HMS Hood by Old Collingwood - Flyhawk - 1/700 - PLASTIC - After her explosion.
8 hours ago, mikegr said:
great built and clear pictures
Thank you kindly.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Share on other sites
Evening all,   today  was  "trying the impossible"  time   -  bending and fitting some conning tower  rails,   I  fitted one of the ladders  - that was "easy peazy"   but the  rails  - boy was it difficult   as its all ready been mentioned this PE  is tissue paper thin  and if a fold line is bent to much it breaks off,  I am not even attempting to fit a couple of levels up  - but think what I have fitted is ok.
OC.
Current builds
Completed works.
Link to comment
Just did a calculation  - those  railings are a Huge  1.2mm  tall   - no wonder thay are hard to handle.
OC.
Current builds
Completed works.
Link to comment
I guess then that the rails themselves are at most 0.2mm thick. That is seriously small, no wonder it’s so challenging. Is the conning tower assembly resin printed or moulded? I don’t see any layer lines or evidence of supports and, assuming it’s moulded, those moulds must be a work of perfection in themselves. Fly hawk should hire you or pay you, you’re doing them proud.
Link to comment
The brass PE sheets in this Flyhawk kit are 0.11mm thick!
I know because I'm working with the same PE and I measured it with a digital vernier calliper. It's enough to drive a man to drink!
Come to think of it, I don't really need tissue-thin PE to do that - 'er indoors manages to get me on the bottle without even trying! 🥴
Edited by RogerF
typo
Link to comment
That’s thinner than a standard sheet of copy paper. Extraordinary. I imagine they deform at the slightest slip of the fingers.
Link to comment
Thank you kindly.
OC.
Current builds
Completed works.
Link to comment
Hi all,   I had my normal Saturday off  so I could  relax infront of the tv,    anyway  onwards  on Sunday  where I will be battling with  somemore  Paper Extreme  (PE)   with a few more sections of Railings and  short ladders on the conning tower.
OC.
Current builds
Completed works.
Link to comment
What is more important is the rigidity of the material. I used Aber PE from Poland. They were the worst. Could be bent by just paint brushing them. Then used many from Chinese manufacturers but not Flyhawk. They were better but still soft, while good in detail. Same for White Esign and Russian Micromask.
Japanese PE are the crispiest by far. They can be cut easily with worn blade or on a soft surface while still being durable and forgiving . Can even hear the cracking sound sometimes. Something like the Japanese knives i suppose.
Metal hardness can be achieved by proper treatment perhaps by high temperature. And obviously this has an cost and impact on quality of those material.
Ofourse being solid hard is not the case here as this would create folding problems. There is a magic balance that has to been found to make our lives easier.
Link to comment
Evening all,    I did a bit more work with my tissue  origami  still on the  conning tower  - so more rails and ladders  oh and a few  details - binocular stands etc.
OC.
Current builds
Completed works.
Link to comment
13 minutes ago, king derelict said:
The PE really looks nice. Railings and ladders always make a great difference. You are getting it very tidy even under the cruel eye of the camera
Alan
Thank you kindly Alan,   just to think there is Four seperate sub-assemblies  making up the conning tower  - each section will be  airbrushed  then brush painted  Corticene.
The binoculars  - I might try to use some of my acrylic  water to create the lenses .........." I dont think so" lol.
OC.
Current builds
Completed works.
Link to comment
Building up really nicely OC.  PE dresses things up nicely.
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Thank you kindly Mike,    boy is it fiddly and delicate  - and can not be rushed,   I use the old fashioned way to remove and bend the PE  - sharp blade  then blade and tweezer flat end to hold the PE  while I use the blade to  bend  it,   then  holding it with tweezers  to glue in place is tricky  - takes great  skill to keep my hand still enough during this.
OC.
Current builds
Completed works.
Link to comment
I think that's where a Hold and Fold comes in very handy.  It holds the piece in place, while you use a blade to create the bend.  I'll also on occasion use the Tamiya folding pliers (they have two sizes) which work well too, but easier to keep things steady in a Hold and Fold.
Mike
Link to comment
Evening all,    a bit more done this evening  -  I added a few bits to the Bridge  and a bit more PE,   I have added a  few items in the pic  for scale  the coin in a Ten Pence Piece  and my glasses.
OC.
Current builds
Completed works.
Link to comment
Evening all,  will be doing a wee bit more later but firstly  what a day  -  the admiral  has been suffering with a very sore  ear  and dropped left side of her  face drooped  eye and mouth,   yep  we  feared that as well  (stroke)  so after  ringing our doctors  he rang  back and wanted to see her  asap,   we went to the surgery  and he checked he over,   he said it wasn't  a stroke  but after giving her an examination  he said she is suffering from Shingles  in her ear.   He said in an ideal world she would be in hospital  but instead  he gave her a course  of  Steroid  tabs.
She has certainlt been through the mill  of late.
So after making sure she is ok and doing our supper I will  do a wee bit more on my Hood.
OC.
Current builds
Completed works.
Link to comment
Get well soon. You're both in our thoughts and prayers, mate.
Ken
Started: MS Bounty Longboat,
Link to comment
1 hour ago, king derelict said:
Hope the tabs bring relief quickly. Thats nasty and worse just before Christmas. I hope it all goes well. I'm glad you have a responsive doctor.
Alan
Thank you kindly Alan,    yep they  were on the ball   and thankfully the doctors waiting area was quite empty.
OC.
Current builds
Completed works.
Link to comment
Thank you Ken for your  kind words.
OC.
Current builds
Completed works.
Link to comment
I know you'll take good care of her, OC.   But also take care of yourself.   I think (can't remember) shingles is contageious or can be.
Link to comment
Yes indeed  Mark,   I asked the doctor that and he  said  you have to come in contact with the rash and touch it  to  catch it, and she has no rash  just the dropped side of her face and really painful ear  - she is more  embarrassed about her face and speech  as  she has the appearance  of a stroke (thank goodness  it wasn't)
OC.
Current builds
Completed works.
Link to comment
OC.
Yes, big relief it wasn't a stroke.  Just be careful yourself around her ear.  That's not something you want to catch either.
Link to comment
Thanks  Mark, will be carefull  - we were over covid  - not sharing towels  constant  washing of hands  etc.
OC.
Current builds
Completed works.
Link to comment
Evening all,   got a couple of hours on my Hood  -  I have moved on to the boat deck again,  there is another block situated here  that has  several items here  including another Hacs device.
OC.
Current builds
Completed works.
Link to comment
Found this on the internet  -  just amazing mindblowing  work  including  weathering and  rigging  at 700 scale 😲
OC.
https://www.golectures.com/index.php?go=search&q=[FULL BUILD] 1%2F700 THE MIGHTY HOOD ( Flyhawk Deluxe Edition )
Current builds
Completed works.
Link to comment
Evening all,   after cooking our supper  spag bol  as the admiral is on soft food due to her face  paralysis,   I did a bit more on the rear block  -  I added a couple of PE  rails, the  rear Hacs   and some  signal lamps  - also the two column platforms,   still some more PE to fit on the top.
OC.
Current builds
Completed works.
Link to comment
Evening all,   not  a very large update  to be honest I only attached Two items  -  Two really small sections of rail  to finish off the rear  block, then It was time to do what the Admiral  our  doggy and I always  do  -  open  just one prezzy  each  with a mince pie or Two,  I  got her a new phone case  and she  brough me a few beers  (very nice)
Happy Christmas to Everyone  - take care and have fun.:cheers:
OC.
Current builds
Completed works.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
