8 minutes ago, RGL said:
Thanks, the Hasegawa PE give you an option for a cover on the bridge that was unique to the Gambier bay or for all other types that Flyhawk doesn’t. Essentially the Hasegawa set is very limited but nicer with tighter tolerances. The Infini radar comes with turned brass pedestals and is hands down nicer. Both Flyhawk and Hasegawa continue with manufacturers making disjointed and confusing instructions which means using three sets took me three days and I’m still confused.
The result is magnificent
Alan
to be honest, i never thought about how good but unserviceable aircraft got back home, i need to read up on why this ship was used for it
the PE work looks fantastic
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
There's interesting stories on all those escort carriers.  Smaller than "normal" carriers they were originally designed for convoy escort duty.   But they also filled other rolls with transporting aircraft from the States to remote islands and locations to returning them back for overhaul.  Wikipedia is a good place to start.  Maybe start with Gambier Bay or "escot carriers".
Strange question  - how do  you all keep you  finger nails  down  -  like mission impossible   for me with no teeth.
Great build   Greg.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
cannot say i fancy all that masking, but she certainly looks great
Great build   Greg.
OC.
sorry, i dodnt have an answer for you, have you asked the wife to bite them for you😀
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Amazing work Greg  - al that detail   blending togther  but also looking so sharp.
OC.
Current builds
Completed works.
Hasegawa sells the stick on blue deck with some PE as an expensive aftermarket set. Not a hard action to stick in but if you removed the little bits to replace it with PE they are a tiny bit too small and leave the plastic deck visible. I’ll finish the PE tomorrow and do the deck markings including masking up the 90 for the deck then some weathering.
Greg
So I’ve added all the metal parts now, (mainly the arrestor gear stuff), and rubbed on the lines (the Hasegawa set has dry decals which I do like but you can’t mask over them as they lift. This I have a bit more painting to go because of that. Then masked up the ship number .
Greg
Neet work with the masking Greg   - you going to spray them in  or brush?
OC.
Edited by Old Collingwood
Current builds
Completed works.
Great work Greg
It's funny though. In the "aerial" shots you used in this set, combined with not having the island as a reference, I found it hard to tell which end the bow was until after you applied the deck numbers.
it's already clear that it is going to be another nice looking ship.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Part 2, I used a light blue diluted oversprayD0B7F476-42D8-4F1A-8EBF-6A739B00E224.thumb.jpeg.062081c4ab0c68d25f6349a071b8917f.jpeg8083B0D4-0E8A-4A1A-A888-7ACFBBBF83E5.thumb.jpeg.ed587a97bfd7ec997409e20a0164db11.jpeg
then a tan overspray0349CACA-1097-4085-8748-83177D2004DA.thumb.jpeg.486154f12a3518592c763020ef79e45a.jpeg
. I then have a the metal cross braces a dark wash (these are the metal sections they use to belay the aircraft)
B45DF2F7-EA9A-4405-946D-A90C789BEC64.thumb.jpeg.cf80a4c38293addedf844ef79461821b.jpegthen another overspray. B1F50A9E-F08B-4359-AFEA-4D3A53515427.thumb.jpeg.7a15c431312327e8363e50022415a730.jpeg
Edited by RGL
Greg
That is looking Superb Greg  - that weathering  is Spot on.
OC.
Current builds
Completed works.
I'm late to the party again Greg.  An interesting subject again; look forward to seeing more.  Looks like you are having a lot of fun with that airbrush this time around.
cheers
Pat
