  before moving on to further steps
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Some more good work  today,   first thing was to fit the Two  lens units under the wings  - these just popped in with a bit of ca run around the edge,  next was to fit the Two radiator flow control vents  under the wings, these were then painted same as the underside.
Then the biggy  - adjust and fit the other main  u/c  unit, again this needed  some sanding  then a good measure of ca to get a good bond,   the tricky part was locating the adjustment leg struts  (I had to keep pushing them in place as they had some flex).
Also  here is a pic showing the first stage of the re - paint.
So this is the current situation.
OC.
Current builds
Completed works.
OC.
Looking good my friend....
Quote:
Thank you kindly.
OC.
Current builds
Completed works.
A bit more done this eve,   Next to be attached to the wings  are the u/c  doors,   first I cut then off the fret  then I gavIMG_0359.thumb.JPG.a4a8dfa59aeeb358c34ebe9fc30f36c2.JPGe them a paint and weather,  then they were glued in place and touched up a bit after fitting.
One wing done.
OC.
Edited by Old Collingwood
Current builds
Completed works.
Looking great, OC.
8 minutes ago, mtaylor said:
Looking great, OC.
Thanks Mark.
OC.
Current builds
Completed works.
great progress OC :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you Denis,    same to be done on the other wing  with the u/c doors, then I will be back on the fuselage.
OC.
Current builds
Completed works.
Mossie's looking fine OC, very nice recovery 😉.
Current builds;
Completed:
7 hours ago, cog said:
Nearly back on track mate. Doin' well despite the setbacks
Thank  you Carl,   yep  slowly slowly catchy monkey    means I can control what I am doing better.
OC.
Current builds
Completed works.
Thank you edward,   was  hit or miss    when I saw the state of the fuselage after painting on that Acrylic gloss top coat I nearly cried,   so glad I ahd not attached the wings and stabs and painted all over.
OC.
Current builds
Completed works.
Not much to report  tonight  just the fiiting of the other two  u/c leg doors  (fiddly little fellas)   is it just me  who feels like I have gone Ten rounds with Mike Tyson  at the bench   and need a rest  afterwards.
OC.
Current builds
Completed works.
Hi all,    thank you for all the likes and comments,    so  while waiting for the paint on the fuselage to harden,  I decided to do a bit more detailing on the wings  with shading and highlighting  to give it a bit of realism.
OC.
Current builds
Completed works.
