Sassafras 12 by ccoyle - Chesapeake Light Craft - FINISHED - 1:1 scale canoe - you read that right
 C.C. Rider?
Just finished sanding and putting on varnish coat #2. It's quite warm today, and the varnish gets tack-dry quickly, which I discovered when I carelessly rested an arm on one of the varnished decks (the one not pictured, obviously). Oops. Good thing it wasn't the finish coat. And stop with the name guesses -- you guys aren't even close! 😝
You should do a christening  party when you name her  - perhaps invite some of the gang round from  here.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
On 5/24/2021 at 10:18 AM, Ian_Grant said:
Experienced husbands, upon completion of such a fine project, and with an eye to the future, would name her after their wife.
That would be if one was still looking for brownie points not the case anymore so name her after an ole Girlfriend the wife knew ;) Kevin
murder on 34th street
Edited by Javlin
Moving forward. I decided that four coats of varnish were enough, not because four coats made everything pretty, but because I felt like my sanding between coats (scuffing, really) was making things look worse, not better. So I moved on to hardware and fittings. 😮
First up: drain plugs. Holes were cut with a 1" router bit, then plugs glued in with marine adhesive. Set the screws with adhesive, too.
For tie-down points, I settled on inexpensive eye screws. These are also set with marine adhesive. The screws are set at the points where the inner rails join together (not visible in this shot); there's a healthy amount of wood and epoxy for the screws to bite into.
Next up was the thwart. You know, I totally forgot to give consideration to which end should be the front -- I just got carried away installing stuff. Oh, well -- now it is carved in stone, er, wood. Each end of the thwart is attached to the underside of a rail by two countersunk screws. I bought myself a small ratchet driver for this job -- worked great, and it came in a set along with one of every type of driver bit known to man.
Lastly for today was attaching the back rest. It is secured to the thwart by a bungee cord and tensioned by two adjustable web belts.
sass74.thumb.jpg.ff3214d08f1b3ba24414bed312b0ddb4.jpgsass75.thumb.jpg.d141739e1df7765e39775332d57f7744.jpg
We are getting close now!
Hope you got a bottle of something for the christening?
OC.
Current builds
Completed works.
A bottle of bubbly yes, but no bananas, flat feet, or whistling (among other things).
Zooming right along ...
Next task was to glue down the seat. Not easy, since instructions specify a linear distance of exactly 71.375" from the stem to the front of the seat. But of course, one can't measure a straight line down from the stem into the boat, can one? Solution: a primitive plumb bob made from a miniature clothespin hanging from a thread wound onto a piece of scrap wood. Measure from the stem to where the scrap meets each rail to create the base of an isosceles  triangle, hang the bob over the center line, and presto! Location of seat identified.
The seat consists of two foam pads. The lower pad is hollow as you can see; that allowed me to run a marker around the inside to see where the glue needed to go. The base is glued down with contact cement, then the top layer is glued on top. The hollow construction will allow my tush to settle in comfortably (hopefully).
With the inside finished, it was time to flip her over again. Here I've identified spots that need a little touch up and flagged them with bits of tape. These are mostly quite small, so I think a a light scuff and a dab with a good quality brush should do the trick -- I intend to sacrifice one of my white sable modeling brushes for the job.  I can easily get another at the local Hobby Lobby. I will test this procedure out on one of the more obscure boo-boos before going at it hammer and tongs.
The finish line is in sight!
Nice job on your canoe, and a particularly nice choice in colours for the finish. If I may offer a small suggestion, if you haven't already, get a set of brass stem bands, they'll help protect the bow and stern from bumps, scrapes, abrasions, chips etc.
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
Hmmmm ! I always knelt in the bottom a canoe with my tush resting against a thwart.  Never sat in the bottom of a canoe.  Wonder what paddling from that position is like.
Anyway, beautiful looking canoe, Chris. Great job building her.
