Battle of Waterloo Attack on La Haye Sainte Farm by Old Collingwood - 1/56 (28mm)
3 hours ago, Javlin said:
I see how it is ;) that's the 1/2 French in me looking good OC.
Thank you kindly,   they only did that beacuse of one of  the British  Cavalry  charges.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Share on other sites
Evening all  - a wee bit more progress  tonight,   the Captain has had waistband sash painted, also his Shako brades done in silver, the rest of the troops I have painted the water  canister belts in a light brown  to simulate leather, and I am now painting their trousers.
OC.
Current builds
Completed works.
Link to comment
beautiful work OC........and you say MY paint is striking..........look whose call'in the kettle black  :D
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thank you kindly Denis,  figures are easier  as they just a small areas  - just takes a steady hand / magnification  and good light,   but larger  subjects like your planes that need complex masking  - is another  field all together.
OC.
Current builds
Completed works.
Link to comment
you don't do any masking?  your a freehand freak.........aren't you? :D  ;)   I'll send all my figures to you.......mine keep coming out look'in like circus clown :wacko:
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Evening all,   a  small update  in la la land  -  I have finished painting the trousers and done the shoe guards, also the rifles and been painted  - just needs the hands and a wee bit of detailing  before I do some washes the dust highlighting.
OC.
Current builds
Completed works.
Link to comment
Evening all,   next set of 2nd KGL  detailed - washes and  dusting  then spray flat top coated with my airbrush.
OC.
Current builds
Completed works.
Link to comment
It's worth noting again that your figure painting is nothing less than amazing.  Imho I think the airbrush has made the final flat coat even better being able to get a thinner even coverage than brushing .
Outstanding job.😉
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Outstanding job.😉
Thank you so much  for saying that Edward - very kind of you.
OC.
Current builds
Completed works.
Link to comment
About all I can say is 'WOW".   Your work on this model is beyond mere mortals.
Link to comment
Thank you so much Mark,    I think the key to it is Practice - practice and more practice, I can see the improvements  from the first ones I did to these  - guess its the same with all our building  here.
OC.
Current builds
Completed works.
Link to comment
OC.
I do agree.  Practice, practice and practice some more.  And your airbrush work is most excellent.  Hard to believe you never used one until now.
Link to comment
To be honet the initial outlay cost and the (what I thought would be Loud noise) from them running  - but mine is real quiet so no  complaints from the admiral  watching her  evening TV.
But I am so pleased now I have it  - deffo an investment.
OC.
Current builds
Completed works.
Link to comment
OC, you're in the zone with your painting. Thanks for sharing all of this.
Ken
Started: MS Bounty Longboat,
Link to comment
Thank you kindly for saying that Ken.
OC.
Current builds
Completed works.
Link to comment
Evening all,   more time playing with my dio  - firstly I had to carefully  cut the figures  off there pre-cast plastic basses  - just need to be careful not to cut their feet off,   then it  was  placement  time  - just a wee bit of CA  under each foot  and positioned,  one of the KGL  has died  and was placed on the grass  - a couple are on the roof of the Piggery firing down on the French  and the rest are scattered.
Starting to get a bit more populated now  Forty KGL  in the farm so far.
OC.
Current builds
Completed works.
Link to comment
OC.
Its looking great OC. Lots of action already. The detail being so good really makes it a gem
Alan
Link to comment
Alan
Thank you Alan,   Its fairly busy in there  - but needs to be as it was a hive of activity  with close to 400 KGL in the farm at one point.
I am working on my next batch of 5th  KGL (Red coats)  at the moment   - mixing them breaks the  boredom factor a bit.
OC.
Current builds
Completed works.
Link to comment
So  just as I said to Alan  - I  have started  on my next Fore-teen  figures, in the shape of more 5th KGL  (Red coats)   these will be placed inside the farm  when done also.
OC.
Current builds
Completed works.
Link to comment
Lovely work OC,
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
8 hours ago, Kevin said:
Lovely work OC,
Thank you kindly mate,   getting there slowly.
OC.
Current builds
Completed works.
Link to comment
looks amazing OC.....the Dio is getting busy  ;)   very nice work indeed!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thank you kindly Denis.
OC.
Current builds
Completed works.
Link to comment
It's going to get crowded fast, OC.  Looking great though.   Will there be room for the French?
Link to comment
Evening all,    more KGL  being constructed  in the shape of the 5th line centre regiment, that was sent down as re-enforcements,   as no extra ammunition  was sent down  to the 2nd KGL.
OC.
Current builds
Completed works.
Link to comment
"Oh yes"   Mark  - planty of Frenchies  going to be included  in the areas surrounding the  farm in front  and to the Left of it,  my build  process at the moment  is to get all the KGL  figures  finished first as they go inside the  farm (it easier  to put the farm on my table under my lamp  - wont be that easy  once its fixed to the base)    then I will work on the scenery and other figures  including all the French.
OC.
Current builds
Completed works.
Link to comment
Evening all,    Fifteen   5th Line KGL  both cantre  and  light  companies, now complete  - just need their  back packs  then primer.
OC.
Current builds
Completed works.
Link to comment
Evening all,   some back packs added then  primer sprayed on   - then I gave  my airbrush its first deep clean,  dismantled it  cleaned the needle and the point  and re assembled.
OC.
Current builds
Completed works.
Link to comment
Evening all. a  small update but minus any pics  - sorry,    so I started  my normal  route  painting the faces  - first a  basic skin flesh colour, then a wash  to bring out the details, then after this was dried  a touched  up the cheeks with a subtle pink colour, I was just about to do the highlight areas  when  normal life had to but in when our  carbon monoxide  detector started  pipping at us,   we didn't know what it was at first as we have other devices that make funny sounds when they want our attention.
So I went into the kitchen  and saw that it was making a slight flash and  ping sound  roughly every minute,  I pressed the test button  and the dial showed a very low reading of 0.50ppm    but after doing some reading up  - it could have been pippingh at me to  re charge the batteries in it  - so as we speak they are on charge.
Life does have to get in the way with important things like modelling.
OC.
Current builds
Completed works.
Link to comment
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
