Such a fine craftsman you are. I was about to abandon my crude efforts on the stove, but your work has inspired me not to give up…. Yet. One difficulty I am encountering is soldering a third piece to an already soldered joint between two other pieces, as in connecting the cross piece between the two side frames. How do you keep the first one from melting?
Henry
Henry
you have to use a heat-insulating paste on the solder already made!
Like this:
https://shop.mealli.it/index.php?id_product=750&id_product_attribute=0&rewrite=pasta-termoisolante-per-saldatura&controller=product&id_lang=1
Keep pasting on the ochre on all the joints you wish to protect. Or, if you mean soldering three pieces together in the same spot, you either need to solder them simultaneously or use a lower melting point solder for the second pass to attach the third piece (can be tricky!)
On 4/5/2023 at 9:31 PM, giampieroricci said:
I resumed the setting up of the upper deck:
upperdeck128.jpg.7d35ffff06be0006ffe4ae9272274f8e.jpgupperdeck126.jpg.fcb15823ab893c43b947ac3dea6d7133.jpg
I must have missed it, but how did you make the "glass" in the windows?
current build- Swan ,scratch
on shelf,Rattlesnake, Alert semi scratch,Le Coureur,, Fubbs scratch
completed: nostrum mare,victory(Corel), san felipe, sovereign of the seas, sicilian  cargo boat ,royal yacht caroline, armed pinnace, charles morgan whaler, galilee boat, wappen von hamburg, la reale (Dusek), amerigo vespucci, oneida (semi scratch) diane, great harry-elizabethan galleon (semi scratch), agammemnon, hanna (scratch).19th cent. shipyard diorama (Constructo), picket boat, victory bow section
