USS Essex by RGL - FINISHED - Trumpeter - 1/350 - PLASTIC - as she appeared in February 1944
How are you making out acquiring the air group? I see Free Time, over here north of Atlanta Georgia, has some sets, but I'll bet the shipping would be a deal-breaker.
Ken
Started: MS Bounty Longboat,
Link to comment
Share on other sites
Hi RGL: In the States we refer to them as "the Greatest Generation" I think for good reason. I have never made it to the Pacific battlefields, but have stood on both Utah and Omaha Beaches in France in awe of what they did.
What is your process for etching the armor belts on the hull. At first I thought they were scribed, but they looked raised in your pictures.
Dave
Link to comment
Dave
I mask the lines of the hull plates and add layers of primer then etch they plates into the primer.it only needs to be about 1mm
Greg
Link to comment
Great work greg.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
And the other side. Note most of this will not be visible on from looking inside the side doors. There are 3 elevators, the AOTS intrepid state there are two cylinders per hoist (I can find no photos of this, but I have used cut off big bore barrels. There is also supposed to be lift wells which would be overcapitalising. I intend to have the side lift down and the two centre ones up.
Greg
Link to comment
awesome progress Greg........looks great! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Mr surfacer put in with a big brush to represent barnacles8E7A0507-C9EC-4BA3-9050-0E9764D197FF.thumb.jpeg.b1f501fde2d51677608ef74e52efc3f0.jpeg. Then lights coats of black, green then grey,a filter coat and that will until the boot strap and the rest of the hull is done. Now I can do the hangar deck. 7ADEF01F-4C6A-4E89-B69E-66D12120AB06.thumb.jpeg.969c658b3922536b79366679f334ef3f.jpegFA5E9E81-19D3-4289-BBC9-F3601B417698.thumb.jpeg.dc21806a11a65ba45360b86838ba67f3.jpeg
Edited by RGL
Greg
Link to comment
What supprises me is - so little depth in the water,  only looks like about twenty feet or so, thats so little for so much weight, as a comparison  HMS Hood  was near 40 feet.
OC.
Current builds
Completed works.
Link to comment
Actually the Hood and the Essex were very similar in many ways with the Hood being slightly longer and wider but drawing less water with almost a third more tonnage at full displacement. (About 40,000 tons Vs. 30,000 for the Essex) Fully combat loaded with fuel and ammo the Hood in 1940 was much heavier than the Essex at almost 50.000 tons but only drew 33 feet Vs 34 for the Essex.
I think what makes the Essex look so shallow below the waterline is that like all carriers there is so much more above the waterline. The hanger deck alone looks to be more than two stories high. It will be interesting when Greg puts her next to her contemporaries.
Edited by lmagna
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
also taken into account that when the planes leave the deck,  larger plans loose some lift...........like the B 25 bombers in the Doolittle raid.  they dropped before regaining the lift needed to get altitude.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Hi Greg
So the under support of the flight deck was a mixture of I beam, (Your Plastistrut) and lighter perforated beam, (The PE in your build). Or is it just that your supplied aftermarket didn't have enough beams?
It is beginning to look like there will be more to see by looking through the hanger bay doors than will be visible from outside. Have you ordered your 900 crewmen yet? :huh:
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
Yes, yes, maybe and no. 900 crew would cost as much as the em whole model plus extras.
it’s just plod work really but nessesary. There is a large about of detail to go but the flight deck does not sit easily on the hull so I need to do the interiors then mask them off so I can paint the outsides. The tricky bits are the stern then the focsle as they will be covered over by the deck,
Greg
Link to comment
Well 900 might run the bill up a little but there is still a few affordable options out there if you don't mind running a little short handed. You could use the less detailed PE ones in the more hidden areas. :D
https://www.ebay.com/sch/m.html?_odkw=1%2F350+crewmen&_ssn=northstar_models&_osacat=0&_from=R40&_trksid=p2046732.m570.l1313.TR1.TRC0.A0.H0.X1%2F350+figures.TRS0&_nkw=1%2F350+figures&_sacat=0
http://www.hobbylinc.com/tamiya-sailors-ship-crew-set-144-plastic-model-military-figure-kit-1:350-scale-12622?source=froogle&gclid=CjwKCAiAws7uBRAkEiwAMlbZjhjfeeeTzsF-pcmoU4ozA-4_SygR3A5yasF14XxtomepD01zGV10yxoCxuUQAvD_BwE
https://www.megahobby.com/products/naval-figures-for-all-nations-100pc-1-350-white-ensign-models.html
I would think that with the open bow and stern of the American WWII carriers that these areas would be the most visible areas of your super detailing.
Edited by lmagna
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
In some of the pictures it is a little hard to tell why there are so many crewmen visible. #1 looks like they may be re spotting the aircraft forward to allow landing of aircraft. Not certain what is happening with the Avenger as it looks like he missed his approach but I cannot tell if his tail hook is down or not.
#2 is obviously a Pollywog party for crossing the equator and the majority of the crew would probably be on deck.
#4 is repairs or ship to ship transfer of large items and large work parties would be needed.
#s 3,5,6 are interesting because they show the overhead that you are building. It would be great if they were larger so more detail could be seen.
Edited by lmagna
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
