thanks for the likes and good comments :)  this has gone better than I thought it would.  the faring process met with a couple of loose ribs, but it has been done.  I also adapted the jig yet again......this time I shimmed it up to cut 1.8 x 3 mm planking in half {thickness}.  without a good guide to keep the scroll saw blade from going side to side,  it was trying.....but I went slowly and it worked out well enough.
how many of those boats do you have for the Titanic Gary?  that's gonna be quite a process ;)
I wish I could answer you all.......your comments are on the last page,   and I can't review them....your all just too kind  :)     I have more to add.......but work time calls,  and I got to get ready....still need to take Gibbs out as well for his morning jaunt.....I hope we don't see another skunk,  like last Monday  ;)   see you all tonight!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Nice creative thinking.  Keep it up.
Bob
Current build:  SS_ Mariefred
jeeze.......thanks for all the kind words........when I first did it for the Nordkap,  I didn't know what to expect.   I knew I was too green to do a scratch built one,  like I've seen some of you folks do.  the only wood one I've done so far was the one I did for the Susan A.   I've managed to get the skin of CA off my fingers.......don't think I like a world without touch.   the two plastic boats.....I have a feeling that they will find a home on the trawler {if I can fit them}.  I like the way the scratch boat came out.......I did have to use some filler on it,  but I'm hoping that stain will work out.   I'm sure that once the interior of the plastic boats are filled in.......it will hide the plastic aspect quite nicely ;)
thanks to all of you for the comments and likes........I am humbled for the interest you've shown.   I have the update on the scratch built boat......I hope you enjoy it just as much!  :)
can't wait to see what you do with your Gary........what an assembly line!  ;)
I've never done a metal boat Lawrence.........I think that would make me join the folks doing other builds I've seen, that were unhappy with the supplied parts.  they elected to make scratch built boat.   there is a lot of satisfaction in taking what is supplied,  and making it work.  I'm sure you have pictures with your ship's boat in them........I'll have to take a closer look  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
OK........on with the mini armada! :D     I used some of the leftover thin Annegre that I had cut for the United States build, for planking the plastic boats.   for the interior of these two,  I will add in the keel,  the ribs,  and detail them out.   I think that will kill the plastic look.
that jig I made has served me a few uses........cutting down the Annegre,  then the block of rib parts,  and for the latest bit of progress........cutting 1.8 x 3 mm strip stock,  in half,  to around 1 x 3 mm.  it's not quite 1 mm.........taking into account fore the thickness of the blade.........I'm glad I found the other blades I bought for the scroll saw.   I had to shim the jig on both sides to center the strip stock,  and then work very slowly,  to run them through.   to give you an idea of what this looks like, here are a couple of pictures.
I began to plank the frame,  sanding it as I went along.
soon,  I had one side done
I had started to plank the other side......a couple of rows,  to keep it from warping...and so nothing else would break off.
it's finally done
here is the relation to size of these boats.........the plastic one would be out of scale
I added the keel to one of the plastic boats.
....and a shot of the interior,  of the wood boat  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Magnificent work Popeye!
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
thank for the good word...I really appreciate it  ;)    first hurdle over and done!
I plan to do that John......with the interior in place,  I don't think they'll look plastic.  more down the road  ;)
thanks Matti  Piet  and Frank!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Splendid work Popeye, good choice to scratch your ships boat and it's looking real good mate.
As for the plastic boats I did exactly the same on my Badger and I was really happy with the results, these boats can be made to look good with a little imagination and my friend you have that in bucket loads.
Keep it up mate.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Popeye, where is a picture of the scroll saw jig?  Sounds like something I could use.
Bob
Bob.......the pictures of the jig can be found on page 7 of the United States build.      the one thing about the jig,  is that there is still the threat of the blade going side to side,  altering the desired cut.   I'm using a thin blade......good for cutting sharper curves.   I suppose if you were to use a thicker blade.....like a band saw blade,  this problem would lessen considerably.   I found that you can use a scroll saw as a plainer and table saw.......but there's nothing like the real thing.   something I should keep in mind for the future  ;)
thank you very much Mobbsie....it shows me where my wood inventory is lacking ;)   I think the continuance of the plastic boats should go towards the trawler log.........boy.....didn't I deviate form that build in a hurry!  :D  :D   I will get back to it.......but I will also continue with the scratch boat.......I need to get it stained like the Half Moon now........fun.....fun.....fun!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks, I'll have to make one.
