Thanks for all the encouraging comments!
Current :
HMS Sphinx by Vanguard
Completed:
Orient Express Sleeping Car by Amati
Bluenose II (Artesania Latina)
Istanbul Tram - Occre
Bluenose II - Artesania Latina
Bosphorus Sandal Fishing Boat
Riva Aquarama - Amati
Titanic - Mantua
Bosphorus Fishing Boat - Tersane Model
San Juan Nepomuceno - Artesania Latina
Bluenose - Billing Boats
8 hours ago, druxey said:
Very nice! Are you going to put lighting inside so that the interior can be seen?
Though I am not a big fan of "bringing a model to life" (e.g. with human figures, lights, sounds etc), I am considering to add leds to this model, only if I am truly convinced with the possible options. I will try to plan the lights at as accurate as their original spots, such as one on the ceiling of each compartment and a few on the corridors, if this approach works. That would mean I will not install just one or two lights to give a general illumination.
For this purpose I ordered the special leds below:
https://www.smallscalelights.co.uk/product/3528-12-18v-chip-leds-on-pcb
Current :
Completed:
Titanic - Mantua
BUILD DAY 44 / 2.5 hrs / (TOTAL 109 hrs)
Figures 451-457: Here is a series of photos from the roof construction. Overall it went smoothly. Once all parts glued, the next task was to do some surface finishing: remove the spikes coming out of the roof and smoothen the surface using sandpaper and file, especially to get rid of any glue residue. It was pretty much like finishing the hull planking of a ship model.
That's all for now.
Thanks for watching!
Current :
Completed:
Titanic - Mantua
10 minutes ago, wefalck said:
Looks really like thing - ignoring for the moment the 'brassy' appearance of the roof.
Yep, it is ready for painting in white!
Current :
Completed:
Titanic - Mantua
really nice job on the train car :)   the roof assembly was very interesting.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
BUILD DAY 45 / 6 hrs / (TOTAL 115 hrs)
It has been a while since my last build post. I have been traveling and time to time investigating how to install lighting on the ceiling. As I wrote earlier it had to be close to original lighting with at least one per compartment, not just some spots here and there.
I also wanted to fit all the lighting elements (i.e. incl batteries, switch, wires) into the roof structure to avoid hanging of wires around and be able to remove the roof freely without any obstacles.
Here in this post I will show my ceiling structure and light installation.
Finally I was able to find led lamps, small batteries and switch with suitable specs.
LEDs: They are 12 volt and resistors already soldered on the PCB board. They are from a small supplier in UK, https://www.smallscalelights.co.uk. The owner of the webshop, Jennifer, is the same person who is actually producing most of the nice railroad lighting items. Not all the countries are available for shipment, I sent an email request and she sent my order to Finland. So, if you like something on her webshop but your country is not in the list, it may be worth sending an email to her!
Switch: Simple small size 1-pole toggle switch.
Battery: A23 12 volt batteries. Here I installed two of them in parallel. So, still 12 volts but more power to light all 12 leds.
Figure 458: Here is a single LED. It is ready to use if you just hook it up to a 12V battery source.
Figure 459: Here I soldered them to each other in parallel to make a strip of 12 leds, with enough cable in between for installation. Test with the battery looks good.
Figure 460: These are the batteries I use.
Figures 461-464: Experimenting the installation on a scrap test piece (on the right)
Figures 465-466: Testing the installation on the real ceiling piece. I think it looks pretty OK like this
Edited by aydingocer
Current :
Completed:
Titanic - Mantua
Figures 467-472: Ceiling structure, made of carton, to be bent at the designated lines and glued to the roof structure. I had to follow a certain order as I install the leds and wiring during the construction.
Current :
Completed:
Titanic - Mantua
Figures 473-475: The lighting is in place and it doesn't look bad at all!
That's all for now.
Current :
Completed:
Titanic - Mantua
2 hours ago, aydingocer said:
That's all for now.
It's been a pleasure my friend, Beautiful job!!!
Well done...
Quote:
1 hour ago, Veszett Roka said:
Aahah, a BeoCenter 2300 :) You're a man! Listening it must be a pleasure when modeling.
Indeed!! 😃
Current :
Completed:
Titanic - Mantua
Figure 476 - 485: Final photos
Orient Express is finally ready.
I ordered the custom size display case from Sora Shop in Germany (sora-shop.com). Highly recommended. This one cost me around 53€ + 13€ shipment to Finland.
Thank you all for watching, following and your inspiring messages!
Aydin.
Current :
Completed:
Titanic - Mantua
Amazing work  - you must be proud of all your work.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Fine model, very nicely executed. The presentation in the display case is very elegant.
Congratulations,
Dan
This is a superb model. Now, you need an engine in the scale of 1/32nd to pull it.
If you can afford a very expensive SNCF Pacific 2-3-1 from LEMACO, FULGUREX or MARKLIN at 1/32nd scale, that would be perfect. Otherwise, OCRE proposes a Pacific steam engine for a few hundreds euros, that you may be able to turn into a little jewel, with your skills.
Yves
Edited by yvesvidal
Truly an elegant model masterfully executed. Congratulations and thanks for inviting us along for the trip. I especially like the last photo, looking through the windows. All that is missing is the steam and smoke of the train station.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
This has been one of those models that all one can say "wow! wow!!!!"   And the display is perfect.   Thanks for letting us look over your shoulder.
Yves
I have been seriously thinking of this OCCRE actually, I am just undecided between an HMS Sphinx or this one, as next project. I kind of missed the smell of wood :). But OCCRE is in my list!
Current :
Completed:
Titanic - Mantua
