Well, they turned out ok and the proportions looks great. Just need to be very careful here. The MDF design is very different from all other kits I come across. It would be interesting to try it out for a much larger ship. The skeleton of your 1/64 Victory looks really impressive. I guess you will have that design for your upcoming Bristol as well?
Current builds: HMS Victory (Corel 1:98), HMS Snake (Caldercraft 1:64), HMBV Granado (Caldercraft 1:64), HMS Diana (Caldercraft 1:64), HMS Speedy (Vanguard Models 1:64)
I can't believe how fast you are - it'll take me at least 3 months to get as far as you have, and I'm retired! How much does Chris's innovative design help in that regard? Everything certainly seems to fit together really well.
Keep up the good work. I'm really enjoying your log and can't wait to get my Speedy at Christmas.
Derek
Cheers, Derek
Current build:   Duchess of Kingston
On hold:              HMS Winchelsea
Previous builds:  HMS SpeedyEnglish Pinnace, Royal Yacht Caroline (gallery),
                            Victory Cross-section (gallery), US Clipper Albatros, Red Dragon (years ago!)
On the stocks:    18th Century Longboat
Thanks. Well its a design that dont require that much fitting.  Its also a small ship. Planking Victory in the same design would take alot more time just due to size. And i am also abit devoted at the time. I Will be travelling over Xmas and NYE so the build will take a 3 week break soon...
Boxwood... i am in love!
Its a very hard material and the result is way different than my Tanganyika. My new Proxxon sander really came in handy here. Its a hard mtrl so much more difficult to cut.
This is optional according to the manual. But I decided to attach the keel elements before starting the 2nd planking simply because its kind of a slippery hull when everything is sanded  smooth. With the keel my fingers gets something to grab when holding the ship. We will see if it was a good decision i guess...
When i did this the first time I used boiling water, PVA and pins. That is ok if you will paint the hull completely and can use woodfiller afterwards. Nowadays, especially on models when the wood will be visable, I have upgraded my technique and go with the "Chuck method". Instead of bending and pinning down the plank, I spend much more time on preparations. This involves two things: i prebend the plank in the "wrong direction" using hot air and clamps. I also spend some time on sanding to make sure it will lie flat against the previous plank. The final result is an S-shaped plank.
To fix the plank  i put CA on the first 10cm and press it down for just a few seconds until it sticks.
20191213_222302.thumb.jpg.29b3eec80d61e8dcd38bd12dadabe624.jpg20191213_222331.thumb.jpg.2cca623221ff9e8b924e28ab58ef7af4.jpg
Thereafter I use a toothpick or some pointy scrapwood with CA on top of it adding more on the plank and press it down. Repeat a few times and finally the whole plank is fixed.
Hi Vane
Lovely build. I did exactly the same thing with some of my second planking but spaced out the CA so that I could add normal wood glue as well. That should give a stronger bond to the first planking.
My two pennies worth anyway! 🙂
Nick
Interesting, I have to try that too. there are many ways to do this. But i Think the gamechanger for me was when i bought my heatgun from Proxxon and started prebending the planks sideways. Everything fits so much better.
Great build log Vane! Lots of good photos and explanations. I'm getting some great ideas. Thanks!
Peter
Build Log: Billing - Cutty Sark
In The Gallery: HMS Unicorn, HMAV Bounty, L'Etoile, Marie Jeanne, Lilla Dan, Zeeschouw "Irene"
A Toast: To a wind that blows, A ship that goes, And the lass that loved a sailor!
Yes I know, this looks ridicurlos!
However, by using leftover walnut strips on the areas that will be coppered i will save at least 25 strips of boxwood. I am also not that carefull on the details here. Pins, Water and PVA!
I like your thinking with the walnut and saving boxwood strips, Vane, you're doing a great job on a very nice ship.
Edited by Edwardkenway
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Thanks alot. Boxwood looks really flat and precise once its sanded. Some people just use Walnut and hardly sand at all. I have started to pay more attension to everything nowadays. It will be really intresting to compare my Tanganyika Granado hull with this Boxwood hull once things start to be finilized.
Really enjoying your build log Vane, as you spearhead the speedy builds.
Can you clarify for me your technique for bending the planks with hot air and clamps. Do you just heat them up bend then clamp or do you soak them first?
Phill
Current Build: HM Cutter Alert 1777
Thanks. I dont use water at all. I just fix a strip of Wood with 3 clamps to an old cutting board. Then I open the left clamp and bend the strip as far as possible in the "wrong" direction without it breaking and clamp it down again. Then I do the same to the right side. Sometimes I adjust the position and even bend it further by adding an additional clamp. Once I got the shape I want, I take my airgun and heat up the bended parts for 20 seconds and then let it rest and cool down for a few minutes. Remove the clamps and viola.. u are done!
A heat gun is an interesting idea, of course I recently bought a small travel iron to apply the heat but I feel like the heat gun would be easier (maybe not cheaper though). Thanks for sharing the technique!
Did you already experimented with the traveler iron? I bought also one after seeing it in the video of Chuck.
Not yet (I haven’t done a planked model yet 🤫 but my next one will be), I saw one in a store and thought that I would pick it up for when I get to planking.