Jack
Current buildUS Constellation
I tested one small spot as i suggested in my earlier post. I'm not entirely satisfied -- you can see where the touch-up has been done, even though you might have to squint just right to see it. I may reconsider and do only the spots that really need it.
Yes I was thinking the same thing. Sitting in it kayak style will not allow proper power strokes or control whereas kneeling as above gives a great deal of control and power. Even if you aren't going for power it will give you better bang for your muscle buck so you will not fatigue anywhere near as quickly. There is also the benefit that when kneeling it is easy to tip the canoe to one side which will help it turn.
A comfort tip for kneeling:- take two car washing sponges to kneel on, they also double as bailers to remove excess water.
It also makes using the J-stroke to keep the canoe on track  easier to execute, especially if solo.
Jack
More room in the back  (less legs)    for passengers   should have said   MSW  members 😇
OC.
Current builds
Completed works.
Yeah Chris, I'm not trying to correct the designer and I'm sure there will be plenty of quiet drifting/slow paddling where the seated position will be highly desirable. Just thought it reasonable to let you know the other option.
I wonder if this is designed to be paddled more like a kayak which, by the way is far more efficient than the single paddle and "J stroke". I had a 15 foot Old Town canoe and always preferred the kayak paddling style. Either way, you'll work it out and get a great deal of pleasure from it.
Load capacity is only 250 lbs, so it would have to be a really small MSW member.  😳
Yup, exactly. I already have the paddle. It is longer than a typical kayak paddle on account of the higher freeboard. Neither the canoe nor the paddle are designed with aggressive paddling in mind.
Okay, time for THE BIG REVEAL!!
After seven months of work, Sha-Sam-Kat is ready for her debut. Some concluding thoughts will follow, but first let's have some pictures.
The name Sha-Sam-Kat is a nod to my three great kids, Shannon, Samuel, and Kathleen. I got the lettering from a place that does custom boat decals. Got the left side just a touch too high during the application process, but it's not especially noticeable from a distance. All told, I spent probably around $1600 for the kit, tools, and materials -- more than a mass-produced fiberglass or aluminum canoe will set one back, but far cheaper than comparable custom-built wooden canoes. I might get her out on the water this weekend -- pics to follow if that happens.
Some concluding thoughts:
  • Building a boat is a love/hate relationship. There were times when I was all ready to have a go at a second boat and other times when I just wanted the darned thing to finally be finished! Can you say "sanding"?
  • I'm happy with the Chesapeake Light Craft kit -- nothing to complain about in that department. Whatever flaws are visible on the finished item come down solely to me and not the kit.
  • If I had to do it again, I would pick a simpler design for a first effort. Although rated for beginners, the lapstrake planking creates about twice as many seams to tack together and fill. A slab-sided dinghy or skiff would've been easier, but also much heavier.
  • This was my first time working with both epoxy and fiberglass. It sure would have been handy to have those skills before starting construction!
  • If you have building a boat on your bucket list, do it! Don't wait.
So, that concludes my 1:1 build. I hope you have enjoyed the journey with me, and I also hope that it has inspired other potential builders. Perhaps we will see other 1:1 builds in the near future.
Thanks for tagging along, everybody!
She looks great, Chris!  Thanks for sharing.  I've checked out CLC's website in the past and they look like nice kits.  It was a pleasure to watch yours come together.  I'm looking forward to photos on the water.
HMS Winchelsea 1:48 (Group Project)
Completed Builds:
Virginia 1819 Artesania Latina - 1:41
HAZZZAHH!!!!!
giphy.gif?cid=ecf05e47nkh4axnw0oaa35b2w2
Chris, what a good looking canoe, well done.
STAY SAFE
current builds:
Beautiful ! Nicely done ! Enjoy!
Jack
VERY nice canoe Chris!
May you have many happy hours in her.
I've  enjoyed watching the build🙂🙃😉
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Really nice work Chris  and the  name is excellent   "Spice the main brace " mate.
OC.
Current builds
Completed works.
