My last post is from April. I have not stopped building but my mother in-law has fallen terminally ill and she has taken most of my and my wife's attention the last couple of months.This is the update for now. The stern is coming together and have been working with gun port lids on lower gun deck.
UQMWFztUJ36kIIB5wzYAAAAAAHxgNl8-F7csNMk?
Best regards
Henrik
Edited by Henke
Problem with picture
"The secret of getting ahead is getting started" - Mark Twain
Henrik, sorry to hear your news. Your Aggie looks good, please keep us up to date.
Regards,
Bruce
STAY SAFE
current builds:
Sorry to read the news.
I hope that things goes a little normal now for you and the family.
I almost see my own Aggy 🙂
Great job.
Sjors
Edited by Sjors
First thanks for thoughtful comments Bruce, GrandpaPhil and Sjors. It helps.
And now two pictures of this week's efforts.
UQMWFztUJ36kIIB50jYAAAAAAH5UgJ51aL87qbo?
UQMWFztUJ36kIIB50TYAAAAAADHpuoFER6uNYkg?
Regards
Henrik
Edited by Henke
Coming together nicely there Henke!
Precise work on those bits and pieces 🙂
Sorry to read about your personal burden. Hope you and yours can find strength together!
Keep it up!
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
This week I have been working with the upper gun deck guns. Starboard side is now finished (guns on lower and upper gun deck).
UQMWFztUJ36kIIB56TYAAAAAAAvV9-iSmhta3-E?
UQMWFztUJ36kIIB56jYAAAAAABN_kHBJh-3umO4?
Best regards
Henrik
Edited by Henke
Dear friends,
I have come to the section of the building instructions called Hull side fittings. My question is about the chess tree fittings, item 138 below. It is far too long compared to the drawing.
1. Which side of it should be up?
2. Should it be shortened? If so, which end?
Instructions say it will need filing to sit on the side of the hull correctly because of the upper wale and slotted strip/brass profile. I have not done that yet. Please help me out on this? I suppose the slot is for a sheave or pulley wheel. My upper wale is perhaps 1-2 mm off-set compared to the drawing but the drawing is 1:1 and when I compare the chess tree piece 138 to the indicated length in the drawing it is far from right.
UQMWFztUJ36kIIB59jYAAAAAAAQrviOwhomh9Xc?
UQMWFztUJ36kIIB59TYAAAAAAGUieOYz48uzGtQ?
UQMWFztUJ36kIIB59zYAAAAAANe7JrkbttdB_cw?
Best regards
Henrik
Edited by Henke
Henke,
Is there any indication of where the slots is to be on the drawings?
It might be that your chess tree piece is just oversized.
Knowing where the slot is on the plans and you should be able to sand the piece to correct size.
Or create a new piece from scrap wood using the measurements from the plan.
Good luck and I know you will find your way to make this correct.
Lycka till!
Respectfully
I would send Caldercraft an email.
Keep up the great work,
Mort
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
If the rigging is like my Victory, the chess tree is for the main tack in which case the slot should line up with the hole in the hull for that tack. Going by your plan and photo the slot is ok but the chess tree top needs to be cut off.
Henrick,
I am sorry to hear about your mother-in-law.  I sincerely hope that she is comfortable and has the  comfort of family. God bless you, your wife, and, certainly your mother-in-law.
Your model is superb so far!
Bill
Thanks Bill, Ian, Mort and Per for nice comments and good suggestions. I think I now know. A look at some other Agamemnon build logs gave me some clues and a good look at one of the rigging plans solved it. The chess tree piece with its slot, which in reality has a sheave or pulley wheel in it is for the main sail tack. I have now glued it in place as shown below and cut off the top. The tacks which are to be fixed on the inside of upper gun deck need to be fixed before main deck is laid. I have to remember that!
UQMWFztUJ36kIIB5-DYAAAAAAE377catAfHE094?
UQMWFztUJ36kIIB5-TYAAAAAAL9vJl4Iuz7O92w?
Best regards
Henrik
Edited by Henke
Have been working on bits and pieces over the week. I added gun lids to upper gun deck, some decoration to the quarter gallery and the balcony railing on the stern. The balcony railing was fiddly but finally I got it in place.
