Hallo Beckmann ; Laufbohle is "caillebotis" in french and "duckboard" in english ... but i am using an electronic translator and maybe it could be wrong !  Ebony cannot be bent but is as strong as metal => can be put into a milling machine for making the duckboard pieces. Cheers, Empathry
Great planking job!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
I have to agree with all the other comments posted here.  Your planking looks fantastic.  Great job!!!!!
Till next time.....     😎
Steve
Finished:              Artesania Latina Constellation;   Model Shipways USF Confederacy:  Medway Longboat 1742 - Syren Ship Model Company
Current Build:     Syren's Winchelsea
Thank you everybody for the comments, - as I said, these tutorials make it easy to achieve a nice fit of the planks. I switched now to the other side of the hull. Christmas vacations are over now, things will proceed slower from now on.
Looks pretty darn good to me.  I'll be very happy if mine turns out somewhere near that.
Great work!!!
Steve
Thanks everybody for the comments and likes!!
I learned two or three things while doing this:
The bulkheads need to be in perfect shape. If not (and mine are not) it can happen, that you get a bump in the surface. And then, if you sand everything, you suddenly see the bulkhead. I had that at two points. I had to change those planks, wich is really not a nice thing to do. The other thing is, that the planks should not be too thin.  Better more near to 2mm than 1,6 mm. That makes is all more safe and stable. And the better you bend the planks before glouing, the better they fit. Forcing it in position always makes problems. There is a saying about building houses in Germany: Make the first one for your enemy, the second one for your friend and the third one for yourself. That is probably, what I should do with this Winnie-project!😉
Matthias
Great planking job and good tip about the bulkheads! Also your saying is spot on.
Rusty
Yesterday I finished planking the starboard side by adding the stern post.
I did some sanding, but that is not completely finished yet.
Here are some photos.20200301_142036.thumb.jpg.dc060c42fa67e4eaef8dcf4dcf9eafe3.jpg20200301_142052.thumb.jpg.e8af3ea7799cc392b2554004b18c9ad8.jpg20200301_135855.thumb.jpg.f0691d8503ef53a6e9bebb616b9abc0c.jpg20200301_142223.thumb.jpg.8aca0dda9a7c3fc8a399140f7b0e0d88.jpg
and some more pictures from the hull upside down.
20200301_141333.thumb.jpg.65f8cdce4f939ff242548bb00b5903d5.jpg20200301_141327.thumb.jpg.ec7c6d794c73f3f15ef1985f13d9269f.jpg20200301_141756.thumb.jpg.2865e49129cb0bc59b7c18a7d6eecf46.jpg20200301_141817.thumb.jpg.d2b39f14cc51a0fc386a72ff6138b6fa.jpg
Edited by Beckmann
Excellent work!!!   The hull looks good and the run of your planking is really good.   You must feel good to get that finally behind you.  And no stealers at the stern which looks so much better.  Only one drop plank at the bow.   That is how you plank the hull of a frigate. :)
That looks pretty darn awesome.  Time to sit back, have a drink, and admire a job well done!!!!     🍺🍺
Steve
Thanks everybody for the likes and comments. As always I know, it could have been better, but you are right, I am happy, it is done, and I am looking forward to the next chapter wich will be a spectacular one.
Matthias
Edited by Beckmann
