Well I have finished building the 1:1 boat so now I'm doing the model. The plans are drawn at 1:8 scale so I'm going 1 to 1 off them which is very convenient.
I aim to make it as much as the original is made as is practical, including using the same timbers from left overs. The exception to this is the transom because the original is rosewood but the grain is so open it was barely usable at 1:1 so I'm going to use mahogany instead.
When I met Mark Pearse a while back I mentioned that I might do this and he was very keen that I should so here you are Mark.
The plans have all the lines I need so it was pretty easy to draw it up plus the understanding of having already built it goes a long way.
1903593404_OnlakeBG.thumb.jpg.0c9ebcf09c1be13d6fd9981d768afb69.jpg20181120_161711.thumb.jpg.af88e48c18f27740e43e2d1e45ed677b.jpgsail18.jpg.49bf25157afefd6c509307d2433530df.jpg
DSCF1465.thumb.JPG.e655283772ecc4d883729bfdebcedc48.JPGDSCF1466.thumb.JPG.6385ca941eb11e9214f141c857e6a5b0.JPGDSCF1458.thumb.JPG.cc196be6b8725cd2b5e22887fbb99341.JPGDSCF1461.thumb.JPG.2499917de3620a9a71718636931e247a.JPGDSCF1462.thumb.JPG.255f201fb3404977e06be1d8c281ac92.JPG
Thanks Jim, I'm sure it will and at the scale of 1:8 detail should be easier than normal.
She'll be one of very few models with sitka spruce spars I'd imagine.
The planking will be interesting because the full size model had them cnc router cut to shape but I'm going to have to take the lines from the hull as I go in this case and they are some interesting shapes!
lovely clinker style boat :)   you did very well in making the lines so subtle......gives her some character.   so,  is this a plug your creating?  pleased to follow along :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Popeye, thanks for the compliment.
I am building her again exactly (almost) the way I built the original. The building form shown is a 1/8th scale representation of the original and will be scrapped once the hull is finished and righted for fit out. Each individual plank land is cut into the molds to aid correct fitment. I even have a sheet of 0.8mm plywood on order for the planks.
A little more done, this time I steam bent the apron while the original is laminated.
I've joined the keelson to the apron and started fairing the keelson to accept the garboards but here I have to stop because I'm waiting on a sheet of 0.8mm plywood from which I'll laminate 2 layers and then a layer of mahogany to make the transom before I can finish fitting and fairing the keelson in preparation for the planking which will be done with the 0.8mm plywood.
DSCF1467.thumb.JPG.418ca9c6f1dd71be81f81f444f8c2b3a.JPGDSCF1471.thumb.JPG.2b77efc86abf385ad8c0aefadd3a69d3.JPGDSCF1472.thumb.JPG.6c4d640c05629a4df2278c1199073710.JPG
Quite appropriate John
On that, when Neil Armstrong died I worked for a car dealer, in the workshop. In the lunch room I saw the headline on the paper and said "I saw that man walk on the moon" crickets, tumbleweeds. I was the only one old enough to have seen it 😕
I had a set back with this project. I'm guessing that the heating inside caused the building "spine" to warp a bit so everything went out of whack. I walked away from it for a while!
Hopefully the problem is now solved by using different materials and approach. Everything is now clamped and aligned very nicely.. Rather than removing the molds to add glue and re-position them I will cut several small blocks and just glue them into the right angles in the jig so it all stays aligned.
Now that I have the molds sorted I've been able to attach the transom and the keelson is now glued to the transom with the same strengthening knee I decided to add to the full size boat.
Port garboard is on!
I knew I had drawings of the strakes at a small size to show how they went together. As luck would have it the drawing is at 50% of the build size so I just had to double the size and tweek them a bit to make them fit, well the first one anyway. The ply at 0.8mm is easily cut with good scissors which makes life easy and means I can cut the strakes inside, no sawdust!
So the clinker effect is created by paring back the next section of frame to the notch? I’m used to seeing the top of the plank shaved back to receive the bottom of the next plank. Is this how you built the 1:1 version? Seems easier.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Greg, the 1:1 molds were stepped to locate each strake and give a flat land on the mold for the strake. The lands between strakes were still planed to give a proper mating surface. So if you took a completed boat and pressed a giant profile gauge into it you'd get the shape of the mold if that makes sense.
The stepped molds just worked as a guide so all the strakes overlapped by the correct amount etc.
It's very hard to replicate at his scale because the ply is only 0.8mm thick so in this case they are more just guide lines to work to.
This pic doesn't show it very well because it's of a concave part of the hull and the next strake did fall flush on the garboard at that mold but was then rebated into the garboard as it flowed to the transom. You can see the step for the third strake and a straight edge placed on that land would hit the edge of the second strake so you remove material from the second strake until the straight edge lays flat on the third strake land and fair it to the next mold etc.
Edited by Bedford
More progress, both garboards, skeg and keel fitted. On the 1:1 the keel was in 2 pieces joined aft of the centre board slot but on the model it's 1 piece from the fore foot to the transom. I will cut the centre board slot on the mill with a 3mm bit.
DSCF1484.thumb.JPG.19ce4ff315407aaaeadfefe75025ce93.JPGDSCF1486.thumb.JPG.3d9e9490b330611ff8d0676cbd076c28.JPGDSCF1487.thumb.JPG.aa7127c9d641ca9b2a1bfa2c0021d13d.JPG
I found that letting the next plank into the previous one at stem and stern required a fine chisel or miniature shoulder plane. Found a plane online but a bit much $$ and a bit big so I made a chisel from a short length of 1/8" HSS tool steel and it works a treat!
Next problem was applying the glue along the length of the plank without it skinning over due to reverse cycle heating, I needed a quicker way to apply it so I made a glue syringe, it's short and fat (the plunger is 10mm diameter) with a 1mm nozzle. The glue goes on very quickly now.
Oh my, of course you made that little beauty instead of buying one! I cannot remember where I came across a quote that seems relevant but I shall paraphrase. "Buying things is for suckers!" Well done, indeed.
The beauty of making it is I get exactly what I want. It is short and fat so it fits entirely in my hand and I just have to apply slight pressure as I run along the joint rather than a long contraption that requires greater muscle movement and is therefore less accurate.
1 hour ago, AndyG said:
 Is there something in the air😀
Yeah, the mains'l and jib when it's warm enough to go sailing!
Meanwhile I've now got the model of my boat half planked!
More progress, the exterior of the hull is finished and is ready for paint. I have to work out a way to turn 5mm brass rod into 3mm "D" profile to create the rubbing strips.
DSCF1511.thumb.JPG.4a1f931de9ee4c1f5b5039765b957fcb.JPGDSCF1512.thumb.JPG.8dc4a8eb086ad127342ff4948dc97d0e.JPGDSCF1518.thumb.JPG.2f900cc725c76d8207e2b27c618665af.JPGDSCF1520.thumb.JPG.0f622b7e1d65b8e1d53062316292b4d4.JPGDSCF1528.thumb.JPG.48a66e4aa49b6fbad4cb275b79554264.JPGDSCF1530.thumb.JPG.0a7016a272532f129373dafc132751e0.JPG
Yeah, Iain designs beautiful boats and having built it in 1:1 it's pretty easy to replicate at 1:8, they just go together so nicely.
The captain comes down to the shipyard to cast his eye over her every now and then
Edited by Bedford
fix typo