Bob
pretty easy to make Bob.......perhaps yours will come out better........movable guards? ;)
I made some more progress with the boats........staining them was a big first step!   no paint on the outside for me,  John........I promised you......remember!  ;)
the last picture you will see of all three together.........the scratch built boat got the Half Moon color.   I gave it a shot of the mahogany stain.  the other two have gone to the trawler Syborn build.
staining the hull of the boat.......I got a good idea where the bleed throughs were.  to remedy that,  I spread a thin coat of fill to the inside of the hull,  evening it off with a piece of wood.
I was going to paint the gunwales with a brown paint........but I ended up staining them instead.  I figured that if the accents for the interior were going to be stained......it may as well too.   the interior is painted a flat red.
the floor was created next.......made on the table and fitted in place.   it wasn't cemented in until after it was stained.
I was curious how this would look aboard ship,  so I brought her out and set her up as a dry fit.  I might be a little off as far as where everything goes......don't hold me to the layout  :)
just for you J...........I know!   I pined and cried for the Moon,  because I didn't have those tack line decorations.   ..........and what did I do when I got them........drilled them and left them lying around on my table,  for god and everyone to knock'em off!  happy to say that they are in the works!   I painted them with a flat red........but I'm beginning to wish I could sand blast them.....that finish doesn't hold paint for #&%@!
I used the dark stain to give them a bit of weathering......but it caused the paint to become solvent and move around.  the finish showed through.   I brought out the red again,  and touched them up.  the stain mingled with the paint,  but they look a bit too red again.  after I took these pictures,  I took a q-tip and dabbed them a little......they look much better.   I'll give them a shot of flat coat before I even try to handle them.  it's fine.........I still have to map out their location anyway
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Just impressed ... and depressed thinking about my boats
I like this!
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
thanks Nenad.........there is quite a bit of info here about these small boats.    some use a plug to make them,  and some have these mini kits waiting for them in their builds.   you may elect to scratch build them........but you might also look into some of the kit manufacturers that offer them.   I'm sure someone can help you better than I can........I tend to fly by the seat of my pants......I do it so much......I got grab handles!  :D  :D  :D
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Your HM launch is looking good and the lion's heads are coming along, I had the same issues with mine...I ended up hitting them with a flat clear... painting them red... flat clear... brown acrylic wash... flat clear... red dry brush...flat clear...red highlight...flat clear...well you get the picture, I'm surprised they didn't turn out an inch thick :D :D  any way even with all that they need to be handled with kid gloves.  Still working on the masts for mine, mast cap blocks are fighting back...the kit ones just suck, all made from end grain, already broke 2,  hole spacing is bad, anyway I'm in the process of making new ones.
Nice work on your Moon
J
Wow, Popeye, you have been busy!  That little boat looks really terif there on deck!
Cheers,
                       VOC Ship Surabaya
Lions heads....is that what they are? I though that they were raspberries that had been out in the sun too long. :D
Very nice work on the little boats Denis
Michael
hello popeye   its looking vary nice so far keep up the great work
You're in warp drive!  Great work on those boats, love the staining.  And it all comes together on deck.  Smiling widely over here!
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
thanks J......yea, that finish on them is a real problem. would have been better if they were lead or something...but they are done. I'll hit them with a spray, so I don't have to use a brush. thanks for the good word ;)
thanks Piet, John, and Bindy. still more to go......hopefully I can finally cement all these parts on her permanently. that will mark a huge leap in the progress dept. thanks for the good word!
thanks Michael.....yea, even the camera doesn't like them :D :D I can't get a good picture of them...no how! I'm just glad that I could get them.....can't wait to see them on the build! thanks for the good word!
thanks Dragzz......hope to see an update on your build soon! ;)
thanks Ferit......so good to have you here! looking forward in seeing more of your fine work!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
thanks Augie......gotta finish that darn hull work, so I can feel good about getting all the parts on the deck. don't want to do it before I do! :) thanks for the good word!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
