1 hour ago, Justin P. said:
Definitely get the blocks.
K, just placed the order for some blocks and more rope 😁
I think I'll just purchase all the blocks except for the 3/32" single blocks since it got too pricey. I also saw the instructions for the deadeyes and it seems that a block tumbler is needed to assemble them, so I'll just use the kit ones for this. I believe Peter also did the same for his Syren, and it turned out spectacular!
Current:
USF Confederacy - Model Shipways (Build Log)
HMS Pickle - Caldercraft (Build Log)
Complete:
Virgina 1819 - Artesania Latina (Gallery)
U.S. Brig Syren - Model Shipways (Build Log, Gallery)
On the shelf:
Armed Virginia Sloop - Model Shipways
6 hours ago, abelson said:
Nice work on the pin rails. Good idea on using the scrap wood for setting the rails at the same height. Wish i had thought of that.
Thanks Steven! I also liked your idea of using the plans as a template to mark locations of the details. I was too lazy to photocopy them so I just eye-balled their locations..... probably not the best way to do things 😅, but I did use a caliper once in a while 😁
Current:
Complete:
On the shelf:
I finished gluing the eyebolts into position. Not much to describe here, so here are some photos:
Next is the cleats. I have no idea how to drill holes by hand (using a pin vise) into the cleats to pin them for a secure fit. The drill bit just keeps sliding.... I guess I will just glue them without the pin and try to treat them delicately
Current:
Complete:
On the shelf:
Can you make a small indentation with another tool to stabilize the bit?
Thanks so much! Your advice worked!! I guess I didn't apply much pressure to indent before but this time I put more pressure. Here's a pic and the indent tool I used. The black strip will be used to support it. Thanks again!
Current:
Complete:
On the shelf:
I finished gluing in the cleats. I used a caliper to determine the locations. I had to file each cleat so they are smooth.
Next I'll be working on the guns.
Current:
Complete:
On the shelf:
The carronade sleds have been assembled. They did get a bit tedious after the 10th one, so I'm definitely not looking forward to the carronade rigging section 😅.
Current:
Complete:
On the shelf:
That is some fantastic craftsmanship - can't wait to see more!
-Adam
Current Builds
Santa Maria - Artesania Latina (1:65) POB
MayFlower - Model Shipways (5/32"=1') POB
Blue Shadow - Mamoli Revolutionary War Brigantine. (Fict) (1:64) POB (Recommissioned as the Kara June)
On The Shelf Waiting so Patiently
USRC Ranger - Corel (1:50) POB
18th Century Longboat - Model Shipways (1:4) POF
La Nina - Artesania Latina (1:65) POB
U.S Brig Syren - Model Shipways (1:64) POB
Completed Builds
Phantom NY Pilot Boat - Model Shipways (1:96) Solid Hull
Decommissioned Builds
(Time and conditions were not good to these. They have been cancelled =( )
Willie L Bennett - Model Shipways (1:32) POF
USRC Harriet Lane - Model Shipways (1:128) Solid Hull
11 hours ago, Matt D said:
Your Syren looks terrific!  Nice work.
Thank you for the compliments Matt and Adam :), and thanks all for the likes!
Current:
Complete:
On the shelf:
Some more small bits of progress. I have started to stick the carronades on top of the sleds. I'm still deciding whether it is worthwhile to install the pivot pin..
To paint the lugs I just "beaded" them through a wire and painted with watered down red paint to quicken the process
To simulate the elevation screw, I used toothpicks which were sanded down to fit the corresponding holes, and 0.45mm holes were drilled through them to accept the wire for the handle. I deviated from the instructions a bit where I installed the elevation pin, then the lugs. This was done just to make sure I have the same angle on all the guns. The lugs were then glued once the guns were installed to ensure they rest flat on the sleds
So far the starboard side of canons have been assembled.
Looking outside the hull, the carronades can be seen to not be completely in line with one another. I may have to stick a small strip of wood below the sleds in which the guns seem to be lower than the rest. I hope this fixes the issue...
Current:
Complete:
On the shelf:
I finished assembling all the carronades. I tried to adjust the angle of the guns so they are more in line with each other. Here are some pics
Next I'll be rigging them, and will glue them in place as I progress with the rigging
Current:
Complete:
On the shelf:
You’ve been busy, they look great!
We are what we repeatedly do. Excellence, therefore is a habit, not an act.
~ Aristotle
I could carry, paddle, walk and sing with any man I ever saw. I have been twenty-four years a canoe man, and forty-one years in service; no portage was ever too long for me, fifty songs could I sing. I have saved the lives of ten voyageurs, have had twelve wives and six running dogs. I spent all of my money in pleasure. Were I young again, I would spend my life the same way over. There is no life so happy as a voyageur's life!
~ The Voyageur, Grace Lee Nute
Thanks for the component Voyageur! Yeaup, I started grad school this week, so I have less modelling time. Progress has really slowed down :unsure:
Current:
Complete:
On the shelf:
Nice crisp work.
Steven E. Sylven
13 hours ago, abelson said:
Nice crisp work.
5 hours ago, Retired guy said:
Very nice update Wally guns look very sharp 👍 also like your pictures shows your work off very well.
Regards
Richard
2 hours ago, Overworked724 said:
Nice idea using the laser cut piece, Wally!  Wonderful work!,,
Thank you all for the very nice comments!! It's very much appreciated! 😊
Current:
Complete:
On the shelf:
It always looks very impressive when the whole battery is in place for the first time! Your Syren got her teeth now 🙂
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
I think she looks marvelous and gives me more motivation to continue with my own build!  Nice progress!!!!
“Here.  Hold my beer..." --- Common phrase uttered by Lord Admiral Nelson at any pub. 🍺
Thomas
She is definitely starting to look deadly :10_1_10:
Thanks for the great comment Patrick!
Current:
Complete:
On the shelf:
I finished preparing the blocks for the tackles. This was a task I would not like to do again 😅, especially sanding each of the 128 blocks to be rounded, and hand-drilling a hole on each one (using a pin vice 😬). Good thing I distracted myself by watching one of the greatest shows created, the Sopranos!
To finish up the blocks, I brushed them with a bit of tung oil (the untreated blocks looked a bit unfinished imo).
To create the hooks, I used the pin of a compass and some pliers. Hopefully the following sets of images can explain the process better:
The tail bit was then cut off:
Then used pliers and the compass pin to bend it:
This process was time consuming at first, but got quicker as I got more practice making 127 more of these 😄
The hooks were then glued to the blocks using a bit of superglue:
Lastly, I found that the eyebolts glued to the canons were too small for the breech lines. So... I had to deconstruct these parts, use the compass pin again to make them larger, then glue them back. I will also need to do this to the bottom eyebolt pairs on the bulwarks. After this is done, I can finally start the actual rigging!
Current:
Complete:
On the shelf:
13 hours ago, Havelock said:
Wow. Not sure I could handle that! Amazing work!
13 hours ago, BobG said:
Very nice work and good luck in grad school!
Thank you Havelock and Bob! 🙂
Current:
Complete:
On the shelf:
34 minutes ago, abelson said:
Nice work on the blocks and hooks. I've skipped that work for now, but what gauge wire did you use for the hooks?
Thanks Abelson! I used the 28 gauge wire that came with the kit.
Current:
Complete:
On the shelf:
A very small update before starting the rigging
I decided to make rings for the breech line as opposed to making the eye bolts bigger. I guess this is the more accurate way of doing things. Many other Syren builders also did this.
Here are the bridle and aft most ones installed:
All the rings have been made and I can finally start rigging 😁
Current:
Complete:
On the shelf:
