I'm not one to say "There's no way I could do this", but looking at your carving skills, I have to say "There's no way I could do this" :)
Utterly fantastic work...
~Bob
  • 2 months later...
Great job, William, on those figurehead people.  I had a fun time doing them at 1:96.  Very hard to get them to strike the right attitude.  Also, beautiful work on the stern galleries.  Looking forward to seeing the 138 balusters.
All the best,
Ed
Just finished the stern on my own build and thought it looked well but seeing yours makes mine look rubbish ,but i still ain,t redoing it ..Your carving skills are to be envied , by me anyway , tried my hand at it and finished up buying the brass docors .
checked out your stern shihawk and its looks fine, commercial parts are nearly always a let down but you have cleaned them up super, as for the carving you must use the correct material, I purchased some boxwood and like you had a go, took a couple of attempts to get the hang of it and although not perfect they look ok, here`s my version of the right hand strong man and the view through a macro lens shows all the errors but when looking with the naked eye he`s acceptable.
All the best,
Ed
your right Ed thats a lot of balusters to carve, you are one of the few who counted them right, heller got it wrong and the great longridge also miscounted unless there`s been a change somewhere down the line
cheers all for the comments.
OK on with the build, started the second planking on the Vic had to replace one plank but apart from that all going fine, at this point decided to try in my split cannon, as you can see by the photo there is no need to up the detail on the carriage , i`ve looked from all angles and happy with it
I take it that the split cannon is so that you can add them later so that they are not in the way while you complete other tasks.
The stern details are very fine work.
Michael
Michael
correct Michael, some kits have full decks all through the ship and it seems a shame to block them out with dummy wall cannons, i did a tutorial on the AL Victory to make dummy cannons out of the material supplied for the dummy walls and the dummy cannons, here`s the link  http://modelshipworld.com/index.php/topic/2704-dummy-cannons-by-william-butler/#entry73179
  • 8 months later...
Had a break and starting to delve back into it !!! Started to tackle the ships wales ! found this very tricky on a natural finish ship. I’m using two types on wood to create the striped pattern, the difficulty lies in the fact that the stripes don’t follow the wales, so ended up splicing some of the anchor stock shaped wales together ( the ones that overlap the striped pattern), one photo shows one centre wale spliced and the other shows the same wale fitted .
Edited by williamDB
William -
Excellent marquetry work with the contrasting woods.
Dan
I'm in total agreement with Dan.. Excellent marquetry.  But I'm going to add.. beyond beautiful.
  • 1 year later...
simple tutorial on how i made my stock shape wales, i cut a piece 6mm ply to use for my jig, now this jig is not pretty but its accurate, the ply is something like 6inch square. first i set the jig to cut the length, then i cut the long taper and last the short one. the beauty in this method is that you dont have to reset your saw, you just cut it in order cut one cut two and three, when you check your finish piece you have to make sure that both ends are exactly the same depth, if there not leave the last cut until you finished all the others and then reset the saw for the last cut
Very ingenious method of making those pieces, William.
William, just found your log and your Victory, wow!  I love the idea of the using the woods to show the Nelson chequer cirrectly, but your execution is just amazing.  Definitely want to keep following your progress and your great ideas.
Cheers,
Jason
In the shipyard:
cheers Jason,, i looked at a lot of Victory models and couldn`t find one in natural wood where the stripes split down the wales as they should, so i took it on, its a bit of a pain and only a few that see it will know the accomplishment...
  whilst building the Victory i`m building bounty`s launch as a break along the way.... here`s a few photos
