HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
Hi All,
Well here is my Triton Cross Section build pictures up to the point of the
crash of 2013. I don’t have the text but I do have all the pictures.
Just a recap. All of the frames are cut from cherry. The inboard planking
to the lower gun deck beams is also cherry. The outboard planking
from the keel to the wales is Pau Marfim. The wales are cut from ebony.
The gun deck framing will be cut from boxwood and that’s about all I’ve
decided for now.
So here are the pictures up to the current update. If you
have a question along the way let me know and I’ll attempt to clarify.
The first group here is the keel assembly then various frame pieces either ready for cutting or cut out.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Here are some frames in various points of assembly.
Rusty
Here is the framing jig base and all of the completed frames first
temporarily placed to check them and then assembling them in the jig.
Also the last two pictures show the completed assembly removed from the framing jig.
Rusty
Here is the start of the inboard planking
Rusty
Here is the wales and hull planking
I found 1 picture I forgot to repost and added it to the end. It shows the strip
I used to line up my treenail marks. :blush:
Edited by Rustyj
Rusty
Rusty
Glad you re-posted. I'll be following the build. It's looking good.
Ron
Ron
Current Build: H.M.S. Triton Cross Section 1:48
Why is it that I always find out the best way to do something is after I have already done it the wrong way? - Me
Thanks all. It's great to be back.
Coming up I'll be talking about treenailing the
inboard planking. I used a Dremel Stylus, with lithium-ion battery, that I
received for my birthday. Thanks to the Admiral for that one.
So having used it only occasionally so far I thought I would put to the test.
I gave it a full charge and then started drilling treenails. Over several days
I drill over 1100 treenails without recharging. Finally before I reached the
1200 mark the charge gave out. I couldn't have been more pleased. Now I
have a good sense how much drilling I can do before losing a charge. And
quite honestly I don't see a time I would drill that many treenails without
stopping so that adds a bit of comfort.
So now here I have the start of a row of trenails.
post-43-0-66357400-1361117697_thumb.jpg post-43-0-16260500-1361117699_thumb.jpg
And now here are all the treenails added and sanded down.
Now awhile ago it was mentioned to me that I had not added the holes and
cuts for the limber boards. As they were not on the original plans I didn't
give them a thought. After looking at some other builders who did include
them I though I'd give it a go.
Not as good as Chad's and some of the others but I'm happy.
Well that brings me up to date and now it's on to framing the lower gun deck. :)
Rusty
Rusty,
The treenails and limber boards look great.
Thanks Mark and Pete,
For the exterior hull planking I used Pau Marfim which is the same wood as the planks.
On the interior hull planking I tried to use cherry but that didn't work out. So I used boxwood instead.
That worked really nice.
Edited by Rustyj
Rusty
Rusty
That looks great. What scale are you using? 1:48 or ?
Later 42rocker
Current Build -- Finishing a 1:1 House that I've been building for a while
Current Build -- Triton Cross Section
Rusty,
    Glad to see that your back. I had been watching your build and was hoping to see it back. Your doing an excellent job. Looking forward to seeing more.
Wacko
Joe :D
Go MSW :) :)
Hi Everyone. Thanks for the kind replys.
Yeah Ben you were on the short list of suspects.
42rocker. I'm building at 1:48 scale. I added it to the title. Thanks.
Rusty
Ok between reposting and trying to get somethings done I've never been so busy!
That's not to mention trying to read the postings! :)
Ok I've now started to frame the lower gun deck. I am using boxwood for the deck
beams, knees and carlings.
First I cut the deck beams and soaked them for 5 minutes. I then clamped the to a
block with a shim placed at the center to obtain the deck camber. I slightly over
bent them figuring they would flex back a little.
I let them dry clamped foir 24 hours. I then released them and allowed them to sit
another 24 hours.
They now fit the deck camber.
And here is the start of the deck framing.
Edited by Rustyj
Rusty
Thanks Pete!
Rusty
Rusty
I like that method of bending the beams. I may try that with may build.
Ron
Thanks all.
I wish I could credit who I stole/borrowed the idea from but I don't remember! :blush:
Rusty
It might have been Chad who I think steamed his. I thought about it but was to nervous about just missing the shape so 'cut' mine. Doing great though so far so keep it up..
Joss