UQMWFztUJ36kIIB5-zYAAAAAAAoTuwoTNR_8eJw?
UQMWFztUJ36kIIB5_DYAAAAAAD2qwpr0y0D4oec?
Best regards
Henrik
Edited by Henke
This weekend I have been doing channels. Very fiddly if you ask me. To  make them sturdy I drilled two holes on the back side towards the hull in which I put two nails backwards into the edge of the channel. Then I gently pushed the channels towards the hull to create a small punch mark. I drilled 0.7 mm holes as guidance. This way it is possible to try out the correct position. Twice I actually drilled new holes 2-3 mm aside to get a better position. Anyhow the edge of the channel hides the old holes.
UQMWFztUJ36kIIB5CTcAAAAAAOSjrASPp3rkjDE?
Best regards
Henrik
Edited by Henke
What isn't a fiddly business at 1:64?
Haven't said it before, but I think the stern galleries came out really nice. Good job Henke!
Keep it up!
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
Thanks for all likes and comments and particular to Håkan. We are many who like 1:64 scale. When building a large ship like Agamemnon it is a nice trad-off between detailing and physical size.
And now some pictures of this weeks progress. I have been working on the channels and the final detailing of the stern gallery (starboard side). Starboard side is almost finished.
UQMWFztUJ36kIIB5DTcAAAAAANH-O27NHr95KjU?
UQMWFztUJ36kIIB5DjcAAAAAAKls_7HCscX0PrQ?
UQMWFztUJ36kIIB5DzcAAAAAAP3orYzoEWycnyw?
Best regards
Henrik
Edited by Henke
Starboard side is almost finished. I decided sometime ago that I would do sides in turns. Now port side...... I know it will be boring but at least there is some activity in my build log. This weekend´s work has been quarter galleries.
UQMWFztUJ36kIIB5GzcAAAAAAI83FyKjqm3Ehl4?
UQMWFztUJ36kIIB5HDcAAAAAAJmMQSrNQL0tGlw?
Best regards
Henrik
Edited by Henke
Nicely done!
Respectfully
Very nice Henrik! Quick question, did you 'glaze' the windows with clear plastic or leave them open? Not sure what to do there...
Trent
Trent
Current Build: HMS Agamemnon (1781) - Caldercraft 1:64
Finished: Bluenose  (1921) - BillingBoats 1:65
Sadly Foundered: WASA (1628) - BillingBoats 1:75
Hi Trent,
I have chosen not to glaze the windows. There is black plastic with the kit for glazing but I have chosen not to use it. The window frames are airbrushed white which gives them a sharp a clean look. The inside of the galleries is painted dull black. You have to look very close to see there is no glazing. There is also a risk you mess up the window frame painting by adding glazing. I think it looks ok as it is. I am the type of modeller who thinks it is more important to have the look and feeling rather than trying to replicate every detail exactly. I call it artistic freedom 🙂 but I also have the greatest respect for modellers who think differently.
Best regards
Henrik
11 hours ago, Henke said:
Hi Trent,
Best regards
Henrik
Henke,,,   your model looks absolutely fantastic,,, your windows look very very nice and in my opinion don't need the plastic windows...  if it wasn't for "artistic freedom" there wouldn't be models or art.....
Jim T
Current build:  HMS Agamemnon - Caldercraft - 1:64
First thanks for all nice comments and and likes. It is encouraging. Last weekend there was not much modelling. My wife ordered me to build IKEA furniture instead ☹️. Anyhow, this weekend I did some work on the stern. She now has a name.
UQMWFztUJ36kIIB5xjcAAAAAAJqpnEuovBFIryk?
Best regards
Henrik
Edited by Henke
It has been a while since my last post. Since I finished the stern ornamentation I have been doing the port side guns, gun lids and this weekend channels.
UQMWFztUJ36kIIB5yzcAAAAAAPYIEmS4XaXNYlA?
UQMWFztUJ36kIIB5zDcAAAAAAF1Kzzc2lLsMTvg?
Best regards
Henrik
Edited by Henke
Even small progress, is progress Henke 😉
Those channels looks good.
Keep it up!
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
I like the dead eye setup. Nice job.
Respectfully
