10 minutes ago, Egilman said:
Not a real easy seaway to model.....
Will continue to look my friend....
Ok Craig, here's a few shots....
Choppy seas off Australia, It would be the subs operating area....
I think you nailed the coloration.....
More....
Very foamy water with tiny ripples in the surface....
And last, what a wake looks like in such seas....
The water is still chaotic but there appears to be a foam filled trough in a wavy line astern..... It only extends about a ships length before the water churns it all up again....
Hope that helps...
EG
Quote:
27 minutes ago, CDW said:
Used cotton and acrylic gel.
I like the effect Craig. I personally think it is a step in the right direction, for what ever that is worth.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
2 hours ago, CDW said:
Playing around with a little wave/splash effects just for the experience and experiment of it. Used cotton and acrylic gel.
That first splash is exactly what I was talking about...., given the slosh pattern you have there should be another on the port side, just about the middle between the aft gun and sternpost and a bit smaller....
Your doing well, very well... looking good....
Quote:
I like the idea of your 1/700  dio  - there are plenty of kits in the scale out there.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Have you considered having water running out of the freeing ports along the side? Water flows freely through these holes as they are only there to keep air from being trapped between the pressure hull below and the free flooding deck above.
Another possibility would be to add some black smoke somewhere aft, (I am not certain where the exhaust is on a Japanese I boat) that hugs the water on each side indicating that they have just started the diesel engines to start the battery charge and the low pressure air to finish filling the ballast tanks to become completely surfaced.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
I dunno gents.....I thought it looked ok......  the water dio is good,  but in the initial pictures I liked how the model was shown,  and not shrouded in the water.   the bow does ride a bit too high,  but I liked the balance.  really nice effects ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Actually Dennis, the whole boat is a bit too high in the water... The waterline is right at the break of the hull and superstructure when in flat water and in rough seas the water will be washing over the decks on almost every wave.... The driest part of the boat is the bridge and it been described as being in a washing machine while it's agitating during rough weather.....
For a first time creating a seaway, it is excellent though.... not everyone can do a decent choppy sea their first time out....
Here it's not only decent but good job...
Quote:
For me, this was an experiment on creating an ocean-diorama type base. First time trying to do it. My focus was on the water, not the ship position in the water. To do what I envisioned doing, I would have needed either a deeper base, more than the 4 ply's of Dollar Tree foam board I used, or to have literally cut off half the ship from mid ship back to the stern. I wanted to give the appearance of a surfacing sub in rough water similar to this:
submarine-surfacing.jpg.7feac3628488239e66fcddd0c740a278.jpgR8c10882c3de7031c04714a3dab80fe98.jpg.66af4a7c468488865267120aad4fff41.jpgOIP.jpg.84a87344a158a8e0954775b6b7eb5dd4.jpg
On 12/18/2020 at 7:08 PM, CDW said:
This little project is tempting me to do some 1:700 warships in similar fashion.
Javlin/Kevin posted a diorama scene a year or so ago that got me sucked into trying out 1/700 kits.  Definitely need an optivisor if you're going to use PE aftermarket, as the pieces are practically microscopic.  Very challenging for sure.  You can see how small some of the pieces are in my Hatsuzakura log linked below.  But doing "live" scenes in a water diorama looks incredibly cool.
You got the right idea brother, a better foam base material is rigid insulation panels from the local big box store, about an inch thick can handle most seaways..... and works well in most techniques in creating one.... The foil is good for creating texture especially in a high seaway....
I think overall you did an excellent job for a first time experiment.... (much better than my first try) And you chose one of the most difficult seaway scenes to model.... Learning new things is also one of the fun things about this hobby...
You did very well my friend....
Edited by Egilman
Quote:
