Thank you all for you're  still here.
Sorry for this delay but I had to travel to UK to see my new grandson.
You see, I became grandfather for a second time. post-5339-0-77529700-1393118873.gif
Back to work now...
Soon as I got back I painted the cagemast and I placed the fitting of the open bridge.
I must admit that this cagemast is a model by itself...
Thanks
Stunning work. That cage type mast rivals the Eiffel tower in beauty.
New Bedford Whaleboat build. Kit by Model Shipways
I've been making progress on my model and according to the instruction booklet I should be painting it, at least parts of it.
Are acrylic's ok ? I did apply a sanding sealer. but I want to stain the untreated floor boards which are walnut.
Thanks
S.O.S.
I will echo others - a really beautiful build coming together ! The photo of the cage mast with the sky background looks as if it is the real thing ! Quite impressive !
Joe
Joe Zappa
Member, Nautical Research Guild & Puget Sound Ship Modelers
Congratulations on the grandson and on the cage mast.
Thank you all for your wishes that I became a grandfather...
Because of a misunderstanding of the middleman (who translates the presentation...) actually it's granddaughter.post-5339-0-57597200-1393182863.gif
Thank you
Edited by Panagiotis
Congrats to your very well done model Panagiotis,
the model hull design was a bit strange to me in the beginning, but therefore such highly interesting to follow. You seem to know exactly what you are doing. A great build !!
Thanks for sharing this beautiful model log
Nils
Current builds
-Lightship Elbe 1
Completed
Hi all.
Some more progress making fittings, (doors, hatches, skylights and deck bases for the funnels) out of plastic.
I made also the two funnels much easier that I expected,
I found and modified two empty medicine container tubes... that were perfectly matching  in scale.
Thanks
Hi all and thank you for your kind words.
I was dealing with the ship’s windlasses all this time…
She had two main for the anchors and four smaller ones for ropes.
I started constructing the main ones using pieces of plastic in proper shapes.
Every anchor windlass is consisted from 25 pieces...
The windlasses for ropes was another story...
They seemed to be much complex and I had no any good view of them in some photo. To be honest, I tried to find something ready from the market, thinking to modify it but eventually and haven't found something close to them, I constructed them also from scratch.
Finally, I placed them all on the deck.
Thank you.
Hi all. After some time of absence, I'm back with the construction of the turrets.
I started with the big ones (12") on prow and stern, making the shells of them from proper shaped plastic.
I was counting on some spare gun barrels that I thought it would be suitable to finish them but I was wrong...
I soon realized that I had to make or buy new gun barrels.
I didn't want to waste more time, so I put them aside and start making the side turrets (8"). I had to make all four of them.
Again, I made the shells with plastic and finished them, by placing those gun barrels I had in my spare box.
After some modification by a lathe, I think the final result is quite good.
Thanks
Well, I haven't forgotten you….so here I am.
Some progress before the summer heat, hit Greece
I built the cranes, covering a proper shaped pieces of wood, with thin layers of plastic
and by modifying clothing material,  I reproduced the hooks.
I built also the second (to the rear) cage mast by knitting thin wire using a jig and as I did for first one.
Wow.. I did not realize how large that ship was until I saw the turret in your hand.   Beautiful work going on there.
Stunning work--she is a beauty! Like Mark said, I didn't realize how large she is until I saw the turret in your hand.
Cheers,
Jay
Current Build:  Ariel
Hi Panagiotis,
superb Details everywhere and excellent workmanship
well done !
Nils
Current builds
-Lightship Elbe 1
Completed
  • 4 months later...
Hi mates, I'm late, but I’m back…
It’s been a long summer, visiting family members in Europe…but there is some progress though.
So I managed to build the searchlights (four on every mast) and the other navigation lights.
I also made the lifeboats, by modifying some others from my spare box.
  • 5 weeks later...
Hi Again.
Making progress, I had to build some more cowl vent heads.
As you can see in photo of the real ship, there were four more of them in the upper deck.
Having noticed their turning ability, I also accepted the challenge.
Determining the diameter of the heads I firstly made a curved form from plastic and a related hole on a wooden plate.
Then, I shape them by the help of a hot air gun (hair drier wasn’t strong enough) and by pushing thin pieces of plastic with the curved form, on the plate's hole.
Eventually I cut the cup shaped pieces and I glued a piece of plastic tube on everyone but only at the half size of the final high.
The rest of the tube's high was made from a smaller in diameter tube so in a final combination, the heads have turning ability.
Using thin piece of plastic and some putty, I extended two model boats from my spare box and I built the two steam launches of the ship.
I have left some details for later...
Additional progress on the top of the cage masts,
by painting parts (like 12” gun turrets)
and by making some small parts, that can’t be placed at this time on the model (like flag poles-boat davits).
Hopefully, I think she should be ready by the end of the year.
Thank you
  • 5 months later...
Hi mates and thank you all.
I'm almost there but still... As I'm reaching the end, it keeps moving further...
Some more progress on details.
Again by the help of real photos, I completed the two steam launches, some detailson the upper lifeboats
and I set up the stern lifeboats on their cranes.
It is not showing in many photos of the real ship but there were also four (4) large life rafts. Two were placed on the sides of the turret in the prow and two others on the sides of the rear cage mast.
Those old life rafts used to be constructed by pieces of cork, while they had a wooden floor or a net.
A piece of a thick wire gave me the shape of those rafts while the filling of the frame with tape and a wooden floor, took me to a decent (I think) result...
